$0.14 each and $1.20 for 10. I wouldn't call that very cheap. 1206 are $0.24 for 10.
Just checked it and the 1206 should work fine, or 1210.
I bought one of these as a fairly random impulse, not necessarily greatest or cheapest:
It's got the d2pak or something similar FET and diode. Those are 470uF electrolytic input and output caps, however the output is shorted with some sizable SMD cap, most likely ceramic. That seems to be a common practice power through output transients while maintaining low ESR of the ceramic.
The input cap is shorted by an "M4" diode (you can see it on the bottom of the board). That's interesting. It seems to be rated for 1A and basically shorts reverse polarity input to ground. However I don't how that wouldn't fry in a couple of ms, so I'm not sure it really serves as reverse polarity protection.
The whole thing is 26mm by 60mm including pots, terminals, and the giant caps, however it's a two sided board. Of course there's no mcu. Or I don't think so. There is an IC, that I'm fairly certain is a buck controller. I've tested it so far on a wire short, and it was horribly inneficient, (like 10% efficient) but that was waay into DCM and way below the diode Vf. The regulation control got very wonky down there too. I also tested it at 2A output to an XM-L2. It was 87% efficient, for input anywhere from about 4.5V up to 17V, and seemed to control very reasonably. The input power really didn't change. So it seems to work ok for that.
For the wire short I pushed it up to 10A for awhile and it handled it pretty well inspite of that huge inefficiency. I didn't have a chance to see how long it could keep it up or really measure how hot it got het. Of course that wasn't much actual power, I think 7W total power as recall, about 0.7 output. I don't have any good way to test it at high power at the moment. On the other hand most of the losses depend more on current than power.
It would kind of be interesting to see what other cheap similar sized bucks are capable of. Of course as for cheap, they have the advantage of mass production. I'm kind attracted to some of the simple analog controls and self oscillating designs just for the simplicity of it, but it's not clear how much cheaper any of it really is. You still need a good inductor, good fet, good diode, and for anything this big, of course the big board. There are some voltage regulated designs that drop the sense resistors.
It's hard to see how to make anything cheap on a one off DIY scale though. Of course the board is nearly half the price for one-off. It can be worth thinking about what it costs to make 100 though and maybe in some design MTN would do it eventually so it's not only one-off costs that matter. Boards get 3x cheaper automatically when you build more than three at a time, and many of the components get cheaper if you build 10. It might be possible to build 10 for the price of three. This is not necessarily meant to be correlated to my thoughts about simpler designs.
Anyway, I'll update the jumpers in the cart shortly.
Hmm.. I suppose with protected cells or a fused input supply, that input-shorting diode, rated to 30A for a couple of ms, would likely give enough time for the protection to kick in, and may prevent frying the IC in that case.
I have a few buck converters like that. They usually have ripple and are not that great but work fine for what we do with an LED. How they are able to do that so simply is what I don’t know. Same for flashlight drivers, not sure how all these buck drivers you see work so well and are so cheap. I don’t see much we could really cut costs on except the inductor.
Looks like the jumpers are going to get more expensive, not cheaper. Those Yaego's and many others are surprising only rated as <50mohm and a couple of amps. Our sense resistors would make better high current jumpers than those. I found some vishays 1210 or 1218 at 12 or 20A rated, < 4mOhm:
http://www.vishay.com/docs/20043/crcwhpe3.pdf
But those are going to be about $0.41 a piece. Personally, I'd probably just strip some 14awg solid wire. But I can put some Vishay's in the cart. I'll look a little more for something cheaper, but that's probably about it.
Actually the 1218s are $0.59 each.
I think I'd go with them though as a stock smd suggestion. I need to know if that 0.18 width will interfere with the batteries though. The 1210's have the same resistance rating, probably just don't take heat quite as well.
Wow, the 2512's are rated for about 4kW ... for a microsecond. Yeah, at 4mohm that's a thousand amps. Good to know, just have to set that turbo timer a bit short.
You’ll need some VERY high drain batteries too!
I personally would also just use a solder bridge / wire myself. I have not forgot about this, just got another project I am working on right now that is a bit more pressing (got to figure out a driver for the BLF GT).
It's not bothering me at least. I'm not ordering anything for it until I have a Q8 in the mail.
I hooked that cheap buck between 4S LiIon and a 12V halogen. Put about 40W through it. Roughly 95% efficient, scratch that, battery was falling off during measurement, just remeasured with fresh battery, getting 100% within the precision I can measure, probably limited to about a percent by clamp meter current accuracy, anyway, it's darn efficient, but that's basically direct drive. It remained very cool (it's only 3A). It's an infineon FET, so that's a good sign. They're about $.50 each for 1000. They'er actually To-220's which are a bit bigger than D2paks because of their heat sink.
Anyway, this halogen is a great way to test. I've a couple of housing and higher power bulbs, could probably get up to 130 watts with two over-voltaged 50W bulbs. They can take straight 16.8V without frying for a couple of hundred hours anyway.
Which buck are you talking about? I must have missed that.
The little one from the Amazon link we discussed a few posts up. Nothing to do with flashlights really, just observations of a cheap buck. I haven't hooked it up to a scope. It's may have enormous ripple for all know. Anyway, there's no particular point to the story.
Talking to myself and off the trail, but hey... so I plugged that amazon buck into a 2s2p xm-l2 setup I just hacked together driving the buck with 16.0V bench power. That's a more realistic use probably. At 20W or 35W output it gives 94% plus or minus half a percent efficiency. Not bad, and I'll be using it. You can probably literally drive low output panasonic batteries to destructively low charge levels before losing much output with a setup like that, and with 94% driver efficiency and high capacity batteries, that seems like a bunch of constant-output runtime to me. Oh and at the battery running half the current and twice the series battery resitance mean I^2R losses in the battery are twice lower too compared to using 2S battery, again making up some for low drain batteries.
I like higher voltage, it is simply better then higher amps for most things.
No question. It's all kind of making me think expensive buck drivers are alright again. Although cheap ones and pots are also ok for some things. With these two pot bucks you can set a failsafe limit with voltage and then use current to control the light.
Those cheapo buck modules are not bad actually. The ripple can be high and they are analog but if you just want a set it and forget it option they work fine.
Or if you want to wire a remote pot.
Really, I only have two problems with anolog. You can't predict battery life if you don't know exactly what mode you're in, (true of ramping too) and it can be hard to make one-hand use knobs/dials. Buttons work without releasing your grip.
