HaikeLite MT03 & MT07 Group-buy Closed
L6 and MT07 both have similar performance.
Gearbest currently have L6 silver version for $50 so price is your main focus then get L6 :slight_smile:
Interest two depend price
Based on Tom’s measurements the MT07 throws twice as far and has about 35% higher output.
Sorry, I thought the 17000 lumen was to be a new M43 version. I really wanted to get an M43a long time ago.
Please send me a unglued Version of the MT03 for modding. I hope it`s not to late, please give me a short message if it`s possible .
Thx HaikeLite
Robert
I havent check Tom’s review in detail but I believe L6 can be modded with resister for higher current + dedome led and smooth reflector can match the performance of MT07
Yeah it can be modded to match, but a lot of people don’t want to or can’t mod a flashlight. And of course there is the possibility of modding the MT07 for even more output.
Payment send for:
1pcs. MT03 CW 4S no glue
1pcs. MT07 CW 4S no glue
Ah I see :-). The 17000 lumen monster is really a new light. I can only recommend the M43; it’s available again as a matter of fact. Cheers.
Yes, but since the MT07 is already driven harder than the L6 there is less room for modding. With both driven to the max (DD) the output should be the same.
interested depend on the price
I already modded the MT07 up, but moderately. Probably will do it little by little.
Resistor mod (mild), think added an R075, and sanded down the centering ring base only slightly to ensure flattening (0.92mm to 0.90mm) and files the top down so total height went from 1.95 mm to 1.61 mm. Results:
On fresh GA's:
lumens: 5,678 @start, 5,318 @30 secs
throw: 148 kcd (taken at 5m)
Next mod is to replace LED with a P2 1C, possibly sliced, not sure yet. The sanding down of the LED centering piece increased throw from 140 kcd to 148 kcd, so I'm pretty confident it helps both throw and lumens. The idea is to remove possible blockage of photons coming out at steep angles from the LED. It seems to work on pretty much any light that has that type of centering piece, where the lip protrudes upward, even though it's below flush with the reflector.
Might be true for lumens but not throw, since the MT07 reflector is wider than the L6 and a good design for throw, just like the L6. The L6 SMO though will be better then the L6 OP, dunno if it can beat the OP MT07 though. I have an L6 SMO ordered, on the way.
Hello,
HaikeLite MT03 Devourer 4S CW + 4x18650 batteries
Payment sent
Thanks
Hello,
I’m interested in both lights 4S NW, also unglued along with Sanyo GA batteries at $5 ea.
Please PM prices for all, Thank You
See Bluzie's new post of outdoor shots of the MT03 and MT07 here: https://budgetlightforum.com/t/-/37084/53
I am in for both 4S lights, the O3 & 07, in NW, and Please UN-Glued…
Will have PP sent tonight
Thank You very much HaikeLite…!!
PayPal Sent for both lights, Please contact me if you need anything like numbers, Thanks Again
Is it still possible to add 8 Sanyo GA batteries to my order?
I’ve sent the PP for lights and thought I had the correct batteries but don’t and your price is best.
Thank You
I am in. MT07, CW, 4S, no glue. PayPal payment sent. Thank you.
