Indeed, I knew I had forgotten something lol.
Adding some pretty pictures to the OP for people to gaze upon.
What do you mean by ācan freak out with multi-LED setupsā? I want to use 17mm Tripledown Drivers on my triple led flashlight, what problems should I expect using this driver?
You and me gotta talk.
Really great
I will take the purple lightend tailcap
Regards Xandre
Really want to try out one of the full featured 17mm with SIR800DP MOSFETās. This would broaden the feature set of my Ti Quad that I EDC and give me a more accurate voltage monitor arrangement. Iām currently using the A6 firmware due to the instabilities in Bistro with a Quad.
If I could buy one from you to try out, that would be helpful. Then Iād know how many boards and components to attach myself to.
Really good prices for the populated TA17 drivers. Can confirm, it takes quite a while to hand build them
The tripledown (which is was the best design and components available at the time for the record) does not have the latest components (as it lists in the quote). These components were added to the drivers to deal with large voltage spikes that happen with high currents. These voltage spikes can cause the MCU to freak out and do strange things.
Generally I find it will simply shut down with triple setups when it tries to engage the FET although other odd things happen as well like going into programming mode among other things. You never know what will happen with voltage spikes like that.
I have tripledowns in lots of single emitter lights with the only issue being a small flash when changing modes in some cases. In all the triple builds I have tried though they freak out.
PM incoming.
I have actually been putting together a little goodie bag for you to try out, I was gonna wait until I got another item done to send it out but not sure when the parts for it will be in. Got orders out everywhere and I donāt even remember half of them until they show up lol.
It was an early issue with Bistro, getting Turbo to run reliably. There were issues with the components used on the driver that caused the MCU to shift down to moon or low when trying to go into Turbo, even on a single emitter set-up. The release came out with the lights working, for the most part, but shifting to a triple flared up the issue again.
I use A6 firmware in my Quadās because of this, as much as Iād prefer Bistro itās just finicky to get everything working right with correct timings.
The Texas Avenger series promises to correct this, Del scoped out the issues and proper components were sourced, added, removed, relocated, tweaked, hammered and shellacqued.
I wish soft start were still in play as I liked that feature, it was an instant giveaway that Bistro was in progressā¦
Thanks!
Yeah, when you build them for yourself you donāt really notice the time it takes but when I started actually timing the process I was quite surprised to find it was taking over an hour for each driver at first.
By building them in batches and buying/making some jigs plus some experience I have cut the time down to 30-40 minutes now. So basically I am making just over minium wage on these lol.
Indeed, I have had no such issues with the Texas Avenger drivers even with triple XP-G3 lights (of which I plan to sell a few soon) running 16+ amps. The new components list by DEL truly make the drivers rock solid stable in my testing.
I also like the soft start, This is one of the features I want to add back into it if/when TK ever has time to implement the compacted code. It is simply out of space right now.
With the space gains she mentioned possible soft start, 31 mode groups, a larger ramp table and a few more fun strobe modes should all fit.
Although for those like yourself another possibility is to use a tiny85 instead of the 25 and then you will have plenty of room for everything you could dream of.
I suppose I could release a version of the firmware with less mode groups and soft start enabled. Hmm, something to think about.
I really love the 7 mode with reversing into hidden modes. Might would play with some crazy strobes on occasion but my memory makes it difficult to do that kind of thing, so a very elaborate firmware table is lost on me. Iāll set it and forget it.
Iāll take one 17mm TA with sir 800 FET and one SRK driver.
PM Sent.
Thanks, I am happy with how they have turned out so far. They could have never happened without the help of lots of others here.
TA, Iām in need of several of the 17mm version with your variant on Bistro. What I need is the full featured set up for use in a quad light. I donāt care about you building it, throw all the bits in a ziploc and mail em, I can build them myself no problemo. Can we do this? Iād use an L6 driver the same way, just set it up in the MCU and throw all the bits in a bag, Iāll take care of the rest. I need to get a top binned XHP-70 so I can mod the clear L6 for my son-in-law, he has need of a big boss light at work. (Actually, this one needs a ramping firmware, if you can do that, if not I can flash the MCU with my own.)
Holler at me and weāll figure it out, Thanks!
No particular hurry, sometime in the next hour is fine. (just messin with ya, need the light for my son-in-law for Christmas, the otherās are not pressing)
This is kind of the idea, lots and lots of options but most will set it how they want it and never touch it again. The idea is to have those options for everyone.
I do have a version of the firmware with 14 mode groups, a larger ramp table and soft start (I think) enabled. I will have to check into that again. I might add it to the release as an option if people want it. Basically it doesnāt have any of the mode groups after 14 IIRC and has soft start enabled.
Well, I should have a goodie bag of stuff headed your way shortly :partying_face:
Has anyone bought a tailcap yet? With how often I get requests, I would have expected those to fly off the shelf
edit: Oops, I see now that most are marked as āsold outā I just didnāt remember seeing comments about them in this threadā¦ so nevermind!
