I was trying to make that same decision. What clinched it for me was that I want my light to come on in the lowest mode every time, and be able to cycle up through the higher modes, which the UT01 can do.
I had the MI7 and the Manker E11 (the Original of this clone) and kept the Manker. Both are excellent AA/14500 lights with lots of power, but the beam pattern is completely different. MI7 has XP-L Hi and is more like a little thrower (tight bright spot and much darker spill) , and it´s only available in cold white. The Manker on thr other side is much floodier, which I prefer as an EDC that is also used indoors. Plus it´s available in neutral white.
K.
…pushing past the above and entering uncharted areas of ignorance (on my part)…are there ever enough threads on these unprotected lights to simply grab a few when inserting a protected cell (not fully tightened)…while then reaching for my favorite ‘fix’ this side of tie wire…Gorilla tape?
I could care less what a light looks like if it works with a protected battery.
