17mm & 20/26/27mm single-sided DD/FET driver release: A17DD-SO8 / A20DD-SO8 / etc
731 posts / 0 new
vresto
vresto's picture
Last seen: 1 day 14 hours ago
question-if i use this driver in triple xpl for one 18650,it has still the same characterics? mode groups,memory on/off?
EDC-Mateminco MT04 XHP50 nw,Sofirn If-25A cw,Sofirn SCO PRO nw
Headlamp-Thrunite TH30 nw
Andrew2007
Andrew2007's picture
Last seen: 4 years 7 months ago
Yes, obviously the xpl’s need to be connected in parallel. Smile
giorgoskok
giorgoskok's picture
Last seen: 1 month 11 hours ago
Hello everyone .
Can anyone help me get this driver zener modded ?
I mean , what R2 , Rd (resistor in current diode space) and zener should i order , and also , is an already modified firmware available (with the right lvp) ?
I want a simple firmware , 3-5 modes , nothing more .
Tom E
Tom E's picture
Last seen: 5 min 22 sec ago
The driver this thread is based on went through many revs - not even sure what the latest looks like.
This is a similar driver with a zener mod. Notice the 200 ohm resistor in place of the D1, and the zener in it's proper pad, to the right of the MCU. I used this in a XHP70 mod to a Roche LS01.
giorgoskok
Some members here told me to use R1 19.1k , R2 2.2k , 200ohm resistor on the place of D1 , and a zener .
What firmware could i use ?
edit : i use v044 boards
Tom E
Tom E's picture
That's about the proper ratio, as long as the ratio of R1:R2 is bout the same as 36K:4.7K, all depends what resistor values you have or can get. If you stay with these ratios, you should be able to use standard 13A firmware with LVP protection, because that ratio specifically match's well for 2 cells in series.
Oopsie! Forgot, a "2000" labeled resistor is actually 200 ohms,
giorgoskok
thank you very much Tom for your help!!
I have already the resistors , but i can’t find a source for the zener diodes .
Which firmware should i use exactly?
Edit : Any other zener except BZX384-B4V3,115 ?
Tom E
Tom E's picture
Ahhh, for firmware, I haven't been doing much with 13A's as of late. I'm at work, so don't have access to all my firmware verisons. I got my own spins on 13A, 25, and 85 firmware, but it's all based on STAR pretty much, so I'd looke at the STAR versions, but like I said, bout anything would do.
This is the standard zener we use:
http://www.mtnelectronics.com/index.php?route=product/product&path=25_104&product_id=316
Richard probably buys them at Mouser, think I also did recently. I think MtnE and Mouser are ruled out for you cause of shipping costs, etc.
giorgoskok
Mtn has lower shipping Silly
Thanks for your help
ToyKeeper
ToyKeeper's picture
Last seen: 2 weeks 1 day ago
Almost any firmware should work, but you’ll still need to calibrate the voltage yourself. And from what I hear, LVP may be a bit tricky on this setup. There are reports of voltage sag so severe that turbo mode triggers LVP even on full cells.
giorgoskok
Tk what firmware should i use?
Starry-offtime?
ToyKeeper
ToyKeeper's picture
Use whichever one has an interface you like. Smile
I may be a little biased about which specific project. However, it probably depends on what kind of light you’re using and what you want to do with it. For example, blf-a6 is nice for EDC lights but not as nice on throwers, because it starts on low. Meanwhile, STAR_off_time has an option to start on high instead, so it might be better for throwers. Both offer mode memory if you want it.
degarb
Last seen: 9 months 2 weeks ago
Okay. . I would like one without the fet or anything above 380 ma. . The settings need be 100% of one amc7135 (not 2 or more) , 75%,50%,25%,10%,5% pwm based on max 380ma. Is this possible? . Or how much is possible?
Most drivers are wow factor designed, and such are lacking for usefulness and efficient 10 plus hour runtime from a single 18650.
Runtime=Usefulness
RMM
RMM's picture
degarb wrote:
Okay. . I would like one without the fet or anything above 380 ma. . The settings need be 100% of one amc7135 (not 2 or more) , 75%,50%,25%,10%,5% pwm based on max 380ma. Is this possible? . Or how much is possible? Most drivers are wow factor designed, and such are lacking for usefulness and efficient 10 plus hour runtime from a single 18650.
Why not just use an ak-47-a and remove some chips?  Cheaper and easier.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
Tom E
Tom E's picture
Of course it's possible, pretty simple for implementing in any FET+1 firmware version out there. Of course a fully populated FET+1 driver can do all that, plus have a turbo mode using a FET and there's no difference whatsoever in runtime per mode, for the modes you specified. You would just get the best of both worlds - that's why the FET+1 drivers were created to begin with - great run times on the low modes using just the 7135, super output when using the FET.
RMM
RMM's picture
Tom, degarb is an oddity.  He has e-mailed me several times and he has no interest in anything more than the power stated, period.
giorgoskok
Easiest solution is what Richard suggested , get an ak-47 and leave only one 7135 .
Other solution , take a fet+1 driver , remove fet , modify firmware .
Tom E
Tom E's picture
Ahh, not a problem. Posting on this thread I would assume he wanted to buy one of these boards or already had one. Lots of options...
Anyway, good to see you posting smile
On a 3500 mAh cell on a 7135 you would get about 10 hours of ~150 lumens or so, on a typical XM-L2 or XPL. Think I saw ~180 lumens on triple or quad LED setups.
MILSPEC
Last seen: 3 weeks 2 hours ago
Does anybody know which Fet+1×7135 driver on Oshpark is the “up to date” variant? There are so many revisions and I am a bit confused which one to order.
I am looking for a 17mm Fet+1 driver for 1S use that works with some of the firmware in Toykeeper’s repository.
Thank you!
pilotdog68
pilotdog68's picture
Which firmware are you wanting to use?
MILSPEC
I am flexible on the firmware. Guess any FW with 2 channels/pins and compatibility with this driver would be fine? I will only have 1 emitter and need very few modes. The Attiny13 and 25 are here with me, can use either.
edit:
This is a useful thread but I don’t think it is up to date? http://budgetlightforum.com/node/29562
RMM
RMM's picture
I recommended the Nanjg because it can be had pre-assembled for less than the parts alone would cost you to build one up in smaller quantities and if all you want is a single 7135, then there is no reason really to go through the trouble of building one.
chouster
Also, why would you want a 2 channel firmware/driver if you’re using one emitter at maximum 380mA current. Makes no sense.
EDIT: If you’d like to build your own driver, than the HQ4S from HarleQuin is a very nice one. There’s also a dual channel version of it, if you’d insist on that for what reason whatsoever.
pilotdog68
I would say try one of TexasAce’s Avenger driver boards. They are the most “up to date”. They are triple-channel, but could be used as dual channel by just leaving the extra parts off and a couple minor adjustments to the firmware.
They don’t work with all firmwares, but TK’s Bistro and TomE’s Narsil work with it.
Otherwise I think all of the more recent wight boards are mostly the same, just with minor tweaks. Just go with the highest version number. You can click on one of wights boards in oshpark, and use that to see all of the ones (and most recent ones) that he has posted.
MILSPEC
Thank you, pilotdog!
Will compare TexasAce’s Avenger driver and wight’s boards and pick the easiest one to assemble/reflow/with the fewest parts.
pilotdog68
Fewest parts/easiest to reflow will definitely not be the Avenger. It has extra little parts that give extra stability.
wight’s boards or my own DoubleDown would be the easiest. Either will work fine with an Attiny13a, but you really want the Avenger if you are using the Attiny25
chouster
Take a look at my edit above… I’d recommend HQ4S and BLF-A6 firmware in single channel config with Battcheck _VpT…
pilotdog68
two different people asking questions in the thread. I’m replying to MILSPEC, who does want the FET
chouster
Sorry, PD and MILSPEC. Totally mixed things up… Facepalm So my comments were adressed to degarb, I guess. Again sorry.
Smiglo
Last seen: 4 years 8 months ago
I have this driver A17DD-L FET+1 Driver from banggood paired with xml2 u3 and with Keeppower 18650 3500mAh, Panasonic NCR18650B 3400mA.
With fully charged keeppower battery on tail cap I measured only 3.5A, and with panasonic only 3A in turbo mode.
Is this normal, whether it is worth to change battery to get more amps?
