D.I.Y. Illuminated tailcap
I don’t expect you to read this whole thread, but I’d say please read the OP, and maybe the most recent two pages of comments. Even if you don’t, please ask any questions you have. You’ll normally get an answer more quickly here.
Random clicking with freshly made red lightswitch
wait, what, why the bleeder resistor is 500-800ohm, it should be some K ohm, so that the led in tail cap don’t need another resistor( i disassemble 1 tail cap, and it has another resisor to limit the current)
This is not my design and I don’t claim to fully understand it all, but I don’t think that’s how it works. You really need the two different levels of resistance — a low resistance path so that the OTC can bleed off quickly preserving the timing of the mcu, plus a higher resistance path to dim the tailcap lights sufficiently.
This is my design but still don’t claim to understand it!
Mrheosuper if you’ve got an idea, try it! If it works and makes this better let us all know.
Well, i will, just right after i receive my new solder
Success! (I may be a bit giddy at the moment)
Finally got around to trying this again, now that my new soldering iron came in. Overall, it went pretty smoothly. But it could have went a lot smoother if I had read more carefully.
Target: Convoy S2 with a nanjg105d 2.8A driver
Switchboard: stock Convoy
Illum. tailcap board: Rev5.3 (top)
LEDs: 6x blue 0805
Tailcap resistor: single 10K ohm (bridged the two channels)
Bleeder resistor: 750 ohm
Measured draw: 0.1 mA (my multimeter only reads tenths)
One difficulty: the nanjg105d didn’t have a good place (that I could see) to solder the bleeder to. I ended up soldering one side to the spring and the other side to the outside ring via a jumper wire.
Other difficulty: instead of starting out with a 10K ohm tailcap resistor, I used a 10 ohm. It was obviously too bright and the driver wasn’t working right, so I tried a 30 ohm. And then a 100 ohm. And then I finally re-read some posts and realized I should have been using a 10*K* ohm resistor. Once I put that in place, everything started working like it should. I might even try a 20K ohm next time, but I didn’t feel like opening everything back up on this one.
One other thing: the opening in the ring wasn’t quite big enough to seat onto the switch properly. So I lightly filed the switch casing. I could’ve opened the ring’s hole a bit, but the clearances seemed tight.
Thank you PD and everyone that has contributed to this thread!
nice work :+1:
I changed the tailcap lighting in my S2+ shorty and the switch boot. Earlier it has clear switch boot and green leds under it. Now it has a light blue rubber boot from Simon’s aliexpress shop and white leds under it on PD68 V5.1 Lighted tail switch board. Now it has the nice light blue color what I wanted.
Beautiful. I’ve found a boot in the same color as the leds I’m using to be the best combination
The fun thing with this blue boot is that you give it plenty light it will glow in the dark in green color :slight_smile: but with small amount of white light under it I get this. Only a small greenish color in center but you can not see it on this pic.
I did not get the TG06 Tailcap working without a bleeder…what could be the problem? Tailcap works well in some other lights. Where I have to add the bleeder on the TG06 driver? Thanks!
I keep seeing folks posting that they’re building some of these without bleeder resistors. I don’t know how they’re doing it. I haven’t gotten one working without a bleeder yet. Every single one I do winds up with a bleeder in order to get the driver/firmware to act right.
But I haven’t done one of those Thorfires though, so I can’t help specifically with that.
PS: Those blended colors look great in there. I really should branch out and stop doing all the same colors :slight_smile:
Yes. The colors looks damn good in this combination. Where did you place the bleeder and which value did you choose?
Post 1366.
EDIT: That’s an 0805 resistor.
Thanks! Did you test it without a bleeder first?
Are these 0805 size? I ordered a bunch of leds from ebay, and they seem awfully small.
http://www.ebay.com/itm/272173424833?\_trksid=p2060353.m2749.l2649&var=570984529339&ssPageName=STRK%3AMEBIDX%3AIT
I placed one right above the led on a prebuilt illuminated tailcap I had so you can see just how small these suckers are. They just barely span over to each pad.
Those look more like 0603
Ok, thanks for verifying. I was thinking there was no way I was going to be able to work with these. I mean the slightest static or movement from my fingers makes it go shooting across the table never to be seen again. This sucks…waited several weeks to get those so I could finish my giveaway build. I’ll try ordering from a trusted vendor this time.
If I did I don’t remember doing so.
