Thanks Lighbringer. I see.. ok.. This would be a problem on the opposite end also, not that anyone cares much there, but a 254 would not regesiter as 245/255 but more like 254.9/255.
So that creates a little non-linearity in the PWM response, maybe complicates unifying software across different configurations (different numbers of 7135's), but in the end you can still do a PWM of 3 though to get the equivilant of the 1, and if it's really only that bad, then that's not so bad at all. There might be some actual energy wasted in driving all that capacitance though, which might bug the survivalists who want 50 days of moonlight mode. Between the two issues, I'd rather have high frequency.
It might get a little more complicated than that, that there’d be a similar lag when turning off, but the main issue is in fact getting the bugger to turn on in the first place when the PWM period for 1 count is about as long as you want to strobe the 7135s.
It’s like turning on a bank of tube fluorescent lights that flicker a bit before catching. That lag is what causes the issue when you just want to turn the lights on for, say, 1sec, when it takes about 1sec for them to catch.
And the bigger problem is that there’s variation elsewhere (7135s, output drive for the Tiny13s, etc.), that some combos will work fine and give you nice low firefly mode, whereas other times it won’t turn on at all, or start fine in firefly but not at all when stepping down from turbo to firefly, etc.
I followed the thread for a while, on setting PWM values on “biscotti”, and it got really complicated.
For a Li-cell, the best firefly mode is probably just a dedicated line through a resistor, not PWMing it at all. Besides, as I can attest from my Quark, lowest modes tend to be the greenest (yecch). That’s why PWMing is actually preferred over linear. Linear brings its own issues such as nasty color-shifts in any LED (even monochromatic, not just white). Even 2A vs 2mA is a 1000:1 range.
If I understand correctly, the only reason the Pineapple needed to use PWM was in order to be dual chemistry. If it was only AA and Eneloop powered, PWM would not be needed. Im not sure I understand whether LiIon chemistry would require PWM, like the 7135 uses.
here are photos of the new preon and the malkoff, I do not know the speed of the Preon PWM (it has somewhat green tint, even with PWM… probably due to the LED itself, not the circuit, )
[QUOTE=gurdygurds;5011460]Well I now have two Nichia 219b lights and I’m really enjoying them. Received a Copper worm from Gunga yesterday(thanks again sir) and quite like it. Here is a shot of it next to my Preon P1 gen 2.
And here is a side by side comparing my two Malkoff MDC AA lights. 4000k vs 6200K. I absolutely LOVE these flashlight!
[/QUOTE]
there is a way to determine PWM speed with water drops and a camera with adjustable shutter speed:
[QUOTE=Lexel;4991544]All Convoy lights with 7135 drivers use 4500Hz PWM
[/QUOTE]
regarding tint shift
two XPG2 on high, for tint comparison (NoPWM part of the circuits)
the CC light was greener to begin with, not by a lot, LED variation, not PWM caused since these lights are not in a PWM mode
same two lights on Medium…
I dont see a serious green problem with the CC light in this image
the tint shift is more obvious in this sweep
I dont see a large green shift from CC in my lights with N219b or XP-G2, or XPG… , I suspect the XPE had more of a problem with green tint.
Yep. Tint shift is highly dependent on the LED. Modern day LEDS are likely better.
If the pineapple can be done with CC and 1.5V only? I’m all for it. I would like the max to be increased though. The current 100 lumens or so is pretty weak. It’s okay with dual voltage but not by itself.
For me it is important how good the light perform and if its only AA it doesnt get destroyed putting in a lithium battery
PWM should be a few kHz at least
Efficiency in ultra low modes is not so important, who wants to use an AA light for more than 24hours?
If I got a long power outtake, which was last time back in DDR in soviet times, I have plenty of 18650 CC lights which I can use for ceiling bounce light over long periode of time.
I don't see the moonlight as that big of a deal. TA offers multiple hex's with different moonlight settings. IF you're selling a single light you only need to find one that works on that light reliably, and from the sounds of it 5khz would fix it almost entirely and still isn't slow pwm. I think 20khz is still fine though. I guess it just means you need the +1 channel, don't try to do moon with 12 7135's. But that doesn't actually add any cost. It's just about doing it right.
Exactly. Ultrafire 100 Hz PWM is annoying, but I doubt we need a poll to figure that out.
It’s interesting that people interpret “no PWM” to include “no visible PWM” though. What does “PWM” mean to people? More on that below.
I don’t see any “NoPWM” lights there. What I see there are four PWM-based lights. This confirms to me that the disagreement is about the definition of PWM, not people’s preferences about the physical properties of light.
Left to right, the PWM speeds on those lights are (approximately):
Zebra: 5000 Hz
Quark: 2200 Hz
Eagle: 4500 Hz
Malkoff: 1350 Hz
All four of those are too slow. I have the same Zebralight and EagleTac lights reppans used in that pic, and I can see the PWM on both during normal use. All four are examples of what I call “bad PWM”.
The v2 Pineapple driver is spec’d at 9000 Hz, which is ~2 to ~6 times faster than the premium-brand lights shown above. Not bad, but not what I’d call good either. Most BLF drivers run at around 14,000 to 18,000 Hz. The new Convoy C8 runs at 32,000 Hz. I find ~20,000 Hz to be ideal, preferably with a FET+1 or FET+N+1 driver for better efficiency.
I like true CC circuits for their efficiency (when done well), but a 2-channel or 3-channel PWM driver is close enough for my purposes. Here’s a qualitative comparison of 1-channel, 2-channel, and 3-channel PWM drivers and their efficiency as compared to an ideal CC driver:
x2… I tried to elude to this in my earlier post, but didn’t really have the detailed information to clarify what I was talking about.
FWIW I am totally OK with PWM, so long as I can not readily see it. My understanding is PWM is the most efficient way to lower LED output too, although I am not sure why. My Thrunite TH20 I just realized uses PWM for its lowest-low / candle setting. I didn’t even realize it until I had it on and was washing my hands in the middle of the night, under the water it became more noticeable. I am OK with that, since its high enough frequency to not be readily visible all the time.
I would now have to vote for the following after learning the above and when considering the UT01 in transit to me now):
“PWM” speed (as now better understood, thanks to toykeeper)…
…quality LVP protection (as evidenced by the NiMH ‘only’ shutoff apparently exhibited by the UT01)
…and ‘tint’ would be my (off-topic) answers to the OP’s poll involving a 14500 capable light (you can buy a Nichia 219 tinted BLF ‘backup’ light for $7 and a Jaxman for less than $20 so ‘tint’ has become less important to me…yet it’s always nice to have).
I’d really like to standardize more on AA cells and the protected versions for at least 500 lumens in a single cell EDC light.
fwiw, I wrote to Malkoff to ask the speed of the PWM, and got this reply direct from Gene Malkoff:
“The PWM frequency is 310 Hertz. Most people can’t see it.”
regarding Zebralight pulse speed, see http://www.candlepowerforums.com/vb/showthread.php?415838-Zebralight-SC5Fc-measurements-(AA-warm-tint)
“PWM is used to control output on all modes except H1. The PWM is not visible to the eye, because of its low amplitude, but possibly shows up on camera. The cycling frequency is higher on higher output modes and ranges from 775 Hz to 5000 Hz. The amplitude however is higher on the higher modes.”
Note that when I say Zebralight is not “technically” using PWM, it is because the pulses do not drop to zero. That is why there is a blurr between the dots in the reppans PWM progression photo, the LED is not turning all the way off. The brightness is fluctuating, like in the quark, where you also see a blurr between the dots.
Even the Eagletac pulses do not drop to Zero, in fact Selbuilt says he cannot detect PWM, just “noise” http://www.candlepowerforums.com/vb/showthread.php?401362
“There is no sign of PWM that I can see, at any output level…
I did detect some high frequency noise as shown below:”
obviously everyone has different definitions and tolerance of PWM. Some people dont care, some people object to calling pulses PWM unless they drop to full zero, and Zebralight as well as Eagletac, claim they do not use PWM (technically this is correct, but in the real world, some people can see the flashes, or get headaches from them)
thanks for the discussion… I really dont expect to convince anyone whether PWM is good or bad, it is clear to me that the majority of people, given a choice, will prefer NoPWM, but, they will still buy a light that has pure PWM (eg Malkoff and Pineapple), or hybrid PWM (eg HDS, Zebralight, Eagletac) that does not drop to full zero between full power flashes.
“when I say Zebralight is not “technically” using PWM, it is because the pulses do not drop to zero. That is why there is a blurr between the dots in the reppans PWM progression photo, the LED is not turning all the way off. The brightness is fluctuating, like in the quark, where you also see a blurr between the dots. “
I think my Thrunite TH20 uses this same kind of “PWM” on its candle mode. When I vigorously shake the light in my hand… Theres a faint trace of the LED between the “dots”.
Interesting. I used the EagleTac stripe as a reference at 4.5 kHz (since that’s the speed mine was), and calculated the others based on the pulses shown in the picture. But I haven’t actually measured a Malkoff, and can’t say for sure that reppans’ EagleTac unit goes at the same speed as mine. If I use Malkoff=310 as the reference, that would mean the speeds are:
Zebra: 1150 Hz
Quark: 500 Hz
Eagle: 1040 Hz
Malkoff: 310 Hz
That doesn’t sound right though, since I’ve never seen my ZL or ET lights (2014 model) pulse that slowly. So I tried measuring my other EagleTac D25A (2012 model), which oscillates between two levels but doesn’t actually shut off like the one in the pic. It got 984 Hz on its low and medium modes. Moon was slower (much slower), but not bright enough to measure.
ET D25A (2012): 984 Hz (2-level oscillation)
ET D25A (2014): ~4.5 kHz (hard on/off PWM) (can’t measure right now since it’s in pieces)
I also tried measuring my ZL SC52 again, and got these results (with an Eneloop):
L1: 3.3-3.5 kHz (ish)
M2: 15.3 kHz
M1: None
H2: 29.1 kHz
H1: None
The one I’ve noticed during use is L1. That reading was unstable though, which means it probably wasn’t accurate because it wasn’t bright enough for my sensor to measure correctly.
Out of curiosity, I measured my JB RRT01, the continuously-variable magnetic ring light. It measured at only 1.01 kHz, but it looks like the oscillation is a fairly smooth sine-like wave so it’s hard to see.
JB RRT01: 1.01 kHz
… and the BLF Q8 driver Tom sent me. At low levels (up to ~140 lm), it shuts off between pulses, but medium and high levels (140+ lm) do a 2-level oscillation. Neither range is visible, and the transition is seamless.
I would buy a light that is inexpensive and I can easily take apart. I don’t care what cell chemistry it was made to support as I can determine that with driver choice.
if you only had 2 choices, what AA driver would you choose: #1. With PWM and LiIon, or #2. With NoPWM and NoLiIon
everyones opinion on the Merits of PWM varies, and Im not trying to start a pro and con of PWM debate
I was trying to figure out how much market share each of these options represents:
dual chemistry AA and LiIon with YesPWM, or
AA only with NoPWM
I myself intentionally do not buy PWM lights. I also dont happen to use LiIon in AA sizes. So I am a Type #2 buyer. I think Im in the minority, cant tell from the poll, I did not structure it correctly to find out. I got confused by too many possible options, when the last one really is not realistic and should not be in the poll… too late for that
to anyone still reading, which of the two buyer types do you represent, AA/LiIon option w PWM, or AA only w NoPWM?
