Hey mate great review. In your opinion do you think these are the Fujitsu cells(FDK)? They perform similar? The capacity seems to be on the lower side if they are.
Thanks!
Thanks a lot, your reviews are much appreciated. I read them all. Actually these days I come on BLF only for your reviews!
Have you planned to test the other NiMH cells on the IKEA store? In particular the 500mAh AAA cell which seems like a great bang per buck IMO (3 euros for four cells).
everydaysurvivalgear, how do you get that the capacity seems low? If you look at HKJ’s comparator, compared to Eneloop Pro Black, which is also rated at 2450mAH, these actually perform a little better. Of course the Eneloops were probably tested under the old system, so the difference could be within the margin of error. The curves do look pretty much identical otherwise.
Assuming it’s one of the smart Eneloop/Panasonic/Sanyo chargers (most of them are smart chargers), it shouldn’t have any issue charging these. If it’s not a smart charger, you probably shouldn’t be using it on any battery.
If these are equivalent (or close) to Eneloop Pros, you should be able to safely charge them at currents up to 2 amps. Faster than that, and you may reduce their lifespan.
I'm going to finally replace my aging knock-off "penesamig" and "2500mAh" (this capacity almost sounds legit nowadays) with these ladda batteries. They seem to be good bang for the buck–at not much more than half the price of eneloop pro's. The nearest Ikea is only 40mins away from me :)
I've come along that video multiple times, and most people thi k its something new. If you want to know more about FDK batteries, there are many more than you knew.
