Well I still can’t decide what I like better in an L2, the dedomed XP-G2 with more lux or the XP-L HI with more lumen and better tint. I’d say the XP-L HI is more practical in use. The sliced XP-E2 is funny and maybe cool to have that kind of reach @ 2,1A, but not practical at all. One day I had a fox lit up maybe 200-300 ft away, I had to hold that light soooo steady just to keep him inside the beam… Dedomed XP-G2 is somewhere in between, but compared to the sliced XP-E2, even the dedomed XP-G2 is so much more practical.
I hear you on the measuring stuff, PD. I don’t like to measure the heck out of my lights, I simply like em or I don’t, don’t care much about numbers.
Yes, stock reflector but i might be wrong about the current because it is direct driven, no driver at all, so it might be higher. At the time of the test i had three 25R’’s in it, ive seen that same led pull just over 5A from a single cell, so with 3 in parallel there might be a bit more juice delivered to the led.
My TM16 is making 109.75Kcd, essentially stock… I didn’t change anything on the driver, still has the NW (on the warm side of NW) emitters, but I used 18ga Turnigy leads throughout, in place of the 20ga they used.
So I’d say you’re in the ballpark.
I’m using fresh charged LG HE-2 Button Tops.
Direct Drive for Turbo? Where does that info come from? I see an R010 sense resistor on the driver… mine tests out at a bit over 4100 lumens.
Lol…you made someone a very happy camper though. You were able to spread your joy elsewhere. My edc has been the X5 since I received it and it probably will be for a long time.
