How do you think, is here any need in stock design p60 pills in copper? Some drop-in manufactures using brass pill with xhp50, xhp70, driving up to 20W to the led. Not good at all.
X6 SS version spacers and U11 kits will be ready in a week in work.
Next to produce:
- P60 copper pill (for single led and stock reflector, surefire-compatible, with driver retaining)
Thinking about:
- more ZY-T08 pills? Anybody interested?
- regular noctigon and tpad pcbs in stock?
- more Cute-3 optics in stock? Could be available with mass interest only.
- more specific (rare) optics in stock?
- tir+pcb decision for SRK clones? Could be available with mass interest only.
illuminated tailcap decision (pcb with soldered leds) X6 style tail? Could be available with mass (very mass) interest only.
Also, thinking about offering small pieces of bare Al/Cu rod for cheap price.
Waiting suggests about new mechanical parts.
Hi. I made my first order here a while ago. Shipping was quick and took maybe six working days.
The items were well protected, some of the best packaging I’ve seen for a small parcel. http://i.imgur.com/3AII11X.jpg http://i.imgur.com/yN5Y5dk.jpg
Sadly I will have to wait much longer for my other parts to arrive from China and Hong Kong, so I can’t comment on how they work right now, but I’ll make sure to do an update later.
Thanks to Kiriba-ru for providing this service for people who do not wish to order from USA.
I saw your problem with PayPal, did you find any alternative or solution yet? While I don’t know much about AliPay, it does seem like a very similar alternative and I would expect many here to already use that service.
Received my M1 Quad kits, S2+ kits and X5 kits, in perfect shape, a couple of the plastic containers took a beating but everything survived! :+1: Great Job and thanks, kiriba-ru!!
I can change plastic boxes in pte bags to corrugated fiberboard boxes, but they weight 60gr more, so this is reasonable for big parcels over 250gr only. Usually such heavy orders cost more than small parcel limit, so I use this type of package rarely.
I mean what quantity do you need.
All parts are made on manual lathe so abilities are restricted. For example I dont want to make driver retaining version of convoy single pills.
Prices of S2 pills can be similar to S2+ pills - $16 triple driver retaining, $12 single driver solder/press fit.
the M2 Quad kit came in some days ago. Perfect packaging. The spacer fits into the Convoy M2 (from BG) perfectly. Light is not finished yet because the driver is still in the mail.
If first post is saying that item is in stock, this means that it is so with 99% probability.
I can post current stocks photo every week if this is more presentable.
I received a M1 quad kit long time ago but haven’t started my build yet due to a small design flaw, the MCPCB “pocket” is 20mm and because the optic is larger there is no room for it to sit its legs. I think it can be an easy fix using a dremel and cutting disk attachment but I lend mine to a friend, so I’ll probably start the build some time later.
