I think the comment meant that the heat is spread across a wider area. Instead of 10 Watts coming from a couple square millimeters (like in a flashlight), it’s 10 Watts spread across a much wider area. It achieves an effect similiar to a heat sink… without a heat sink.
However, in either case, there is still a need to shed heat somehow. If it’s a sealed bulb, it probably still needs a thermal path from the LEDs to the outside world, even if the LEDs are large with low surface brightness. Because 10 Watts is 10 Watts either way, and that heat needs to go somewhere.
Thermal conductiv gas inside the bulb to spread the heat?
My only filament bulb gives very little heat to the socket.
Is less than two watt,but efficient.
Old incan bulbs were like 5% efficient, meaning 95% of their power went toward making heat. LED bulbs are more like 25-50% efficient. The efficiency drops as current rises, generally, so it’s usually more efficient to have ten LEDs making 100 lumens each than it is to have one LED making 1000 lumens. The group approach makes less heat for the same amount of light.
Instead of using ten LEDs though, it also works to use a single large LED. Again, same amount of light but less heat. And the single large LED can take a variety of shapes. Instead of a square or circle, it could be an outward-facing ring or a partial globe.
Or it can increase efficiency by using a remote phosphor approach. Emit light from a few places but don’t coat the LEDs in phosphors to give them a good tint. Instead, coat the inside of the entire bulb in phosphor material. This spreads the heat around multiple places, part at the emitter and part at the phosphor… and the phosphor can sink its heat directly to the bulb shell and outside air.
For light bulb purposes, I like the large-LED and remote-phosphor approaches. They increase efficiency, make it easier to manage the remaining heat, and provide a more-diffuse less-intense appearance. But small LEDs are okay too as long as they have sufficient heat sinking and diffusion.
I installed all 40 and 60W Cree LED bulbs in my house that I bought from Home Depot. I have not had one fail in more than 2 years of use.
With that said, I installed two 100W Cree bulbs for a customer in an outside fixture. I had one of the 100W bulbs fail. Not sure what the reason was. My boss was pissed and threw it in the dumpster, where it proceeded to smash in pieces.
I keep loosing the original CREE bulbs with the “sticky” coating on the glass globe in 1 particular outside fixture that allows some moisture inside of it. I think somehow water gets inside the globe and causes a short. In this fixture the globes point up with the socket on the bottom. I stopped using the CREE’s in that fixture, but just this evening when I got home I noticed one of the Philips I had in there has stopped working. That bulb had been in there for about a year.
Most outdoor fixtures meant for residential use don’t adequately address the problems inherent in that use. Few keep all rainwater out; it either gets in the working area directly or gets in at the base of the fixture. With there also being winds involved it’s not an easy task to keep rain out. There’s also condensation and humid air to deal with; again few lights handle this very well. They’re often near entryways where vibrations in the wall from slamming doors rattles them loose over time. And more open fixtures will have insects pestering them which can adversely affect heat paths and locations. Then there are the temperature extremes. It’s a rough place to live in and it takes a robust bulb and fixture to survive
Also is a more modern problem- the general cheapening of things. The oldest outdoor fixtures used solid brass sockets, contacts, and screws. Bulb bases were also solid brass. Then came brass-plated stuff which worked nearly as well as long a it stayed relatively dry. Now we get aluminum sockets, bulb bases, and contacts with thinly plated steel screws- a guaranteed path to corrosion- and we get fancier fixtures less resistant to the elements and environment they live in. This cheapening also affects indoor fixtures too
LED home lighting is just past it’s infancy and has more maturing to do before it becomes universal. In time it will get there, and it’s an exciting time to be involved with it even with it’s occasional frustrations. I personally believe the end will be integrated fixtures with long lifespans instead of separate bulbs and sockets since that can be both minimalized and optimized for each intended use. There may even be new mounting systems developed where changing the whole fixture is as easy as changing a bulb. I’m looking at the future of lighting and it’s brighter than ever before in every way :+1:
Phil, that fixture is everything you say and more. It’s cheaply made, old, leaks like a sieve and it needs to be replaced.
Last year I found this huge, used fixture for $10 at the ReStore. I haven’t yet put it up as it may look too “commercial” for a residence.
Here it sits next to a 1 to 7 adapter containing 7 CREE 60W equiv bulbs. With the high price of 100W CREE’s around here, it is cheaper to go that way.
Being a commercial fixture, it is made very well. Cast Aluminum everywhere with a hinged top and built in photosensor. There is a nice rubber gasket that seals to top onto the base to keep the water out.
Originally it used perhaps a high pressure sodium bulb. Huge socket. If I were to convert it over to standard E27’s I would strip out the ballast and socket to make room for the many E27’s I would want to use.
(1 CREE 60W equivalent for scale)
BTW, The reason I believe all this is relevant to this thread is because as of yet, it is not easy to find a decent or cheap 100W equivalent LED bulb. It seems to me that if one needs a lot of lumens, it is more cost effective to use many cheaper, 60W equivalents. Recently I was able to get some Philips 100W, 1500 lumen bulbs for a decent price but I don’t like them.
60W equivalents can sometimes be picked up super cheap. I just got these boxes of 24, 60W EcoSmart LED bulbs for $10 each.
(Home Depot is clearing these out, and some stores are down to $10) There is no instant rebate associated with that price.
I could have sworn Costco was selling a 10 pack of Feit 100W bulbs for $50 a few months ago. I found some reviews on what appears to have been the same bulbs, and they’re bad, but that’s offset by Costco’s excellent customer support. I think Feit has decent support too. Unfortunately Feit bulbs now come in smaller packs at a greater per bulb price. That said, it looks like there are quite a few selections of 100W LED bulb packs that bring the per bulb price down to about $3. I have one of those 7x bulb adapters too. They’re a great way to get lots of affordable lumens with the bulbs we have now. Hopefully in a few years I can replace it with a single normal size bulb that puts out 10 thousand lumens, high cri, 4500k tint, dimmable or 3-way, and doesn’t crap out in less than two years. I suggest getting a socket extension for the middle bulb so that it’s not shrouded by the outer bulbs. I’d like your current old fixture if it were rehabbed. It has lots of space for bulbs, has more volume that should help the bulbs stay cooler in its enclosed environment, and has more glass to let the light out.
I was in Costco yesterday and saw these 10 packs. The price is right, although only because of the CT subsidy. Trouble is they are daylight bulbs. Even so, I was VERY tempted to buy one.
That looks like it. My store doesn’t have those now. I would have bought it at full price, nevermind that huge discount you get in Connecticut. The biggest now is a 4 or 6 pack, and I don’t think it’s daylight. I prefer daylight since I’m used to high tints from living further south. The 60 watt 10 packs are still there.
The Feit 1600 lumen 100W eq uses 15W and claims on the package it is rated for enclosed fixtures, it works remarkably well. Though with subsidy it was $5 a few months ago, i bought 5, great bulb, i should have bought more, i replaced those not so great Philips bulbs with the Feit bulbs, the Philips are now unused and take up space.
I would be concerned about using that 7x device unattended, as far as i know its not CSA/UL/CE rated, and some adapters from chinese websites have been found to be unsafe (low gauge wire, cheap plastic that combusts etc.). For example i was looking for GU24 to E26 adapters and reviews complained about these type problems in an amazingly simple device thats just plastic and some terminals
I wish i could buy one of those 7 bulb adapters at a big box store that is approved, i would buy a dozen of them
The last of my original daylight 100W bulbs has failed. Unlike the other bulbs, I caught this one before complete failure. One strip of LED’s doesn’t light up.
It’s weird that the 100W ones didn’t last. I replaced most of my bulbs with Cree 60W back when they were released, and none have given me any trouble at all. Well, except the one I hit with a light saber… but it only knocked the glass off, and it works fine after gluing that back on.
I haven’t had a problem with the 60W bulbs either.
Home Depot rejected my attempt to return Cree bulbs for the first time. So much for recommending buying LED bulbs there for excellent customer service. This will be the first time I try Cree’s customer service. The replacements came from Costco this time. Feit dimmable 100W bulb 4-pack for $17. I was tempted to bring some back from my trip to Seattle where they were subsidized to $8, iirc.
