protection tube for clip solarforce
8 posts / 0 new
The Last Katun
The Last Katun's picture
Last seen: 1 hour 33 min ago
The clip Solarforce touches the tube of the flashlight and can scratch the surface. I added a small plastic insert.
This component is required to combine the mainboard to the case, they used some years ago but still can be found.
Take this part only, and leave those little plastic extensions, used to put it better.
Paste with a drop of CA glue inside the clip solarforce.
Now the plastic is in contact with the tube and the wear is smaller.
The clip is harder to loosen, can be an advantage or a disadvantage
alfreddajero
alfreddajero's picture
Last seen: 7 months 2 weeks ago
Cool, where can one get one.......
With Darkness, there will always be Light.
CheapThrills
CheapThrills's picture
Last seen: 1 month 1 week ago
Theres a ton of plastic rivets and push rivets at eBay but I´m yet to discover the right word for searching these...
ri chevy
you could probably just cut up a small piece from a clear plastic soda bottle and glue that in place.
Halo...
Halo...'s picture
Last seen: 4 years 8 months ago
There is always clear heat shrink tubing as well.
The plastic rivet is cooler tho. Looks professional.
alfreddajero
Yes it does.....i have a lot of heatshrink but it throws the beauty off, especially since mine are yellow and red lol.
Chicago X
Chicago X's picture
Last seen: 7 years 10 months ago
I have used black heatshrink tubing with good results, but this is a much better-looking approach.
Please let us know if you can find the exact item.  I would like to do this to a few of mine.
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
old4570
Last seen: 1 week 4 days ago
Excellent tip !   .....
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
