Custom sized Micro Textured lens:
If there is enough interest in custom sizes, I will have 1 or 2 sheets cut into any size you want. The only material I have available is 1.5mm thick… I should have some 2mm in a few months.
You will be able to specify your size for as few as 1 lens or as many a 1 gazillion lenses, but remember, it will be 1.5mm thick.
It looks like the Pineapple uses a 1mm lens, so someone will need to decide if the 1.5mm will work properly.
A C8 usually has a 2mm lens, but the thinner 1.5mm doesn’t seem to be a problem.
For Surefire 6P, the diameter should be 28.2 -if you request a 28.2, I will include the o-ring I use when installing the 1.5mm lens in a 6P.
If you want the lens for Solarforce (29.45mm) or the S2/S2+ (20.4mm), do not request them as a custom… I have them available and they are cheaper because I had them cut in mass.
The cost will be a little higher for the custom cutting and possible lower material yield. When I have the lenses cut, it’s always 1 size per sheet.
When specifying your size, measure the diameter in mm and specify to .1mm. (i.e. 28.2mm). I will have the lenses cut as ‘not to exceed’, so the final dimension may be slightly smaller.
I have devised a formula that will allow you to price out your lenses (use mm for the radius): 2+((πr²)*.0075)=$ plus $1 per order ConUS - plus $2 per order international.
Big lenses will be expensive and I don’t recommend it for anything larger than a C8. With that said, I’m going to have one cut for my L2… I like what it did for my C8 so much, I just have to try it.
So, who’s interested?
It will take at least 75 lenses to make a custom run feasible, so let me know who’s interested.
I'll be interested in a few, but have to take measurements this evening at the earliest. I want 2 for the Lumintop Prince (brass & copper) but they may take your standard 20.4mm x 1.5mm size, then I'll have to check if 1.5mm thickness is ok for the Pineapple. Definitely would be interested in a couple more (OTR M3, M6, JetBeam Jet I/II MK, etc.) but have to check thickness's if 1.5mm is ok in them as well. I have no shortage of lights
So for a 40mm wide, lens, I calculated $11.42, plus shipping: 20*20*3.1415*.0075 + 2, if I did this right.
Well I’m definitely interested in a Pineapple lens. I think the 1.5mm thickness will fit ok, but it may take a little thinning of that thick led centering ring to make it all tuck in there, and I’m not sure what that would do to the beam, but I’d still like to try it.
Tested in a convoy S2+ with XP-L HI and SMO reflector, the beam appears to be much improved. The outer ring is completely gone and the yellow center in the hotspot is way less noticeable. It also gave back my 1A emitter the pure CW tint, which used to have a yellow/green shift when the convoy AR glass was in place. The MT glasses are also much clearer than I expected, the texture is extremely fine and almost unnoticeable.
Excellent glass even if you don’t need the MT feature, the lack of tint shift and high transparency alone is worth it. :+1:
Would love to have this glass in my skillhunt H03R headlamp (much smaller than S2+).
Since I don’t think the custom lenses will use a full sheet of material, I’m going to have the custom sizes cut and the remainder of the sheet will be cut into C8 sized lenses.
If you haven’t added a post saying you’re interested, please do it by tomorrow night (12/04). I will PM everyone who is interested with instructions.
I plan on submitting the sizes for cutting on Wednesday (12/07) and should be able to mail the lenses out the following week.
After I have submitted the sizes to be cut, the custom sizes will no longer be available.
I put a MT lense in a Solarforce L2M host running a CustomLites XPL-HI de-domed emitter (V2 bin, 1A tint), SMO reflector. The new lense eliminated a small, pesky ring at the spot/spill interface. Now the spot is even and slightly feathered at the edges, and just looks fantastic.
I'm very pleased with this upgrade, and want to thank Randy for developing this lense and bringing it to market. Good stuff!! :) :) :)
I have sent a PM to members who were interested in the custom sizes of the MT lens… if you are interested and didn’t receive a PM, contact me.
Payment deadline is Wednesday. After this, the MT lens will only be available pre-installed in one of my flashlights (no custom sizes).
Order placed and pp sent. Thanks for doing this Randy! I know this sort of custom order stuff is time consuming and probably not very profitable. We definitely appreciate it!
If anyone needs more time to measure the lenses you want, just let me know. The order doesn’t have to be placed on Thursday… I can do it later if needed.
