At first I didnāt use any but it didnāt work in an acceptable way. So I put a 470 in it, because thatās what I had on hand. Iāve used up to 6-700 ohms before with good results. My driver now works pretty much like the tailcap isnāt even there, although it is now possible for me to click too fast to enter the programming. I have to kinda slow down just a bit when doing those 15-or-whatever clicks or it never registers. Not a big deal at all.
thatās not corrosion, many cree leds have that and presumably itās from testing the leds at production time or some of the production steps involves using heat thatās why you have central pad discoloration
It could be corrosion, or oxidation, because itās where the holes in the reel tape are, and theyāre ānew old stockā so they must have been stocked somewhere for quite a while.
Cheap too at $5.75 for 20 pieces.
And itās the last generation of the super tiny die Cree LEDs, so it should be fun in AA zoomies.
First i had to figure out the chromaticity coordinates, but iįøæ glad i could choose āWDā, which is 1D and 2A.
They also have āWJā which is 2D and 3A.
My Employer gave me a Helping Hand today. OK, Sortaā¦
They did unknowingly Sponsor this build with parts and time. Nice when the Dept Super is on Vacationā¦
Idea from PilotDogās link, maybe, in this thread?
The flex hoses we use on machinery at work. Of course I dug up new ones for my personal build. Found the powder coated steel blocks on parts shelves and had 2 pre-drilled holes in each. Used some MEK to melt the powder coat and clamped the 2 blocks together in a vise till they were fused together. No glue just the PC acting as glue. Drilled the holes to size and tapped for the fittings. Still need to mount up some alligator clips. Base is pretty heavy, enough to hold what I will be using it for.
Similar items sell for $55 and mine wasā¦ Ummā¦ paid for by my generous employer. Actually only took 20min to make. Need to remember to a get a piece of adhesive backed rubber pad tomorrow, for the base.
Well, oxidation is a form of corrosion and yes it is exactly where the holes are in the tape. And Sirius, that certainly doesnāt come from production or testing. Those are LEDs that werenāt stored properly, under too humid conditions or something like that. Shoot the seller a message if you receive LEDs like this. I received a few that looked like this. Used very fine grit sand paper to sand off that stuff and reflowed them right after. I mean they worked fine, but thatās not how I want to receive my LEDs, especially expensive ones. I can overlook that if itās a cheap LED, but if I pay 7,99$ for one XP-L HI or something, than Iām quite pissed if they look like this and I let the seller know.
Yet another X6 triple. The baked brown finish was shown 6 or 7 weeks ago. Iām not always this slow. So this is an Eagle Eye X6. First baked. Then the tail cap received a wire bypass. The driver is the MTN17DD NUV FET+ 7135 with Bistro firmware. The triple Noctigon has Cree XP-L V6 3C emitters and the Ledil optic is the Cute3-SS version. The copper spacer is from Kiriba-ru. I used ceramique heat transfer paste between the MCPCB and spacer as well as the mating surfaces of the spacer to head. I retained the glass with the O-ring between the glass and the optic. It seated okay with the bezel fully screwed down to the head.
I have run it on a 30Q flat top and Wow!, it sure is bright on turbo!!
I have not run a amp test but will get around to that sooner than later I hope. Iām also looking forward to getting the integrating sphere and will check the output when it arrives. Right now all I can say is it is BRIGHT!! on turbo and very very low on Moonlight. Very cooll!! And I really like the optics beam pattern!
Did you happen to have any trouble with the MtnE 1.6mm thick driver? On my EE X6 Triple I needed to apply a layer of solder on the outer ground ring, making it thicker, to get good contact under the retaining ring.
My BD04 driver did not come out as pretty and I removed one of the chips because I thought I got it to hot and had a problemā¦ I was wrong, oh well + 3 better than +0!
Thatās the first time I see a baked X6, well done!
ā
I got my 2 W2 emitters today from AE. One was 1C and the other 1A, both tints are very similar with the 1C producing a bit of greenish tint in the lower modes and some in the spill, pure CW in turboā¦ I thought it would be a bit neutral but no. It replaced a XPL HI in a EE X2R and it seems a lot brighter. Now Iām unsure about what to use for a triple build, these W2s or the new XP-L2.
Pretty simple one today: My clear-ano Convoy C8 came in a day or two ago. It came with a translucent tailcap. I donāt know why these manufacturers keep tempting me with these tailcaps. Theyāre basically begging to be illuminated from within. So I did:
I think I finally figured out a way to illuminate the triple optics in my F13. I cut off a small section of one of those RBG strip lights and pulled the components off. I think they are 0505 LEDsā¦not sure. Tested all the pads to see where all the traces went then soldered on some smaller LEDs. It tested just fine when I connected it to an 18650, so it should work once I hook it all up. Iāll need to run something up from the driver for this, so need to figure that out as well.
Made myself an extra constant light output light for testing purposes: Supfire A6, AK-47C driver with one chip removed=700mA, XP-L U6 5A 80CRI on a KD-DTP-board, big Omten switch. 20 seconds after switch-on it is constant 240 (djozz-)lumen and stays that within 1% for about 10 minutes (still rock stable after that but just falls outside the 1%).
