If you’ve received the Micro-Textured lens and have tried it, please post any comments you have about it.
I’m trying to decide it this will replace my AR lens for the P60 drop ins or just have it as another option (opinions?). All of my personal P60s now have the MT lens it’s the only lens for me.
I’ve also tried it in a C8 and I really like the results.
I’ve had a few more requests for the lenses, so if you’re interested, Sunday 11/20 will be the last day to request them through BLF. After that, they will be available on my website, but only as an option with a flashlight or drop in.
I have notices in a SMO P60 with a Nichia led that this is like a night and day difference. I have also installed on in a SMO S2+ with and XP-L HI and OMG it makes the beam so perfect! I am going to have to order more of these.
This would be a great Lens for the Q8 Flashlight. At the moment i can not find the dimensions. But if the price is right there is much potetial for a big sale (~ 800 people are on the interest list). Because at the moment they are using a plain glass lend without any coating.
I am not sure about that!
A ~30mm lens cost 4,5$. I do not have the exact dimensions but it has to be somthing about ~47mm± a few mm.
Sure it will not be for 5$ but I’m pretty sure it will not cost 40$.
And if its in the 10-15$ range i would be definitely interested.
Hope that i can get the exact dimensions soon.
For the Q8, could someone provide the lens dimensions. The only thickness I currently have the Micro-Textured AR material in is 1.5mm, but this thickness may be suitable for cutting a few for evaluation in the Q8.
(I have a few sheets of the MicroTextured-AR 1.5mm coated but uncut.)
The Q8 probably uses a 2mm lens… I will be getting a quote for a few sheets of the 2mm material AR coated an cut to C8 size.
Does the Q8 need the MT-AR lens to clean up the beam or does it just need an AR lens? The plain AR will be easier and less expensive.
The only existing Q8 prototype has a lens size of 55.1 mm x 2.81 mm, but of course doesn't have to be an exact size replacement. No guarantee the eventual production unit will have the same lens size. We requested a width of 2.25 mm but it didn't happen.
I was interested in the Micro-Texture to smoth out the beam from the 4 LED´s.
The AR coating would be a nice thing to have but for me the Micro-Texture is far more interesting.
But the final price will tell if it is something worth to consider
