Extended View :
Flashlight :
UT02 length : 84mm
Max UT02 diameter : 22mm
UT01 ?
Extended View :
Flashlight :
UT02 length : 84mm
UT01 ?
Thanks for saying this - https://www.youtube.com/watch?v=PQHn1BFt-u0
The user manual is a complete photocopy of the Manker E11’s, just without the Manker logo.
Without trying to sound too controversial, may I ask if this torch, and the UT02, have been copied out of spite for Manker?
Btw, thanks for the review, giorgoskok. I’m now going to buy more than one.
Sorry , UT01 i meant .
So, only 0.3-0.4mm length difference makes such a damage... :(
I guess that there might be even some IMRs that won't fit then.
Anyway, I've ordered a pair of 49.5mm UR14500P and a pair of 50mm TF IMR14500, so I will have 14500s that fit, but... do you think that there might be a problem with flat-top cells? Will the UT01 work with these?
They will fit.
Most IMR without button top work ok
Thanks, George.
(Still naively? hoping for a shorter/protected/quality cell out there or a work around)
Thanks Giorgos! :+1:
Give us the lumen/cd data now, cause I can’t wait… I wanna order this little AA monster and compare it ot Mi7!
I will update the post when i have these values , be patient
I was, till I saw the first part of your review!
Only think that it needs special treatment is the length of the battery , nothing more .
Updated OP with intensity measurements .
Now running runtime test (Medium mode , 14500 battery) .
Tomorrow will update with amperage draw on AA and lumens . These should have been updated today but i had zero free time…
Thanks for the info.
I don’t want to pull the thread off track at all……but somebody help me. This was in the OP:
Eneloop AA 2000mAh :
Amperage Draw :
Lowest –
Low –
Medium –
High – 4.2A to 3.3A
I am not going to claim any sort of knowledge here…but how does a AA put out 4.2A??? I don’t understand all these currents, draws etc.
I wrote it that ways because i see 4.2 amps in my clamp meter for some seconds .
Don’t forget that UT01’s driver , when you insert a AA battery acts like a boost driver . boosts 1.5 volts to 3V that led operates .
Also measured output with AA , high mode is about 340-350 lumens .
Thanks, this has been a helpful review!
I’m not a fan of mode memory in an EDC light - do you know if there’s any reasonable way to disable this, like a solder blob across key contacts on the driver?
Thanks!
If you short click to enable light , always starts on lowest mode .
Only longer click has the memory .
Andyman: giorgoskok:Updated OP with intensity measurements .
Thanks!If you short click to enable light , always starts on lowest mode .
Hm - OK, thanks! I thought I saw in the other video review that a regular “on” click takes it to the last-used mode.
Short-click to low sounds perfect though!
Cool thanks for the review!!
Can’t wait for mine. Shipping is REALLY slow.
Mine is stuck…
“Awaiting International flight - Airline Inspection” since 12/7.
Hopefully its just a laggy tracking update.
EDIT: Sorry…wrong thread.
Trying to decide between this and the Klarus Mi7. What are people’s thoughts on how they compare?
