Due to low interest and the large amount of time hand building these items takes I do not plan to make any more of these Drivers by hand. I do have some raw parts left for you to build your own items though!
See this thread for all the details on the hardware Texas Avenger Driver series - Triple channel + Bistro or Narsil + Clicky or E-switch - The Ultimate open source driver!
All prices are + shipping, generally $2.80 per package in the USA. Shipping is a flat $2.80 for up to 4oz, then $4 for up to 8oz and finally $5 for up to 1lb. Basically for most people it will be $2.80 shipping in the USA.
For international shipping it is sadly much more expensive. I can send it via regular mail without tracking but be aware, there are positively no guaranties with this method and I do not like shipping like this due to that. This option runs about $3 to most countries. With tracking it is generally about $13 to most countries. Contact me for an exact quote.
Texas Avenger blank PCBâs, cheaper then buying them from oshpark
7 - 30mm Texas Avenger LDO PCBâs for the L6 / S70 or other lights
- $3 each
2 - 46mm Texas Avenger PCBâs for Skyray kings & Q8 among other lights
- $3 each
8 - 46mm Texas Avenger Multi-cell LDO PCBâs for Skyray kings & Q8 among other lights. This allows you to run in a 2S or 4S cell setup for driving XHP LEDâs or the LEDâs in series.
- $3 each
8 - Skyray kind multi-cell tailcap PCB with optional fuses, this works with the above driver to setup the light for 2s or 4s operation along with the possibility of using a tailcap clicky switch among other things.
I also have some of PD68âs Illuminated tailcap kits for sale (with his permission).
These are the raw parts kits for building the lighted tailcaps. I ordered enough parts to build 100 of them but have only built 25 or so. Thus I have a few to sell lol.
I am sold out of the PCBâs, plus you need to get the right sized PCBâs for your tailcap anyways (I generally use the 5.1/5.3 combo). So these will need to be ordered separately from oshpark. The details are all in the above thread.
These kits come with:
1288 switch
50k (or I have a few 100k) pot
Spring
Header pins
4.7K resistors for the LEDâs
LEDâs in the color of your choice
Choices are Red, Yellow, Green, Blue, Purple (does not work very well), White and Orange.
- $3 each
Lighted tailcap pictures:
I also have a few FET+1 Skyray king 46mm Drivers with custom copper contact plate and temp sensor left as well
- $12 each
FET+1 SRK V2 Driver:
Convoy S2+ âTactical Combatâ ring. I got requests for these from some local cops and they work quite nicely actually. It allows you to have a âcigar holdâ on a Convoy s2+. To install it simply presses down over the back of the light and the tailcap screw down âinto itâ.
It is a tight fit to ensure it doesnât come loose so expect a bit or resistance when pressing it on. Also it will only go one way, the tailcap is slightly larger then the body, so test fit it to the tailcap first in order to see which side needs to face the tailcap.
1 - Black
1 - Gray
Can also custom make them in most other colors including White, yellow, neon Green, dark Green, White, Blue, Red, glow in the dark, Opaque, Gold, and several other colors.
$4 each
