Honestly I did not think I would like it. I was going to leave it here for my wife.
Truth is I am keeping it. Making it my EDC at work. I do wish it had a belt clip and the little rubber cover for the Micro USB is kind of irritating really only because of the tiny little tip of it. I snipped that off and now that cover does not get snagged all the time.
Arrived my first TIP winter Ed. (from bg this unit)
Confirmed that after lockout if I press any button, the switch not blink (my previously TIP blink the switch after lockout if I touch it)
I was looking for a torch that took 3xAA for friends that don’t like Li-ions and found this zoomie. Pretty good for the price (£11.70 BangGood). LED looks like a genuine XM-L2. It can also take a 26650. With a fresh 26650 I measured 1.4A on high and 350mA on low (so room for improvement).
I like the zoom feature - gives you both a thrower and a flood in one. Access to the battery is a bit complicated though… you have to unscrew the end cap and then the charging piece before you can get to it.
It does come with a nice Sanyo sourced 18650 3350mAh protected battery.
It is a Spanish knife of the brand Aitor (it is an old knife that I found years ago in an armory that was going to close the business, it was in the back room)
Thanks, its stunning and i mean that, the xpl HI 4000k, xpl HD 4000k, then 219C 5000k and 219B 5000k blend beautifully for a 4500k wall of light.
Not sure of the output tbh, but going off quad p60 mules its not much different………….its very very bright! even on an IMR18350 ! Has drivervn4, can set the heat temps, turbo timers
Driver
DriverVN4
Programming Instruction
Step 1: From Off or On quickly tap the switch 10 times to enter Programming Mode. A dim slow blink will initiate.
Step 2: Tap the Deck number. A dim fast blink will initiate.
Step 3. Tap the number of mode group. A double blink & 1stmode in group will initiate.
Toggle Programming Lock
10-11-10
Toggle lock or unlock current Mode Group settings.
Any Mode Group in Deck 2 automatically initiates Programming Lock
Turbo Timer
10-12-T ( Default 10 minutes)
T= Time you want Turbo to run
Turbo = Maximum brightness
After entering Deck 12 light will initiate Turbo. Let light run until desired felt temperature and or time. Turn off to lock in Turbo Timer.
Mode Groups
M = Last mode memory. Light will initiate last mode at next turn ON if light is off longer than 1/2 sec. Mode Group without M will always start with 1st mode.
D = Double Tap. At any mode double tap switch to activate Hidden/Last mode.
F = Firefly = Lowest possible brightness
S = Strobe
So many options to suit most users there, i like 2 mode simplicity no memory or 3 mode no memory like 5/33/100. 2 mode i like 25% level as this tends to be enough for 95% of my uses, no memory again so you know what to get, Set turbo timer and set temp to 185F as a back up.
