The fun thing with this blue boot is that you give it plenty light it will glow in the dark in green color but with small amount of white light under it I get this. Only a small greenish color in center but you can not see it on this pic.
I did not get the TG06 Tailcap working without a bleeder…what could be the problem? Tailcap works well in some other lights. Where I have to add the bleeder on the TG06 driver? Thanks!
I keep seeing folks posting that they’re building some of these without bleeder resistors. I don’t know how they’re doing it. I haven’t gotten one working without a bleeder yet. Every single one I do winds up with a bleeder in order to get the driver/firmware to act right.
But I haven’t done one of those Thorfires though, so I can’t help specifically with that.
PS: Those blended colors look great in there. I really should branch out and stop doing all the same colors
I placed one right above the led on a prebuilt illuminated tailcap I had so you can see just how small these suckers are. They just barely span over to each pad.
Ok, thanks for verifying. I was thinking there was no way I was going to be able to work with these. I mean the slightest static or movement from my fingers makes it go shooting across the table never to be seen again. This sucks…waited several weeks to get those so I could finish my giveaway build. I’ll try ordering from a trusted vendor this time.
This discussion made me check my TG06. I did not install a bleeder, and it works fine. The tail PCB is one of the original 2 led, 2 resistor models. 2 Green Led’s, 1 (4.9Kohm resistor), and a Home Depot plastic washer Don’t know how to check for drain, but it is barely visible in daylight.
The switch I posted in my pic a few posts above is from a BLF X6. Can you verify the LED in that is 0805 size? I had contacted the vendor on ebay and they stated they didn’t carry anything in the 0603 size. They were only .99 for 100, so I’m not too concerned, but I don’t want them to send me the same things again.
I think you got the correct size. The resistor next to the led in your picture is an 0805. My astrolux SC has the same size led that’s in your picture. I think they may be 1206. I was able to use an 0805 on the other side of the board though, with a little work. I couldn’t imagine trying to solder a 0603.
I concur with Dusty. I switched around some color/resistor values on my “stock” BLF X5/X6 lighted tailcaps and Manker definitely used something larger than 0805 originally. I put some 0805 emitters on my boards too, because its all I had. It can be done. Just remove that bigger emitter, glob up more solder than you’d normally use on the pads, and kinda “stretch” it over to contact the smaller 0805 LED. It’ll work fine, and you can’t tell it at all once its reassembled.
Ok, thanks for verifying guys. Now that I look at it, I can see the silkscreen print around the resistor is smaller than the one around the led. Well dang, I’m glad I bought these in bulk ’cause I can see myself losing half of them.
Mine have an arrow on one side. I simply tap the ends with my multimeter on diode test mode and see which way they light up, then I know that the arrow means ground/positive.
