DQG Tiny 4
I HAVE FOUND IT !!
Yesssssss !!!
Soooo tiny….
Now back to reassembling the PCB…
Yeah that sucks…
Mine came off too eventually, but i’m gonna fix it with grey epoxy.
No chance it will come off again.
It’s a shame this light is so poorly thought out regarding the PCB.
Well, all the parts are back in place again.
Quick test showed it works, but not sure about the modes yet. (fumbling with tweezers as a switch)
I put the switch back on too with a bit more solder and a blob of grey epoxy.
Will be able to test in a few hours.
I’ll put up a pic of the result and how i secured the switch.
And if all is well, i’ll take off the XM-L2 and see if what can be done about the non existent heat management.
That went faster than expected, so here is the picture:
And it works as it should too. :slight_smile:
Grey epoxy blob behind the switch.
I put some in between switch and PCB as well.
And now hope to find a proper solution for the total lack of heat management.
lot of work!
curious what you can do about the heat problem, that is the reason it;s tiny after all…
if you get the heat out, then the outside will get hot(ter).
mine gets pretty warm just on high, not even turbo
wle
It took a while, yes…
Good Lord those SMD parts are tiny… :confounded:
Found another design flaw that really helps breaking the switch off the PCB too.
I will show you later.
My guess is they had better plans but it turned out to be too expensive to produce.
Either that or it’s just a bad design.
Not sure what to do yet, but i have some ideas.
Like a copper ring on top of the LED in contact with the shelf, and making the + pole a disc with a seal pad between it and the brass ring that now has the foam rubber on it.
Then a thermally isolated iron battery contact, but maybe that’s not necessary.
It’s a challenge…
That’s the idea of a thermal path, isn’t it?
Like this the heat is only transferred to the battery top and nowhere else.
Imagine how hot the LED will get… :person_facepalming:
Welcome to modding 101.
Some of these lights it seems like they spent more time designing mod defeats than actually worrying about the light. That emitter on board stuff is ridiculous, I don’t know why they haven’t figured that out yet.
Good luck! :slight_smile:
It could have worked with a copper or even aluminium board, but it’s just regular epoxied fiberglass (or whatever PCBs are made of normally).
I can hardly imagine this was the original plan.
DQG tends to try to make the smallest possible light for a given format. They can shave off several mm by putting the emitter and driver on the same board instead of using a separate star. Zebralights are built the same way.
Unfortunately, this does make them much more difficult to mod.
Hmmm…. It seems the easiest way to solve cooling problems is making it a triple…
Make that R010 resistor a direct bridge for a bit more turbo and just put one of my Kaidomain 219C triples in there (when they arrive) and forget about solving impossible things…
direct bridge give You ~2.3A at Turbo
FET also has a resistance
Hmm… 2.3 Amperes : 3 = 0.77 Amperes per LED in a triple… That’s not much…
No, i will try to fix the thermal issues as it is now.
Keep it a single LED light.
Maybe i can make it work. :slight_smile:
Just checked. With triple nichia (warm white from fasttech) turbo on a freshly charged battery 18650-25R is 2,08A… (R010 changed to the R000)
Okay, that’s low…
But those are 219A Nichias.
219C has significantly lower Vf so will probably draw more current.
Either way, for a triple this driver is not powerful enough i.m.o.
I took off the XM-L2 anyway, and i will try to make a tiny 5 x 5 x 1mm thick DTP MCPCB to put one 219C on.
The TIR works better anyway when it is mounted over a 3535 in stead of mounted on top of a 5050, i just checked that out.
Wish me luck… :confounded:
My first DQG 26650 was a triple, I removed the mcpcb and used a standard Noctigon triple (went to parallel instead of series) and then used an FET driver with ramping firmware to make it a really nice little monster. :slight_smile: Gave that one away in a post count giveaway, sold my grey DQG 26650, ready for this new one with it’s awesome 7 emitters to play with. :wink:
I’ve done similar to a Zebralight SC52, put a ramping FET driver in it for 1117 lumens on a 14500 with an XP-L emitter.
The tiny lights are a fun challenge, these in particular are a booger to work on but when successful they’re so much fun! :smiley:
I decided to keep the stock driver.
Otherwise i would probably make it a triple 219C pocket rocket. :slight_smile:
Now it will be ‘just’ a modest single LED EDC light with (relatively) long battery life and enough cooling.
Just ordered some silicone carbide too to pot the space between PCB and head shelf, in combination with grey A+B epoxy.
I’ll drill a 2mm hole through the tiny 5 x 5 mm MCPCB (which i will make from the replaced 16mm one from my B158, it will get a 219C on it), throught the PCB and through the brass plus contact thingy, put a short 1.8mm copper rod through it to keep everything in position for reflowing.
I will take pictures to show it.
For now i’m struggling with a nasty neck ache, can hardly move my head without screaming…
Later…
Modding 102, the aches and pains of the flashaholic…
Definitely makes it difficult to accomplish a tight mod when the neck is uncooperative!
Take care, take drugs, get to feeling better soon…
lol thanks.
Thankfully it’s getting better now.
I think it’s these:
$ 0.74 for 50 pieces…
could be that, but it has to fit EXACTLY and be EXACTLY the same size
this one looks different, has rectangular button instead of round
wle
