Photos of your new arrived lights
Finally get to post here after a long while.
ThorFire BD04 + bike light from Amazon for about $13
FandyFire G36 modded with 3x XHP50s. Silly bright for the size, gets hot quick. :smiley:
Anker LC90 zoomie:
Anker LC40:
JetBeam JET-1 MK:
Why is it that these Jetbeams look so pretty?
what do you think of the Anker lights, specifically LC90 ?
I like the zoom feature - gives you both a thrower and a flood in one. Access to the battery is a bit complicated though… you have to unscrew the end cap and then the charging piece before you can get to it.
It does come with a nice Sanyo sourced 18650 3350mAh protected battery.
They’re calling your name. :smiley:
If I have to believe all these lights calling my name, I must be very loved :slight_smile:
The ultimate tactical interface is here… :smiling_imp: , I love it.
MecArmy SPX10 (my second MecArmy, first was SGN3)
Hi Trevi_lux
What’s the knife?
It is a Spanish knife of the brand Aitor (it is an old knife that I found years ago in an armory that was going to close the business, it was in the back room)
(Maybe a diving knife, I do not really know)
Received both the other day. Beautiful flashlights :slight_smile:
Acebeam H10
Nice! How’s the beam? Pretty much a wall of light huh?
I have an E14vn with 219c and with the optics, it makes the beam greenish. I’m now thinking about Just running it as a mule.
Thanks, its stunning and i mean that, the xpl HI 4000k, xpl HD 4000k, then 219C 5000k and 219B 5000k blend beautifully for a 4500k wall of light.
Not sure of the output tbh, but going off quad p60 mules its not much different………….its very very bright! even on an IMR18350 ! Has drivervn4, can set the heat temps, turbo timers
Driver
DriverVN4
Programming Instruction
Step 1: From Off or On quickly tap the switch 10 times to enter Programming Mode. A dim slow blink will initiate.
Step 2: Tap the Deck number. A dim fast blink will initiate.
Step 3. Tap the number of mode group. A double blink & 1stmode in group will initiate.
Circuit Temperature Sensor
10-10-F (Default 160F)
F1= Off, F2 = 105F, F3 = 115F, F4 =120F, F5=130F, F6=14F0, F7=150F, F8=160F, F9=170F, F10=175F, T11=185F, T12=200F
Toggle Programming Lock
10-11-10
Toggle lock or unlock current Mode Group settings.
Any Mode Group in Deck 2 automatically initiates Programming Lock
Turbo Timer
10-12-T ( Default 10 minutes)
T= Time you want Turbo to run
Turbo = Maximum brightness
After entering Deck 12 light will initiate Turbo. Let light run until desired felt temperature and or time. Turn off to lock in Turbo Timer.
Mode Groups
M = Last mode memory. Light will initiate last mode at next turn ON if light is off longer than 1/2 sec. Mode Group without M will always start with 1st mode.
D = Double Tap. At any mode double tap switch to activate Hidden/Last mode.
F = Firefly = Lowest possible brightness
S = Strobe
Deck 1 – Simplest
10-1-1 => 100
10-1-2 => 5/100 M
10-1-3 => 5/100
10-1-4 => 100/5
10-1-5 => 25/100 M
10-1-6 => 25/100
10-1-7 => 100/25
10-1-8 => 50/100 M
10-1-9 => 50/100
10-1-10 => 100/50
Deck 2 – Lenders with Auto Programming Lock
10-2-1 => 30
10-2-2 => 7/30
10-2-3 => 1/7/30
10-2-4 => F/2/10/30
Deck 3 – General Users
10-3-1 => 5/33/100 M
10-3-2 => 5/33/100
10-3-3 => 100/33/5
10-3-4 => 1/15/100 M
10-3-5 => F/15/100
10-3-6 => 100/15/F
10-3-7 => F/33/100 M
10-3-8 => F/33/100
10-3-9 => 100/33/F
10-3-10 => 15/100/F
10-3-11 => 33/100/F
10-3-12 => 50/100/F
Deck 4 – Goldilocks
10-4-1 => F/5/33/100 M
10-4-2 => F/5/33/100
10-4-3 => 100/33/5/F
10-4-4 => F/5/33 D for 100
10-4-5 => F/2/25/100
Deck 5 – 5 Level Precision
10-5-1 => F/1/20/50/100 M
10-5-2 => F/1/20/50/100
10-5-3 => 100/50/20/1/F
10-5-4 => F/.7/3/25/100
10-5-5 => F/1/5/25 D for 100
Deck 6 – 6 Level Precision
10-6-1 => F/1/5/15/50/100 M
10-6-2 => F/1/5/15/50/100
10-6-3 => F/100/50/15/5/1/F
10-6-4 => F/.7/2/7/25/100
10-6-5 => F/1/3/10/30/100
Deck 7 – Tactical
10-7-1 => 100/S M
10-7-2 => 100/S
10-7-3 => S/100
10-7-4 => 100/20/S
10-7-5 => 100/25 D for Strobe
10-7-6 => 15/100/S MD for Strobe
10-7-7 => 5/33/100 M-D for Strobe
10-7-8 => 3/5/33/100 M-D for Strobe
Deck 8 – Discos & Bicycle
10-8-1=> 10/25/50/70/100/BikeLo/BikeHi
10-8-2=> 5/33/100/Blink.5Hz/Blink1Hz/Blink3Hz/BikeHi/Blink8Hz/S/Beacon
So many options to suit most users there, i like 2 mode simplicity no memory or 3 mode no memory like 5/33/100. 2 mode i like 25% level as this tends to be enough for 95% of my uses, no memory again so you know what to get, Set turbo timer and set temp to 185F as a back up.
Stunning is all that springs to mind tbh
Wow… !! thats impressive
A lot of beautiful lights. That custom E14 is indeed impressive ven. My posting has a little less art to it but its growing on me since I’ve started using it. It’s TM28 with 4x XHP35. I too got the Christmas Tip and had dismissed the Thumb but now that I see Mr Simple with it tucked in like that I’m going to check it out. I think I want that one too.
Been a busy couple weeks!! All new additions. The Manker and Utorch came today.
Thanks
Very cool, very nice touch too with the flat to button top converter……………not seen that before!!!
