Thanks for saying this - https://www.youtube.com/watch?v=PQHn1BFt-u0
The user manual is a complete photocopy of the Manker E11ās, just without the Manker logo.
Without trying to sound too controversial, may I ask if this torch, and the UT02, have been copied out of spite for Manker?
Btw, thanks for the review, giorgoskok. Iām now going to buy more than one.
evankouros
(evankouros)
December 11, 2016, 4:16pm
30
So, only 0.3-0.4mm length difference makes such a damage... :(
I guess that there might be even some IMRs that won't fit then.
Anyway, I've ordered a pair of 49.5mm UR14500P and a pair of 50mm TF IMR14500 , so I will have 14500s that fit, but... do you think that there might be a problem with flat-top cells? Will the UT01 work with these?
giorgoskok
(giorgoskok)
December 11, 2016, 4:19pm
31
evankouros:
So, only 0.3-0.4mm length difference makes such a damageā¦
I guess that there might be even some IMRs that wonāt fit then.
Anyway, Iāve ordered a pair of 49.5mm UR14500P and a pair of 50mm TF IMR14500 , so I will have 14500s that fit, butā¦ do you think that there might be a problem with flat-top cells? Will the UT01 work with these?
They will fit.
Most IMR without button top work ok
Freedom
(Freedom)
December 11, 2016, 4:26pm
32
Thanks, George.
(Still naively? hoping for a shorter/protected/quality cell out there or a work around)
evankouros
(evankouros)
December 11, 2016, 4:28pm
33
Thanks Giorgos! :+1:
Give us the lumen/cd data now, cause I canāt waitā¦ I wanna order this little AA monster and compare it ot Mi7!
giorgoskok
(giorgoskok)
December 11, 2016, 4:39pm
34
I will update the post when i have these values , be patient
evankouros
(evankouros)
December 11, 2016, 4:43pm
35
I was, till I saw the first part of your review!
giorgoskok
(giorgoskok)
December 11, 2016, 9:24pm
36
Only think that it needs special treatment is the length of the battery , nothing more .
giorgoskok
(giorgoskok)
December 11, 2016, 9:54pm
37
Updated OP with intensity measurements .
Now running runtime test (Medium mode , 14500 battery) .
Tomorrow will update with amperage draw on AA and lumens . These should have been updated today but i had zero free timeā¦
cdjaney
(cdjaney)
December 12, 2016, 5:04pm
39
I donāt want to pull the thread off track at allā¦ā¦but somebody help me. This was in the OP:
Eneloop AA 2000mAh :
Amperage Draw :
Lowest ā
Low ā
Medium ā
High ā 4.2A to 3.3A
I am not going to claim any sort of knowledge hereā¦but how does a AA put out 4.2A??? I donāt understand all these currents, draws etc.
giorgoskok
(giorgoskok)
December 12, 2016, 5:15pm
40
I wrote it that ways because i see 4.2 amps in my clamp meter for some seconds .
Donāt forget that UT01ās driver , when you insert a AA battery acts like a boost driver . boosts 1.5 volts to 3V that led operates .
Also measured output with AA , high mode is about 340-350 lumens .
Andyman
(Andyman)
December 12, 2016, 5:44pm
41
Thanks, this has been a helpful review!
Iām not a fan of mode memory in an EDC light - do you know if thereās any reasonable way to disable this, like a solder blob across key contacts on the driver?
Thanks!
giorgoskok
(giorgoskok)
December 12, 2016, 5:47pm
42
Andyman:
Thanks!
If you short click to enable light , always starts on lowest mode .
Only longer click has the memory .
Andyman
(Andyman)
December 12, 2016, 5:53pm
43
giorgoskok:
Andyman:
Thanks!
Hm - OK, thanks! I thought I saw in the other video review that a regular āonā click takes it to the last-used mode.
Short-click to low sounds perfect though!
kramer5150
(kramer5150)
December 12, 2016, 6:28pm
44
Cool thanks for the review!!
Canāt wait for mine. Shipping is REALLY slow.
Mine is stuckā¦
āAwaiting International flight - Airline Inspectionā since 12/7.
Hopefully its just a laggy tracking update.
cdjaney
(cdjaney)
December 12, 2016, 7:41pm
45
EDIT: Sorryā¦wrong thread.
lumiere
(lumiere)
December 12, 2016, 7:54pm
46
Trying to decide between this and the Klarus Mi7. What are peopleās thoughts on how they compare?
peteybaby
(peteybaby)
December 12, 2016, 8:16pm
47
I was trying to make that same decision. What clinched it for me was that I want my light to come on in the lowest mode every time, and be able to cycle up through the higher modes, which the UT01 can do.
