I don’t turn off the lights when taking my measurements, when I set the luxmeter range to x100 the tiny 50lux from my room lights become 0 and do not affect the 50000 lux from my light
So for me it’s an insignificant decimal place that doesn’t even get considered.
I see your point bu i somewhat remember having the exact same number when measuring my B158 at 5 and 100 meters using the simplified widespread method of calculation, maybe i should try it another time.
I was under the impression that the common wisdom among us was that 1 or 2 meters readings may not be accurate and that around 5 meters was kind of the minimum distance to take readings.
I have to say that this possible effect has caused me some confusion regarding my understanding of throw and how to predict it, so I did some measurements to see what is actually happening.
My test light was a UF-1504, with 62mm diameter lens and XPL HI V2 1A. I put in a 8x7135 driver to keep the output more constant with time. I measured the lux at three different distances measured from the lens.
dlux__cd
6.05m7230_264.6Kcd
8.34m3840_267.1Kcd
10.29m2530__267.9Kcd
These measurements are consistent with measuring the distance right from the lens and not at some point behind the lens.
Plugging the 10.29m measurement (the beam size at this distance was 36cm) into the calculator you linked (after converting units), results in:
divergence distance behind aperture: 2.14m
candlepower: 390.9Kcd
The calculator results are not consistent with my measurements and how they vary with distance. There are certainly some things in your explanation of the effect that make sense, but actual measurements tell a different story.
A different effect could have caused your conflicting results when you measured the lux at 1m and 2m. At small distances like 1m, the lens might not be filled with the image of the LED, from the point of view of the lux meter. Moving farther back to where the lens is filled would then result in a larger throw number.
I’m pretty sure the reason people don’t measure at 1m is because a luxmeter can only do like 20000 or 200000 lux, and at 1m an aspheric flashlight is above that by a lot.
That’s interesting. Is the entire lens actually being used to focus the light?
I usually check by making sure there is led light spilling off the sides of my lens, and using a water sprayer to put water in the air so I can make sure the beam is filling the lens.
Your results still show that the farther you measure at the higher the cd you get. Maybe try measuring at 50 or 100m?
I will need to do more tests with different lights to double check.
I really can not follow your story very well, I think that you are simplifying the direction that the rays coming out of a flashlight as if they start from a point source which certainly is not the case, flashlight optics and hotspot size/brightness have everything to do with the led not being a point source.
Hotspot brightness has to do with the fact that flashlight optics are imaging a led at a distance, so it more or less follows the lens maker’s formula creating an image of the led at a distance, smaller led or longer focal distance of the lens=smaller image, . Even reflectors do something similar although the way they ‘image’ is way more complicated.
One consequence is that if the image is created at twice the distance from the lens, the image is twice as large (4 times the surface area) and is thus 4 times less bright.
And my aspheric lights follow that simple: twice the distance from the lens= 1/4 the brightness pretty accurately, even when starting from 1 meter.
Reflector lights need more distance to form their uniform hotspot (they are not focusable like zoomies), but my usual 7 meters indoors is enough, and the simple relation between distance and brightness is followed.
But the lens is not producing a point source of light…
That’s why applying the inverse law of light assuming that the lens is at r=0 is incorrect.
If you had an ideal light source behind a lens, the lens would collimate the rays and the intensity would not change by distance, which would be infinite candlepower.
[quote=Enderman]
No, ever since i started this hobby back when flashlight where much less bright people pretty much agreed on the wisdom that the closer the measuring distance, the less accurate, one or two meters readings have always been considered irrelevant and met with encouragment to measure from farther as far as i can remember, absolutly nothing to do with luxmeter capabilities.
Yes, the entire lens is filled with the image of the LED for the distances I measured. I check by looking into the beam at different distances using sun viewing glasses.
I think it is because of the reason I mentioned above; at close distances the lens is not filled with the image of the LED. You cannot tell this by spraying water; you have to actually look into the beam at the lens.
There are ANSI standards, developed for and by the lighting industry by specialists in the field. There is probably a reason they don’t use if’s and assuming in their definitions. The primary objective is to establish parameters of comparison, to create an equal and repeatable playing field for the purpose of recreative ability in determining the value of one light versus another as suited to a particular task. At the end of the day, deviation from the accepted standard is disqualified summarily as non applicable to the established criteria.
So, in simple terms, if we don’t all use the same test, our results cannot be compared and as such, the tests themselves are disqualified.
Don’t sell us, sell ANSI, then we will adapt accordingly.
An Enderman’s primary purpose is to create chaos and confusion.
it is irrelevant where the imagine source of the flashlight is
you get only higher lumens if you go to a negative distance towards the spot where the light should for a focal point,
but that is physically impossible
if the light has 20mrad divergence it doesnt matter where you put a ideal luxmeter as long as the beam is uniform in brightness,
as a reflector light is not uniform in brightness at close distances, so you have to go further away,
if you are too close you measure too low lumens in the donut hole or too high lumens in the ring where the brightness is concentrated
on a reflector light the spill also affects the measured lux if you are very close
the next factor is that your measurement would need to be taken on an indefinate small point in the middle of the beam,
so the bigger the spot is the less you get a false reading as your luxmeter has a quite big spot to catch light at low distances
It does though…
If you take a measurement at 10m you would think at 20m it would be 1/4 brightness, right?
But if the convergence point behind the flashlight is 100 000m behind, then the difference between 10m and 20m is nearly 0 because 100 010^2 and 100 020^2 are almost the same number.
Unlike 10^2 and 20^2 where the second number is 4x bigger.
Hopefully the 100000m exaggeration is enough for you to picture what is happening here.
Lol I need you to crunch some numbers for me. Then in about a week there will be a tiny upgrade to 1 of my sk68 and 1 sk98 lights. I'm curious what of any difference will be.
I have some higher output cells coming. I'm told I should notice a difference.
If you are up to it, my light meter is built into my phone app. Just let me know at what distance or whatever you may need.
Let me know if you are up to it. I will be typing up a review so it may take me a few minutes to respond. And if you don't feel up to it that's olay too. I know all about being tired. I'm very good at it.
The more the better, because the margin of error when calculating lux and measuring the spot size is lower.
Although it should be in the tens of meters, not hundreds, because then the lux values are too low to be read by the meter
you are wrong
if the convergence point would be 100000m behind the flashlight just the divergence would be really low about 0.000001mrad if the lens diameter is 10cm
at 0.000001mrad the Lux value between 10 and 20m would be almost the same
lets say at 1m I got 100cd
now I got to to 10km
you are just not understanding the difference between a flashlight and a laser
take a laser pointer with 3mm beam and 0.25mrad single Mode diode
I measure at 0m 10000cd
at 1m 3mm+(0,25mrad*1m)=3,25mm spot
calculated 8521cd
at 2m 3mm+/0,25mradx2m)=3,50mm spot
calculated 7346cd
I got 15 years experience with lasers also calculating things trust me
I understand the principle here but I can see why it’s sorta hard to explain and actually using it is also quite a trick. I have a question for EasyB though that may clear some things up, how did you measure the spot, it is of course square so did you measure it’s width or diagonal. I think the correct measurement should be diagonal if you are using the lens diameter as the aperture.
I’m going to do some more extensive tests shortly but as I’ve thought about this in the past I sorta came to the same conclusion as DBC in that in the end it doesn’t matter because numbers are great but if everyone else is just measuring lux at at distance then you are “cheating” kinda, I mean you may be more accurate but for instance in my case selling a light using this more “correct” math means that when people measure it they will come up short and it will be hard to compare with other lights measured in the same fashion. As in for personal uses it’s fine but it’s hard to move out from there.
Then there is the measurement problem, it’s not exactly easy to get really accurate hotspot sizes, sure you’ll be close but there is a lot of messing about and guessing required since the beam is not clearly enough defined at that range. You would have to move the lux meter around to chart the lux change.
However, because this effect gets more and more pronounced the higher the kcd using the “basic” measuring setup may cause some issues because the “basic” measurements will rapidly start generating higher kcd with longer and longer measurement distances. So maybe this is really needed for 1Mcd+ lights. I’m going to try to get some different tests done with our 1-3Mcd prototypes and see if I can get some good comparison numbers.
the divergence would be really low about 0.001mrad if the lens diameter is 1cm
at 0.001mrad the Lux value between 10 and 20m would be almost the same
EXACTLY
THIS IS MY POINT
You can’t take a lux measurement at 20m and then just calculate it back to 10m by 1/r^2 by doing lux*20^2/10^2
Because the flashlight is not where r=0 is!
If the divergence is really low, just as you said, the lux will barely be any different! It will not be 4x higher at 10m compared to 20m!
Good point!
The farther you calculate it, the closer you get to the true value, but users usually do less than 20m measurements so they would get a smaller number than yours.
Measuring the spot size is hard unless you have a highly collimated light with a sharp projection, so tbh this method is not really useful for typical flashlights and reflector lights, it is more for aspheric throwers and sky beams and stuff like the maxabeam.
Also, IIRC the maxabeam was measured at 3M lux at 1meter, but the candlepower is 12 million. So yeah, goes to show how misleading lux can be when calculated incorrectly for those types of lights.
now I got to to 100.000m then my spot is exactly 20cm
so at 100km of the flashlight I get 25cd
if I calculate that lux to 1m I get 25,000,000,000cd
if I measure at 300.000km or one light second
I get a spot of 600m
0,0000027cd
If I calculate that to 1m
I get 250,000,000,000cd
so for this almost perfect thrower the distance to get an accurate reading would be a couple of light seconds away
there will be a point where the cd doesnt raise anymore
how far that is away depends on the divergence and lens diameter
as flashlights are really bad on divergence that point is really close to the light 5-10m should be fine
just go further out and when the calculated CD value dont increese anymore the reading is accurate
measured 8521cd
measured 7346cd
if I calculate that to 1m I would get 29384cd
at 100m 3mm+(0,25mrad*100m)=28mm
measured 115cd
if I calculate that to 1m I would get 1,150,000cd
at 100km 3mm+(0,25mrad*100,000m)=25003mm
measured 0,00144cd
if I calculate that to 1m I would get 1,440,000cd
for a Laser that will be in the range of a couple hundred meters to kilometers
it all depends on ratio for divergence and lens diameter
Yes good job, now you’re basically saying the same thing I did in the original post.
For most people with regular flashlights, it doesn’t really matter.
For HIGHLY COLLIMATED lights such as aspheric lights or short arc lights (eg the maxabeam) then YES there is a significant difference between just measuring lux at a few hundred feet vs actually calculating the real candlepower due to the highly collimated sub-1 degree of divergence.
It does NOT need to be a laser, anything that partially collimates light is affected by this property.
This is why if I measure my light at 5m it gets a different cd rating than if I measure it at 10m or 15m.
I honestly don’t understand why you’re even trying to argue, you’re basically proving my point a second time…
