The Atoms are wicked, my AAF is nearly the same output as my SWM D40A (0.7 vs 0.8 lms), and will do 200+ hrs (9ma Eneloop tailcap current draw) - I cannot believe they only spec 45 hrs. The 150ish lumen-hours/AA is the best efficiency I’ve ever seen for sub-lumen output, but this driver does lack voltage regulation (i.e., output changes depending upon V, and the light is rated to 4.2V). I bought a bunch for$18 when the reflectored version (“F”) went on clearance earlier in the year, but I think the current AA mules are way out of the OPs price range.
The A0 mules tend to be a bit dim for me too. Although I agree you can wait for deep dark adaptation, I find I’m always blowing my deep night vision with something (eg, smartphone surfing at lowest output), so I tend to prefer the “brighter” moonlights, and with a little more hotspot focus/lux.
Do you have a link to an independent output/tailcap current test of this light? I’m curious since that’s more than twice as efficient as I’ve ever seen for ~3 lms (eg, typically >11ma for a li-ion in my AA/14500 ZLs, Olights, Quarks)
Sure… I share a similar interest in low lumens, long runtimes, the 1xAA(14500) format, and have a bit of pet peeve with grossly exaggerated manufacturer specs, and sadly, your sample at nearly half claim isn’t too bad! (Although most exaggerations short change on lumens since that’s much harder to verify.)
