They’re probably just rewrapped WhateverFire cells in drag.
And even so, get a light that takes a 26650, slap on some of those rubberbandy things that “adapt” 18650s for use in 26650 tubes, and you’ll be able to use 21700s in 26650 tubes as well.
By this logic A 26650 should be 7300mAh.
Can you take a guess why not?
Tell us?
I wouldn’t be surprised if it took 5+ years for these cells to hit the open market. Tesla isn’t going to release them for general sale unless they know for sure that they can meet their own internal needs, and that may very well be never. We’ll probably have to wait until someone like Panasonic, Samsung, LG, or Sony start producing them in their own factories. And for that to happen they will need to see a demand for that cell either from Tesla not being able to produce enough in house or some other car maker or industry adopting that cell. The sales from those of us using them for flashlights probably don’t even show up as a blip on their radar.
Ok people… it’s time to start discarding 18650 flashlights.
20700 Sanyo NCR20700B 4000mAh High Discharge Flat Top
Price: USD 9.99
Spec sheet here:
Someone needs to get a pair of those to HJK for testing, STAT!
Clif Notes:
Rated capacity: 4000mAh
Minimum cap: 4050mAh
Typical cap: 4250mAh
Impressively little voltage sag under 15A discharge
~2800mAh capacity after 500 8A discharge cycles.
Edit: max dia = 20.35mm
I wonder how many lights out there have enough body material available such that a enterprising modder with a mini lathe could bore the body slightly to fit a 20700…
There is nothing special about them…
They are in between 18650 and 26650 size, and have between 18650 and 26650 capacity.
It’s just a different size battery.
Why bother making an entirely different flashlight just to fit a different battery if you already have two FAR more widespread options that are the same energy density?
It literally makes no sense….
“let’s make a new shoe size that is between 11 and 11.5, and that fits feet between size 11 and 11.5!”
The difference between 18650 and 26650 is just a few millimeters of diameter, and if you want a larger diameter body you go with 26650, if you want less then you go 18650.
There is no benefit to going in between.
If a new type of battery is to be introduced it needs to bring something better to the table than there already is.
Not “lets make something sized in between, that performs in between”
The 26650 is far from the same energy density as the 18650, I bet they are even worse then the 20700.
4000ma in a high discharge cell is 33% more then you get in a 18650, that is well worth taking note of.
26650 lights are ok but they are large and heavy, only suitable to larger format lights. The 20700 could fit in EDC lights.
The problem with the 26650 is that it has a much lower energy density than the 18650.
Now we have a 21700 with the same high energy density as a 18650 but with the potential to have greater discharge rate and capacity than the 18650 (probably on-par with the 26650) but in a much smaller package then the 26650.
Those are advantages which we flashlight dudes can work with to produce lights which are more powerful than those which run on 18650 but smaller than those which run on 26650.
Also, the 1 inch diameter (25.4mm) battery tubes we now use with 18650 can also fit the 21700 - just bore the hole a bit larger.
The only thing is the tailcap thread diameter area will need to be a few mm larger which is no big deal.
Generally speaking, I bet the lights which run on the 26650 now can also run on the 21700 with the same resulting performance.
If you used the same “better manufacturing” used for the tesla batteries then you would have 26650s with the same energy density as 18650s.
Maybe instead of trying to introduce something in the middle just improve what you already have??
But they are not and will not do that. They have had 26650’s for how many years? Yet not a single major manufacture has produced a 26650 yet. Thus I think it is safe to say they will not be doing so.
The 20700 should reach 26650 levels fairly easy with major brands working on them.
Technically Sony did make some 26650s but this proves the point even more, they tried and gave up a long time ago. Not enough buyers probably which is really the only reason this Tesla stuff is interesting, it’s a large enough market push that it could shift production by major battery manufacturers. Then you stack on that these manufacturers are interested in producing as few different cells types as possible to compete with economies of scale. It’s up in the air, some may switch a lot of production and development to these new cells and maybe eventually all of it. I’m sure we’ll always have all the weird sizes we love from Chinese brands as long as there is the demand.
No matter what happens though, I’m excited, it’s a new cell type to build lights around and more money in development of better batteries.
Just say when akkuteile.de or nkon.nl got them in stock and I will order some.
My queue is fairly short at the moment, i.e. a review will probably show up in less than a month.
Thank you HKJ. Hopefully the battery will show up in the European outlets soon.
Clif Notes:
Typical cap: 4250mAhImpressively little voltage sag under 15A discharge
Here is a test/review:
The two cells tested were donated for the purposes of testing by City of Cloud (Batteries). Thank you! To prevent any confusion with the eGo-type "batteries", I use the term "cell" here to refer to a single 18350, 18650, 26650, etc. While the...
BMZ, who are building a gigafactory in Europe, have voted for the 21700 over the 18650:
"……….Europe’s biggest battery supplier says, “With 3Tron, BMZ is putting its trust in a completely new format: instead of a 18650 (18mm diameter and 65mm high) cell size, 3Tron will be produced as a size 21700 cell (21mm diameter and 70mm high)…..The 3Tron battery system, as the first 21700 format system worldwide, is setting the standard in this new class – because it is clear that other manufacturers will follow and produce 21700 format batteries as well: the development possibilities of the 18650 cell format are exhausted.”…………."
FRIEDRICHSHAFEN, Germany – Two of the world’s biggest battery suppliers presented major innovations at last week’s Eurobike. Panasonic showed its newly developed 20700 cell. BMZ, however, topped that with the world 1st 21700 cell. With the company’s...
Sanyo battery - Sanyo NCR20700A 3300mAh 30A Battery
Price: USD 7.99
Sanyo NCR20700A: 3100mAh, 30A, $10/unit
Sanyo NCR20700B: 4000mAh, 15A, $10/unit
Don’t forget if you are in the USA , IMR has the 15% discount code that was worked out a couple months ago with Jason for the forum members.
This would bring the price of the 20700 to around $8.50 each for us using the code…… BLF15
If interested in the thread you can find it HERE
How much are Samsung 21700 cells?
Some info about the BMZ 21700 cell:
KARLSTEIN am MAIN, Germany – It has been one of the most read articles this year at bike-eu.com; Bike Europe’s September 6 publication; ‘Quantum Leap in Battery Innovations Presented at Eurobike’. This ‘leap’ extends e-bike battery life to up to 12...
Excerpt:
“………What it all boils down to is that BMZ developed what it calls ‘giga-cells’. They are named 3Tron and come in the 21700 format; 21mm diameter and 70mm height which is a lot bigger compared to the nowadays commonly used 18650 cells. The new 21700 cells offer, “60 percent more capacity while being able to use 400% more discharge current at the same time,” claims Sven Bauer, Managing Director of BMZ GmbH.
Thanks to a big increase in active cell material as well as the use of nickel-manganese-cobalt oxide, stronger conductors and high-quality materials, 3Tron increases the energy yield by 50 percent. The lower internal resistance produces 68 percent more output.
In producing the super cell, BMZ cooperates with the world’s leading cell manufacturer Sony. This company’s manufacturing expertise comes with the annual production of more than 300 million cells, says BMZ………”
