Ahahaha! Idiocracy… a documentary!! I’ve been saying the same thing for years. I call it the “idiocracy effect.”
I work on a plane and have to make an announcement on each leg regarding the Samsung Galaxy Note 7. Even though they have been recalled, and the replacements have been recalled, and now they are banned by the FAA from every flight in the U.S. Some people are still using them and sneaking them onto planes.
Li-Ion battery fire/explosion onboard a sealed pressure vessel probably won’t end well. You can’t just pull over and park. This is the idiocracy effect in action.
And yes, because of the “idiocracy effect” now prevelent in our society, perhaps PCB fuses are a good idea.
Cells, capacity, series, power and availability…. what do we mostly use, a 3000mAh 18650? Maybe a 3400mAh? But we’re talking about using 4S, then 2 parallel, right? What about the big 32650? It’s in excess of 6000mAh, delivers whatever power any other cell is capable of and then some (yes, it’ll outperform the 30Q or LG HE4) And 4 inline series would make (does make) a great handle for a honker.
The beastly Trustfire TR-J20 uses 3 of these, I’ve helped build one that utilized 4, and the results can be staggering. It would have the full capacity of 8 18650’s, with the expense of 4 good cells. Something to think about, I’m sure most would want to veto based purely on having to buy those 4 new cells, but doesn’t a light like this warrant a set of matched dedicated cells?
Edit: Just so you know they’re serious contenders, my TR-J20 uses 3 TrustFire 32650’s and puts out 15,000 lumens. Richard built one that needed 4 of the big cells, I built him an extension for the TR-J20 he modified, and it made a whopping 34,000 lumens! These cells are awesome!
4 x 26650 inline!?
Comedy. The tube will be too thin. And the proportiins would be horrid.
26650 can be used in a 2x2 configuration. With no carriers i think.
As I mentioned up a few posts but you keenly overlooked, all that needs to be done is bore out a fat tube to fit 26650s, and have thick tube walls. The weight of the thicker walls (by rough calculation) will be minimally more than the weight of the 2x carriers and 4x extra cells that will be housed in the 18650 configuration.
Or if weight is truly an issue, bore more aluminum out, and make a plastic sleeve.
well, 4*26550 is quite big, but how’s about 2s 26550, it’s thick and long enough to not be an idiot looking
and today many people have access to 26550 cell, if you want to make a flashlight for everyone, you need to stick with AA ni-mh battery
but, the vote has decided 8*18650, so, nothing can do now
A changeable Tube would be better, for those who dont have and hate dummy cell
I can assure you there was no vote. 8 was always the final spec. I’m only discussing 4x 26650s to put ideas out there even though we all know the GT team will ultimately decide what goes in to the light. And that in itself is not a bad thing, we can’t keep debating for months on end we will never get anywhere with it. I think the hold up now is reflector sourcing
We can do the vote but I assuming that 95% will chose 8×18650 option!
So can we stop discussing about that.
18650 are most available battery on the market and at the moment you can buy 4 Panasonic 3400 mAh on GB sale for 11$. Also what charger would accept 4 26650, or 32650 at same time? With 4S2P we have that option to use only 4 cell’s and have a spare for the backup…
If it is a weight balance only issue,so as to put 4 only 18650s,it could be possible to make the battery tube from ss,which is way heavier than aluminum,so there would be a better balance.I have a Astrolux ss and I know.
I think it’s high time to stop discussing all kinds of options, variations, possibilities and whatnot.
*New project
Aim:
BIG thrower that surpasses the latest super throwers like the TN42*
- easy build to keep cost down
- user friendly
simple design so that as much as possible will want to buy & use it
I propose to stick with the long tube, 8 cell configuration. Preferably like so that it can be used with just 4 cells, 18650 only.
EVERRYONE has 18650 cells and the chargers to go with them.
Let’s not make this an endless discussion, however interesting, and keep the end goal in mind.
. BIG thrower that surpasses the latest super throwers like the TN42
Grtz
Nico
Will update the list late
No 4-8 18650 in two parallel carriers that need 4 cells wired in series it is.
(I am eyeballing some old notebooks and besides with 2,5A at the LED any 18650 will do and I saw the 3400 Panasonic’s for $11,11 at Gearbest recently so even buying new cells would not set somebody back that much)
With SRK/Q8 compability at the head side and a 46mm driver people should be able to mid how there heart desires.
I agree that with this mass and sine finning at led level and higher up to avoid rolling away the GT should provide ample cooling even for future IUP140 (Insane Ultimate Performance, you know the LED series Cree will bring above the Extreme High Performance )
Using 32650’s was considered early on but rejected due to the fact most people do not own any 32650’s. Plus the tube to reflector proportion would be even worse. The 4x 18650 was the biggest we could go and still be hand held to improve the visual appeal.
I have never been a fan of the massive heads with toothpicks for bodies myself.
Just to throw some Idea’s (these idea’s where already suggested I think), 4 26650’s in a 2 row 2s side bij side config is not really a bad idea.
You’ll have a carrier with on the left side 2 26650’s in series and on the right side the same, together they form a 4s setup.
Because you use a carrier the tube doesn’t have to be that thick, however using 26650’s in this config will increase the diameter by 8mm. (measured at the batteries)
Or if you use 18650’s instead of 26650’s in the same config the diameter will decrease by 8 mm.
The balance will be slightly worse. 5ar should be able to see where the Center of gravity is in his design software.
I would still like 18650 over the other size due to general availability thanks to all the Vaping stores that have recently started to pop up everywhere, I could get some almost anywhere in an emergency, 32650 or 26650 not so much, would consider those bigger sizes if the design changed to the box form, but I like this traditional design better for this project, maybe the box design with bigger batteries for a XHP70 with an even bigger reflector in the future… :sunglasses:
This was another big factor, plus like was said, since this light will have such a low current draw due to being 4S any 18650 will work. So laptop pulls would be perfectly happy in this light making the cells themselves quite cheap.
4x 18650 in a 2x2 configuranion is good. It can be made from a tube, and plastic insert. Bypassing the need of a carriers and bringing the price down. Excellent idea. Or even better, it can be made for 4x26650 with one plastic insert, and for 4x18650 with another plastic insert. Same tube, same everything just a piece of plastic. No need of complicated carriers, no danger of mixed cells. Any 4 cells will do the job at 3.5A drain.
How? lengthwise wont fit. The length of the tube is still 2 cells.
Or do you mean, make at wide enough for the 26650 setup but use a plastic insert to bring it down to a 18650 setup?
Better Idea, using a carrier like this:
Can use both 26650’s as 18650’s.
A carrier is easier or necessary to make contact with the driver contacts (2 rings).
Another picture, orange are the 26650’s red are the 18650’s.
