Yeah, tested it, three 25R’s @ 4.19V = 5.7A at the tail, so there it is, it is more than 5A.
My TM16 is making 109.75Kcd, essentially stock… I didn’t change anything on the driver, still has the NW (on the warm side of NW) emitters, but I used 18ga Turnigy leads throughout, in place of the 20ga they used.
So I’d say you’re in the ballpark.
I’m using fresh charged LG HE-2 Button Tops.
Direct Drive for Turbo? Where does that info come from? I see an R010 sense resistor on the driver… mine tests out at a bit over 4100 lumens.
Probably misremembered DD.
Max did a really nice write up on the TM16.
Hello my friends! banggood sent me a nitecore TM16 - a Tiny Monster! they also offer it for us to a unbeatable price ;) [image] you can find the other glossy advertisement pictures in banggoods webshop ;) the Specifications: (from the shop) Product name: NITECORE TM16 4x CREE XM-L2 U2 LED Flashlight Brand: NITECORE Model: TM16 Emitter Brand CREE Emitter Type: XM-L2 U2 Material: Aerograde aluminum alloy Total Emitters: 4x Lumens: 4000lm,1780lm,680m,280lm,5lm Runtime…
With the lumens Nitecore quotes (4000), Turbo is probably like 2.8amps per emitter. It still could be susceptible to a tenth of a volt or two.
My only remaining Courui D01 also uses 25R’s, it’s making 545Kcd with an XP-L HI for 1476.48M throw.
Not liking myself for selling the SBT-70 D01.
(gotta see if I can tweak it for that remaining 436 feet to make a mile. LG HE-4’s will probably do it. )
Edit: Best is actually from Efest 35A’s in this light, at 557.5Kcd for 1493.32M. Still some 381 feet shy of that elusive mile. Oh well.
Lol…you made someone a very happy camper though. You were able to spread your joy elsewhere. My edc has been the X5 since I received it and it probably will be for a long time.
545kcd using xp-l hi ? Sweet .
Also , anyone using the 86mm KD reflector in his D01 ?
How did you focus your D01 for that throw?
Yeah, that little quad is a pretty dang sweet light, for sure. Dang sure won’t be picking one up at Wally’s World anytime soon… :laughing:
Nothing yet but it is still early...
I cheated unknown. The “Big Head” Courui is now the Mega Fat Head Courui.
153mm Seanna optic.
153mm Seanna optic.
Ohh i remember now :smiling_imp:
Shame Shame Shame.
I need to tweak mine. It was such a pain for me to mod it when I finally got it all together and properly centered I just left it. Low 200kcd’s iirc. Really disappointing for a FET XPL-HI in a Courui D01.
CQG Carbon Fibre
- Nitecore TM16 - 105kcd - Stock (Nitecore rates 122.5kcd)
- Solarstorm SP03 - 236kcd - Dedomed XM-L2’s, FET
- Courui D01 - 231kcd - Poorly focused dedomed XP-G2, FET
- Brinyte B158 - 230kcd - Dedomed XP-G2, FET
- Convoy L2 - 130kcd - Low-bin (possibly poorly focused) XP-L HI, FET
I recharged the batteries completely in these 5 and measured again. The only other change was that I removed a rather tall centering ring from the Courui, but it didn’t make much difference. It was one of my earliest mods, and I have a feeling I just need to completely rebuild and update it. Any tips on where best focus is? Right now the reflector is directly on the mcpcb. Not sure if I need to raise it up more or sand some off the reflector.
Marked improvement in the L2 with a charged cell.
Here are the numbers:
- Nitecore TM16 -
105kcd> 111kcd - Solarstorm SP03 -
236kcd> 255kcd - Courui D01 -
231kcd> 239kcd - Brinyte B158 -
230kcd> 243kcd - Convoy L2 -
130kcd> 194kcd
Sweet mod CRX !
I sit a wrap or did you fit the CQG into a carbon fibre tube ?
Thanks. It’s a 14mm od x 12mm id carbon fibre tube, i just cut the pieces and epoxied on.
I always felt the S2 was just a bit too thin & slippery - much better now.
10180 & 10250 battery charger
Great work one more time CRX … Very very nice charger
Cheers mate
