Impressively little voltage sag under 15A discharge
~2800mAh capacity after 500 8A discharge cycles.
Edit: max dia = 20.35mm
I wonder how many lights out there have enough body material available such that a enterprising modder with a mini lathe could bore the body slightly to fit a 20700…
There is nothing special about them…
They are in between 18650 and 26650 size, and have between 18650 and 26650 capacity.
It’s just a different size battery.
Why bother making an entirely different flashlight just to fit a different battery if you already have two FAR more widespread options that are the same energy density?
It literally makes no sense….
“let’s make a new shoe size that is between 11 and 11.5, and that fits feet between size 11 and 11.5!”
The difference between 18650 and 26650 is just a few millimeters of diameter, and if you want a larger diameter body you go with 26650, if you want less then you go 18650.
There is no benefit to going in between.
If a new type of battery is to be introduced it needs to bring something better to the table than there already is.
Not “lets make something sized in between, that performs in between”
The problem with the 26650 is that it has a much lower energy density than the 18650.
Now we have a 21700 with the same high energy density as a 18650 but with the potential to have greater discharge rate and capacity than the 18650 (probably on-par with the 26650) but in a much smaller package then the 26650.
Those are advantages which we flashlight dudes can work with to produce lights which are more powerful than those which run on 18650 but smaller than those which run on 26650.
Also, the 1 inch diameter (25.4mm) battery tubes we now use with 18650 can also fit the 21700 - just bore the hole a bit larger.
The only thing is the tailcap thread diameter area will need to be a few mm larger which is no big deal.
Generally speaking, I bet the lights which run on the 26650 now can also run on the 21700 with the same resulting performance.
If you used the same “better manufacturing” used for the tesla batteries then you would have 26650s with the same energy density as 18650s.
Maybe instead of trying to introduce something in the middle just improve what you already have??
But they are not and will not do that. They have had 26650’s for how many years? Yet not a single major manufacture has produced a 26650 yet. Thus I think it is safe to say they will not be doing so.
The 20700 should reach 26650 levels fairly easy with major brands working on them.
Technically Sony did make some 26650s but this proves the point even more, they tried and gave up a long time ago. Not enough buyers probably which is really the only reason this Tesla stuff is interesting, it’s a large enough market push that it could shift production by major battery manufacturers. Then you stack on that these manufacturers are interested in producing as few different cells types as possible to compete with economies of scale. It’s up in the air, some may switch a lot of production and development to these new cells and maybe eventually all of it. I’m sure we’ll always have all the weird sizes we love from Chinese brands as long as there is the demand.
No matter what happens though, I’m excited, it’s a new cell type to build lights around and more money in development of better batteries.
Just say when akkuteile.de or nkon.nl got them in stock and I will order some.
My queue is fairly short at the moment, i.e. a review will probably show up in less than a month.
BMZ, who are building a gigafactory in Europe, have voted for the 21700 over the 18650:
"……….Europe’s biggest battery supplier says, “With 3Tron, BMZ is putting its trust in a completely new format: instead of a 18650 (18mm diameter and 65mm high) cell size, 3Tron will be produced as a size 21700 cell (21mm diameter and 70mm high)…..The 3Tron battery system, as the first 21700 format system worldwide, is setting the standard in this new class – because it is clear that other manufacturers will follow and produce 21700 format batteries as well: the development possibilities of the 18650 cell format are exhausted.”…………."
Don’t forget if you are in the USA , IMR has the 15% discount code that was worked out a couple months ago with Jason for the forum members.
This would bring the price of the 20700 to around $8.50 each for us using the code…… BLF15
“………What it all boils down to is that BMZ developed what it calls ‘giga-cells’. They are named 3Tron and come in the 21700 format; 21mm diameter and 70mm height which is a lot bigger compared to the nowadays commonly used 18650 cells. The new 21700 cells offer, “60 percent more capacity while being able to use 400% more discharge current at the same time,” claims Sven Bauer, Managing Director of BMZ GmbH.
Thanks to a big increase in active cell material as well as the use of nickel-manganese-cobalt oxide, stronger conductors and high-quality materials, 3Tron increases the energy yield by 50 percent. The lower internal resistance produces 68 percent more output.
In producing the super cell, BMZ cooperates with the world’s leading cell manufacturer Sony. This company’s manufacturing expertise comes with the annual production of more than 300 million cells, says BMZ………”
Those are still too expensive, but pretty good when considering that they just became available. Remember how expensive the NCR18650B was a few years ago? It was insane, but now they go for about 1/3rd of that. Hopefully these do the same and end up costing around $3, which I think is entirely possible with cells coming out of Tesla’s Gigafactory’s. BMZ calls their battery factor a gigafactory too, but apparently is unaffiliated with Tesla. I think their prices will be good, but it’ll be hard to match the advantages of Tesla’s vertically integrated business. Competition is good though, and should drive up manufacturing efficiency and battery capacity.
ok applying my logic
the 21700 will become a household name like AA and aaa (yuck i hate aaa)
i think the general audience has matured to the point they are ready for a paradigm shift in there lives
we Here and in the Vaping world have held onto something for too long and it is time what we know and care about be taken away from us (can you handle that)
up to this point most consumers have never heard of an 18650 or 14500 because it was never meant for them 18650 have been around since 1991
it would be like giving a Light Saber to Jar Jar Binks
but the world is smarter and the chargers are better or the 21700 will be too big to leave in a pants pocket with loose change
i hope to see the 21700 in stores even Kmart soon
i am looking for the ’’That’s one small step for mankind, one giant leap for mankind.”
i have had fun for years ripping apart things for the**_ “Precious bounty” even did a Creative MuVo2 for the 4gb Microdrive _**
but now i only buy NEW TOP OF THE LINE Sanyo/Panasonic NCR18650B and at one point i paid $2,82 each for 50 (now they are hard to find at $4)
but i am trying to say i think 21700 will be come a household word sorry for my rant
Outside of the small group of flashlight enthusiasts, almost nobody has ever heard “18650” and I would be willing to bet about 0.0000001% of the world population knows what it is.
Now you think people will magically need something 10000x less common than an 18650??
Sorry, but no, this is never going to become as common as alkaline batteries. Even 18650 will never become as common as alkalines.
Ask your grandparents what an AA is and they will know, but not 18650 or 26650.
I think all the people in this thread need to get real and actually see what a huge minority they are and how rare 18650s are outside of their flashlight friends group.
