Got my D4 from Aliexpress from a seller who stated that it’s “100% original”, with more than 1000 orders and very good marks for that product, I thought it actually is authentic.
Turns out you can fool the vast majority of buyers, because now looking at the negative feedback , only 3 buyers complained it was a fake.
It is a good overall fake, even the cable is branded Nitecore as are the capacitors.
Scratching the verification code only to find out it was used before (and now i see the exact same number was used for another post on this thread) googling the number also leads to other buyers with the same number.
Here are some photos of my unit:
. I would rather have a coke in the evening…
. Nowhere on the PCB does it say Nitecore or Sysmax
Sharing. I have a D2 and a old D4, both from the same seller.
D4 dont have the verification code in the box. Above the barcode, in the box, have a ’SYSMAX Industry Co. Ltd…
Inside the PCB its a SYSMAX too and dont have any Nitecore component. But the magnet test, cable and box its ok. The power socket its similar to my D2 above.
The D2 have the verification code, box, magnet test, cable, and more, all ok. But the power socket its:
Sorry for the poor photo, my cell phone its broken. If anyone needs I dismount both and take some photos.
Lol, I think I have an i4 fake that I bought from an ebay seller that is now gone. Time to throw that charger in the bin thanks to this thread. Will stick with Xtar from reputable dealers from now on.
I inserted a pair of 18650b’s equally drained to 3.6 v.
In one slot, the battery is charging ok, while in the other the charging stopped at 3.72v, showing 3 solid LEDs.
Sometimes it mistakes a Ni-MH cell for a Li-ion and overheats it pretty much, so I have to keep an eye on it - if the third LED does not start flashing after several hours - I pull the battery out and measure the voltage with а DMM.
Thanks for the info.
Now it worked, tried it a couple of days when I tried before.
I did post to there support about it earlier also, probably like many others
And it was nice to know get/confirmed it was a legit charger.
I have the same thing regarding the magnetic parts on my D4, only the positive is non-magentic, negative and the rails are magnetic and the validation check says:
"Invalid request! Registration unsuccessful.
This product with serial number of 8462548401078217 had been registered for warranty service on (03-01-2015 11:30) . If the first verification attempt wasn't carried out by you, please contact your seller before taking further action."
I googled my code and got a few hits including this:
"Finally, after validating the scratch code 8462 5484 0107 8217 on our validation page(http://charger.nitecore.com/validation), it showed that the first-time validation happened in last year and not operated by our sales! That means it is a counterfeit charger!!!"
"In this case, we think many counterfeit chagers are using this fake validation code( 8462 5484 0107 8217)!"
I see there is also an earlier post with someone who also got a charger with the same validation code
Thanks, I had a good look around Google wasn't anything concrete apart from the charge rate, that link seems to imply that just below 1.6v is a suitable termination voltage?
