OK, so if you have 40 eneloop AA’s and the flashlight is testing at 28 hrs “continuous” and you want 72 hrs, again continuous then you just need to replace the battery 3 times during the outage.
Which brings me to another question, do you not have daylight available during these outages that the flashlight could be/should be turned off?
If you have daylight available, you could use a solar charger to give the batteries a boost at least.
I’m not trying to be a wiseazz, just trying to understand your exact situation and needs.
One other flashlight that comes to mind with a very efficient driver is the Thorfire PF03, but it is AAA and those batteries do not pack near the punch of AA so that will probably be out.
Good luck,
there is absolutely no information on testing conditions for battery runtime
like
at 21°C
ENERGIZER L91 Ultimate Lithium
Constant Current Discharge to 0.8 Volts
Now, as I mentioned before , I did not expect the XTAR to get 80 hours runtime on a 2000 Mah eneloop , but I surely expected to get longer then 28 hours runtime. That is a big difference between the companies claimed runtime, and actual runtimes . And we now can see, the company was not claiming 80 hours runtime, on special lithium batteries, because they list nimh/alkalaine as being used . In fact, I will be shocked if this light got close to 80 hours runtime, on a new alkalaine. Maybe thats why it was marked down to $7.50.
correct….it doesnt even mention using lithium battery….therefore you conjecture that the 80 hour runtime, is accurate because the manufacturer is claiming use of lithium, is wrong. the runtimes were for nimh/alkaliane.
now can we admit you were wrong, and / or the company is being deceitful at best ?
Gestestet mit einem 750 mAh NiMH Akku und der mitgelieferten Alkali-Batterie. Die Brenndauer im 100 Lumen Modus ist akkumuliert, da die Taschenlampe nach 3 Minuten Betrieb im 100 Lumen Modus zum 25 Lumen Modus herunterschaltet, dann aber wieder neu mit 100 Lumen aktiviert werden kann.
Contact Xtar and ask em which battery they used to get the runtimes I am almost sure they did it with a Lithium primary
if you got a XP-G R5 LED inside you reach about 150 lumens/watt at low currents
so your NiMh has 1.2V and 2000mA that is 2.4Wh on paper
a Lithium primary has 1.5V and 3100mA that is 4.65Wh on paper
so 3 LED lumens x80 hours are 240Lh
so I need just a bit over 1.6Wh to power the LED the rest taked the flashlight converter
3.05Wh from the lithium primary are lost in the converter
34,4% efficiency
if you get only 30 hours out of your eneloops
that means from 2.4Wh are only 0.6Wh used to power the LED
so 1.8Wh are lost in the converter
25% eficiency
There is another thing to consider, which is how much charge is lost while sitting on the shelf. I use NiMH rechargeable batteries in many things. I recently bought a (16?) pack of eneloops and recycled some old Energizer’s.
HOWEVER, all of my devices that are strewn about the house for emergency use, have Energizer Lithium primary cells installed. In many cases I have also fashioned insulators out of old business cards that prevents each device from accidental turn on or any standby drain.
I have not run any tests to determine max run time for any of my emergency devices. I do have spare Lithium primaries and multiple methods of charging batteries from virtually any power source. I’m confident that I could easily go months without requiring new cells to generate light. But then I don’t live in a cave where I need a light on 24 hours a day either.
The eneloop , I used for this test…was fully charged at a slow rate…capacity read 2019 Mahs….it was then put right in the light, and turned on moonlight mode for testing. This eneloop, did not sit on a shelf for days or weeks, where it would lose capacity. I did this test, because I actually thought it would be incredible, if the XTAR got anywhere close to the 80 hour runtime as claimed.
you dont u8nderstand that testing conditions are not specified
and the battery type to use is as well Lithium primary but as it is not common they did not write that in the description so people dont put 3.7V batteries inside
no matter how you try to spin it, this is deceptive on the companies part.
If you bought a car, and they told you it gets 60 miles to a gallon ….but then you got it home, to find out you only get that MPG by using jet fuel…and if you use normal gas, you only get 20 MPG….and you werent told this by the manufacturer…would you feel deceived ?
