Sorry, didn’t see the 240 sqft size. 4k lumens might be overkill. Sometimes I ceiling bounce my BLF A6 and that produces very nice results (before it gets too hot). Another option if you are looking for an indirect solution are wall mounted sconces. To test results, I’ve used magnets to attach some of my lights to the dry wall screws.
BTW, one thing I really like about the Jetbeam Jet-1 MK is that the tail is threaded to match a tripod. This makes for an easy temporary floor mounted indirect light.
What I did in the bedroom was to put up some crown molding with the top of it 6” from the ceiling. Then I just dropped some rgb + ww LED strips into it. It’s very nice indirect lighting and I have complete control over the intensity and color from my phone. You could also go with remote control or wall mounted options as well.
Yes, ceiling-bounced floody flashlights, from table-height, give a fantastic lighting effect. It practically eliminates shadows, and makes everything appear much softer under the light. It’s hard to get that effect with standard household lighting. You might be able to do something similar with wall-mounted lights directed upwards to bounce light off the ceiling at an angle. Kind of like you see in some movie theaters or museums.
I don’t find the flashlight distracting when I bounce it, as long as I’m not standing in the direct path of the spill.
Yes, with a 300 or 500 watt halogen bulb, they give off a very nice light that is bright enough for almost any room. The only downside is that they’re usually only 6 feet tall, and so taller people can see the bulb which is very intense. Well, they also use a lot of electricity, but you don’t get CRI 100 any other way.
i do not think you’ll find any factory made light that has 1 led running on max current, they always use multiple leds running at 1\2 or less of max current.
so if you want 4000lm xhp70 room light, you’ll have to build your own.
i gutted my 600w halogen light in my bathroom and replaced bulbs with 9 xml leds 80+cri, running at 900ma, it is even brighter that halogen was. sure i could have used 2-3 mtg2 at max current to get same amount of light, but leds run more efficient and make less heat at lower current.
That was the case. I have one 500w halogen in my home. I have converted it 4 years ago with 3xE27 bulbs. 13.5W led times 3 is 45W for 4000lumens. And now there are many of those with a E27 bulb that can fit a LED with no problems. It will be a lot dimmer, but they are really cheap. Ikea has one for 5euros. The led bulb is more expensive than the fixture. And you can put multiple fixtures, and distribute the lights better.
I have wired the sockets that have the floor and table lamps to be on a light switch, so you do not have to turn each one individually. With smart bulbs you can have a similar setup.
Would like to thank everyone here for some really good info. The idea I kind of like the most at the moment is the one where I can wrap the whole living room with a led strip up under the crown molding and connect it to a switch that can turn it on or off as well as change the color like this one I found on aliexpress On/off color switch
I will secretly purchase and plan the whole thing and build most of it at my relatives house and when my wife is with her friends for a couple of hours, I will have it all set up in our house without her knowing and surprise her when she comes back!
4000 lumens really isn’t a lot for a room that size, especially if you’re using lampshades. Every room in my home has over 4000 lumens. It’ll may seem like a lot because most homes are incredibly poorly lit compared to offices and produce departments. That said, you’ll probably like the lighting a lot better if that 4000 lumens is distributed around the room. The led strip you’re thinking about is one way to do that. If you have high ceilings and lighting with a ceiling bounce, 4000 lumens will get eaten up real quick.
Low ceilings actually, just under 8ft. We never wear sunglasses, so bright lights bouncing of the ceiling look very good and not so bright at all for 4000 lumens. We have white walls and ceilings which makes it much easier to create a nice effect, so I'm eager to make this happen. Would you or anyone else know of good quality led lighting that can change color? I purchased a few about a year ago for my pc and 30% of the lights are already gone, so would like something that is more reliable than the ones I got and that can be dimmed.
We used to run lighting level calcs that took into account ceiling height, ceiling, wall and floor reflectences, light fixture properties, etc… Results were giving in average foot candles at the work plane (30” above the floor, typical height of your average work desk). It’s been a long time since I’ve done anything like that, but I’d bet somewhere out there, you could find an app which would allow you to at least estimate the amount of FC that you could expect to have.
For comparison, typically for an office space (in the days before computer workstations), you would expect the design to be somewhere between 50-100 FC.
IIRC, hallways, breakrooms, water closets, etc… were designed more around 30 FC. Generally for homes. there wasn’t any recommended lighting levels because they weren’t works paces and home illumination levels are more of a personal taste item. Your average house, therefore, was normally lit up to pretty low levels, often with task lights being used to augment. If you go back 30-40 years, a lot of homes (especially bedrooms) weren’t even designed with permanent ceiling mounted fixtures. Lighting was often provided by lamps plugged half-switched duplex receptacles.
I have a “flowerpot” edison-base socket for a large-globe neon bulb (flower-shaped electrode with different-color phosphors), that I stuck in an LED “halogen” replacement spotlight. The WW bulb shines up at the ceiling, giving the whole room a nice WW glow. I’m sensitive to bright light point-sources in my peripheral vision, as it gives me “eyeaches”. I rarely use the overhead light in the room.
So yeah, get a pole-mount torchiere with such a bulb aimed up, and it’ll flood the ceiling with whatever light you choose, colored (haha) by the actual color of the ceiling, of course.
If you go with just RGB your going to hate the white it produces. You’ll want to get RGB + warm white strips, or add an extra warm white strip next to the RGB strip, which probably wouldn’t be a terrible idea anyway to get some extra light.
