Received a text message from DHL about a shipment on the 15th—-these lights are the only thing I’m expecting from Hong Kong
A completely different tracking # also
Destination Country - Tracking Consuming: 257 ms
Origin Country - Tracking Consuming: 2458 ms
2016-12-10 15:52 Despatched to overseas (Country code: US)
2016-12-08 15:51 Received from Customer
How do I track it now that it’s in the states? I tried USPS and nothing showed up.
Hi.
The package has arrived and the lights are in the house, but I am not
…but I have seen the pictures.
(BTW: The number HAIKElite sent us (DHL number) is a ref number found on the package.
They should have sent the WAYBILL number (that is the correct one for tracking), also found on the package.)
Anyway, thanks HaikeLite and Alva.
“those who wait for something good does not wait in vain”
edit :
Please check 35mm Copper DTP Emitter board first !!!
It held down by 1 screw and loose, that’s why I measured lumen drop so fast.
(I added another 1 screw)
Thanks POK for the advice on checking the screw. I haven’t received mine yet but will be looking into it. Not having seen it, did you have to create another thread for the second screw or is there already another thread?
Thanks
Anyone having any issues with their MT03s? Ordered three, and all have this problem. Medium mode does not work. When cycling through the modes, when it gets to “medium” it just flashes once, and doesn’t get any brighter. Has the same brightness as “low” mode. The rest of the modes seem to work properly. The lights involved are all 4S models, two nw one cw. Batteries used are Sanyo 18650ga.
Well, just tried some 18650Bs in one, and now I have medium mode? Of course, I can’t tighten down the tailcap. All three lights that exhibit this behavior have different sets of the 18650GAs. Weird. Any ideas why this could be occurring?
Hhmm, the MT07 is quite low but it is NW, not CW. Mine is doing 5,300 now w/resistor mod, but was 4,700 stock. Still 3,500 you got is quite a bit lower than the 4,500 they rated. Wonder if the 4S is lower lumens...
