Man that second one is is sweet looking, I like how the battery tube flow’s into the head, and I think it would look better with the clean head of the third one, or with out the notches. Like the full diameter tube with out the flats also, Perfect for a tail cap switch only, which wouldn’t bother me either! :+1:
The blue parabola is the accurate shape, it starts at the bottom with a 45° angle.
But this explains the difference in basic shape of our designs.
I use the blue one. It’s also a little deeper and has a brim on the big end.
Wow, nice detailing Jerommel
I really like the design
But I feel like it is more suiting a smaller light because those top “blocks” and fins laying “on top of the head” make this a much heavier light.
That depends on the shape of the inside of the head.
In all a couple of ‘blocks’ on it weighs less than a thick wall with some notches taken out.
So it’s probably lighter actually.
When looking at the renders I realize, even more than before, that this light, not even sporting a handle, will be VERY diffucult to handle (as opposed to a box design with a handle).
So I’m out, please scratch me from the interest list.
Here are some cold hard reflector facts illustrated:
Based on what i go by in my images, maybe it should be a little deeper still, because as you can see the actual amount of light that is focussed by the reflector is quite small.
But that’s the case with all regular reflector lights…
The best bit is just spilled…
He told me he uses cinema 4D.
I do use solidworks for my designs.
I’ve taken a look at cinema 4D and I just cant understand how he can make this in cinema 4d. So 5ar you sir, you are very good! :+1:
Serious, do you use that program professionally?
That’s why he said:
“I do not know which version is better but there is no need at this point to think about it because while I do not know the dimensions and shape of the reflector can not tell whether this look to stay because everything depends on the reflector. Small changes in the details affect the overall look, will be smarter when we know the details of the reflector.”
I really like the V0.5. To be honest the V0.45 from MortyDuck looks good to (with that sharp edge on the head).
Though, that last design from 5ar is by far the best! Great job thinking a little bit different. It has a very tough and rough look to it, perfect for the best thrower!
Don’t agree with you, it is all about balance, just tested it out with my 10kg axe, 5kg axe and crate for bottles that has a central handle with 4 and 9 glass bottles filled with water.
The axes hold easier because the arms hangs straighter down the body.
The weight distribution of the 5kg axe (the 10kg is top heavy since their handles are a meter long) make it balance, I can hold it for a long long time en if needed carry it over shoulder, a box is much much harder to keep at eye level.
But we have had this discussion before so no point in repeating it over and over, OP updated and you are replaced on the list.
A parabolic reflector has a given shape and proportions.
The one he uses to design a light around is way off.
The LED is not in the focal point, he’s using an incan light reflector model.
Iḿ sorry, but just look at the picture.
Do you think i should not have pointed this out?
And as i said, it does explain the different basic shapes between his and my designs.
Lets put a 23mm-35mm floating lens in front of the led. So it will focus the die to infinity. If we can find a lens that has the required focal distance and diameter we can even attach it to the front glass. Or below it.
It will be a form of large TIR optic that forwards most of the light straight forward.
We can calculate which part of the led light is wasted in spill and project that forward. And how big of a diameter lens we can put on a given focal length.
Balancing definitely helps, but keeping it compact helps even more.
Just imagine controlling a 30cm (1 foot) long pole weiging 1kg (2 pounds) versus a 2 meter long pole of the same weight. The longer pole requires a lot more force and energy to control when swinging around.
Let’s just agree to disagree; no hard feelings from my side, but this project (the way it’s turning out) just isn’t for me.
