If you want performance i would say recoil reflector set up.
Problem though, is finding a decent and affordable 5 inch reflector that can take at least 120° from the LED.
So basically it looks like from the thermal simulations that the current design is just enough to keep an XHP35 cool enough to not burn you. Anything more and it will get too hot and need to step down. So we for sure need to keep cooling in mind as night time temps here in Texas can be easily 90f+ which would allow it to get even hotter.
Good info!
As far as the reflector goes, 5AR has not had a design to work with since we do not know what we will be using yet. That said I really like the shape he has come up with anyways, the strong taper to the head just doesn’t do it for me, looks a bit silly IMO.
There will naturally be some redesigns once we find a reflector.
And remember, this simulation is done with a convection coefficient of 30 W/(m^2.k), which is natural convection (almost no moving air/no forced cooling). If you would walk outside that number will increase, and that has a big impact on the results. (increasing the number to 40W reduces the temp by ~5 degrees celcius)
Also the battery tube isn’t part of the simulation, so that increase the mass which will reduce temps slightly.
And finally you hand plays a big role in cooling a light (well only if you’r not waring gloves but in the winter the temps are low enough that it wont have problems).
So I think that the cooling is good enough. Maybe some small tweaks.
It is good enough, I am not saying any major changes but we for sure don’t want any less cooling. The extra fins in 5AR’s last design is about the most I think would be needed.
First, I’d like to point out that not all parabola’s are created equal. There is no fixed parabolic formula for flashlights, which is why 200 flashlights on my shelves all have different profiles. There is simply no such thing as perfection. It all starts going wrong when we leave the pinpoint of light at the source and spread out the die surface, that gives us multiple points of output and the parabola suffers when trying to converge the beam.
The Nitecore P30 is a nice example of being different, at approximately 43Wx40D it approaches that “square” ratio and as such it throws very well for a smallish light, illuminating out at 670M with a mere 1070 lumens from an HI. I’m not prepared to cut my TN42 reflector in half so you can see an example of a thrower’s parabola (approx 89Wx88D), nor am I willing to cut the SR-90 Intimidator’s as it too can do over a mile…. and at 88Wx60D it’s more of a bowl than you’re describing as perfect. At any rate, having had several different lights in hand that attain a mile throw, I can tell you for a fact that each one had a different parabolic formula.
All we can really do is wait and see what reflector is available for our need and test it to see how it performs. We just might not be able to get a proper reflector that does what we want. Not without designing it first.
I have a 200mm convection lens from Edmunds, it lists for $135 for the glass lens alone.
Conclusion is if you have more cooling fins you have more square area of cooling to the surrounding air. I think if the cooling fins can be cut deeper. And they have a bigger diameter you will have the best result. Is it easy to do the thermal analysis again with wider cooling fins and in between the fins deeper milled (smaller diameter). PS I like the .5 style
The lower fins can be cut a little deeper I agree, the top fin needs more meat behind it so that the heat can easily move up there and beyond, plus for strength…
