Smallest MT-G2 Flashlight Ever?
Even smaller than the BLF-348 MT-G2, the DQG Hobi MT-G2
Dedomed MT-G2 Q0 5000K emitter on copper slug
10mm MTN driver
Reverse clicky tail switch
Titanium & brass body
Graphite trim
2x 10180 or 2 x 10250 cells (with extension piece)
Weight - 19g (with cells)
Length - 54mm
2A max current on high mode
Come on now…that’s just plain nonsense :wink: Does it burst into flames when you turn it on? When I read the title the first thing that came to my mind was, noway it was the smallest ’cause I recall somebody doing this in a 348. I should have remembered it was you. Anyhow, nice job as always. I’m waiting for you to shoehorn an XHP70 into one of those matchstick lights now.
Super floody light? Count me in :+1:
:smiley: Thanks
Thought about it. It would probably be easier to get a XHP70 in there due to the smaller size, i had to grind down the corners of the MT-G2. The only thing that bothers me is if there would be a shadowy cross or dull centre spot if the emitter is installed in a mule light? I haven’t researched that yet so if anyone knows?
Not exactly the same thing but my EE X7 with xhp50 and no reflector or optic gives a perfectly even beam.
That’s what i wanted to hear, i think…
Thanks.
You sir are just plain crazy. Love the mod and your abilities. :+1:
If there is no optic it is a perfectly even beam, well, flood, since there is no beam :stuck_out_tongue:
Hahahaa!
And i was actually thinking of something like this, since i have 2 10180 DQG cells collecting dust. (because the Astrolux keychain lights suck…)
But you just did it. :smiley:
How much current can a 10180 push anyway?
And what kind of driver do you use?
I get a maximum draw of around 1.4A from a 10180 and 2A from the 10250 MBI nukes, dropping quickly on full blast mode obviously due to their tiny size but good enough for little fun builds like this and there are always lower modes to use.
The driver in this one is a zener modded MTN 10mm
What if you made a flashlight where the entire front of it is just one big LED like a COB chip?
I think that would look really cool :slight_smile:
Not sure how close to the phosphor you can cut those…
I like that idea, going to look into it. :wink:
YAY! :smiley:
+1
What a tiny little monster you’ve created CRX! :exclamation:
