Whooahhh…just looked at my spare driver from Simon. I’ve done simple mods before, BUT …now holding the driver in my hand and seeing how tiny these things are I don’t think I’m capable. Not with my existing iron and steadiness of nerves in my hand/fingers. Mannnnnnnnnnnn
Anyways……
So , there are 2 R082’s on the board. Do you solder the R100 over the terminals of both R082’s or just one of the R082’s?
You might need to buy a new tip that’s narrow and pointy if your existing one is too rounded. Have good lighting, a clean work space and a magnifying glass. I’ve got a thing called a “helping hand” that can hold the driver and a magnifying glass right over it. Then rig up a good light to shine on it. Use some very pointy tweezers to position and hold it down. If your iron is hot and clean with a tiny bit of solder you should be able to just touch one end for a second and get it done.
There are actually tutorials online for soldering tiny things. Check those out. You can even practice on an old circuit board you have laying around. It’s not that hard.
I tried a resistor mod on my L6 as well. I used a R091 out of another driver I don’t need anymore. I couldn’t really notice a difference to my original other L6. I tried different batteries but not a real difference. I bridged the resistors with a few cm of 22AWG wire. The light didn’t work. It just flashed one time for a tiny bit of a second after clicking the tailcap switch. I have the “silver” version of the light.
Adding the R091 should give you 7.25 A if all spring bypasses are okay. 4690 lm vs. 3800 lm stock should be noticable but difficult so see without direct comparison. Better measure it.
The 22AWG could have triggered the overcurrent protection of your protected batteries.
I just found an old circuit board with some 1206 R100’s on it. Is there an easy way to measure, calculate or otherwise determine if these are rated at 1/4 watt?
Not that I know of. I’ve seen that size in both 1/4 and 1/8 watt. I’d try it and see. I guess the worst thing that could happen is it’s not 1/4 watt and might fry itself and your back to stock.
Hi ,please give me a link to this FET driver , and can this driver be used for two XHP70 in paralel and each one to run on 10-12a.
I want to make a monster.
Dales FET driver is pretty custom, you can’t just buy it. It’s a MTN 17mm driver piggybacked on a bigger board and uses TK’s ramping firmware.
If you wanna a good FET, look at Lexels thread about him making some Texas Avenger drivers. I just got one for my L6 and it pulls 12 amps. It also has Narsil ramping firmware in it which is sweet. Cost me about $25 total. Hurry, though as each small batch gets sold out. I just ordered a second one. Lol
Another option is the FET driver at MTN Electronics for the L6. It’s cheaper, but does not having ramping firmware, only multiple levels. Actually, Narsil let’s you choose ramping or levels which is another great feature.
He is using the Texas Avenger driver I am pretty sure. It will handle whatever your batteries can provide assuming that the input voltage and output voltage are close.
Random question but hopefully someone knows the answer: I have the non-e switch version of the KD FX-30 driver, and I want to put it in a light with an e-switch. Is it possible to solder an e-switch to the board while I’m resistor stacking and have it work that way? Or will the firmware make that impossible? I have the driver and a spare e-switch, but I’m guessing the firmware won’t let this go together? Hope I’m wrong, there are still two pads on it for an e-switch, but I don’t have the ability to re-flash it if that’s a requirement to make it all work. Thanks a ton.
