The ones from DD are also sold out. I just received my last replacement cells shipment of 6 protected cells from DD. They test to just somewhat shy of 2300mAh @ 1A and 2.826V (as measured by my UT-58E DMM)
It is not a big problem finding other batteries with about 2000mAh at the same price, there are lots of different names in cheap batteries and my guess (without testing) is that many of them will be between 2000 and 2400 mAh.
HKJ, my cheap batteries do not fare 2000mAh. I'd be happy if they can do even 1600mAh. A lot of them are between 1-1.5Ah, and some like GTL and "Sony" ones do 500-800mAh. They are reclaimed batteries.
Thank you for the review HKJ, I was about to order a few of these batteries. I did order some 14500's in the same wrapping, though. Hope their capacity isn't similarly reduced.
I am not going to check more of them for the next two months, but if other people get some and can test them, it would be nice if they could post shop (and sku), date and capacity.
WoW Outstanding Awesome Review!!! Thanks for sharing HKJ
I have received 12 of those new cells from DX, and I don't like them.
They DO look different from the older TF Flames, this new batteries have a crossed trash bin symbol near the CE symbol (older TF Flames doesn't have it), colors are sightly different, red color on the flames are more notorious on the new cell, and brown color in the flames is more notorious on the older TF-Battey. They also look fatter for me but I haven't measured them, and they may change in length between each other (comparing new with new).
For me it is no longer a deal to buy this batteries, I'm looking forward to your review of the ManaFont TF 3000mAh
[EDIT]
Here I show a third cycle of those batteries interconnected 4S.3P @ 400mA (that means 133mA for each cell) till protection kicks:
I'm very disappointing with this results; THIS DX's batteries performed better in my case, and they are the cheapest from their site.
HKJ, as FX-32 states, your new Trustfire Flames look different from the older DX Trustfires. They also look different than my most recently purchased set from BIC (less than one month ago).
Benckie’s test batteries (from Manafont I believe) don’t have the trash bin symbol after the CE symbol either--take a look at the photo in post 26:
https://budgetlightforum.com/t/-/4522#comment-85416
In addition to the absence of any trash bin symbol, all of the 18650 Trustfire flames that I have purchased have a textured negative terminal. Yours appear to be smooth.
Are your Trustfire Flames fakes or just a new design? I don’t know, but maybe you should change the title to “DX TrustFire TF18650 2400mAh (Flame)” since Manafont and BIC still appear to be selling the original, and better performing, Trustfire Flames.
The negative terminal is the same, I just compared to my 1 year old flames.
But the trash bin is only on the new batteries, this makes me believe that they are the new TrustFire flame. A copy would probably use exactly the same design as the old ones.
If you look at the info box, you will see that I do specify where I got them, include the DX SKU number.
I believe that it is very interesting to see what batteries comes from where, but we do not know enough about these batteries yet, are they the new generation flame or did DX just buy some even cheaper copies with improved marking? It will probably take a few months before that can be answered correctly.
I recieved two pairs of the "3000 mah" TF Flames from Manafont, last week. They do have the trashcan symbol, FWIW. I have no equipment to test these cells, so I will leave it to others to determine if the extra $2 ($1 per pair) was well spent or not. :)
