Anyone can help me with pill-less C8 internals measurements?
I have a convoy host laying around, what measurements do you need?
Is there a triple/quad optic for the C8?
Hi,
my parts came some weeks ago. Took a while to build all lights. Parts fit perfect, thanks kiriba!
Eagle Eye X7
- 3x Nichia 219C D280
- Ledil-Cute-3-SS Narrow Beam
- MTN17DDm Bistro
- 2700 Lumens
Eagle Eye X6
- 1x XP-L HD
- Kathod PL1672 Ultra Narrow Punch Beam
- BLF X6 Bistro Driver
- 60 Klux
Olight M22 Warrior
- 3x XP-G3 S5 3C
- S2 Spacer + sanded Noctigon XP20 soldered on top
- MTN17DDm Bistro
- 3300 Lumens
Convoy M2
- 4x XP-G3 S4 2D
- Carclo 10621
- MTN17DDm Bistro
- 3500 Lumens
Regards
Kenjii
Great photos Kenjii!
Im not sure that youve got pl1672 from me, anyway what do you think about the beam?
Ok, here is the best I can figure based on that picture, keep in mind that my calipers are fairly cheap so the accuracy is not super exact.
The MCPCB shelf is - 21.68mm
Depth from top of threads to shelf - 33.68mm
Depth from threads to top of shelf - 31.78mm
PCB depth - 1.9mm
Straight bore side (34.1 in your drawing) - 34.31mm
I am not totally sure what you are wanting with the 15.6 measurement, are you wanting the bore size at that depth? If so it appears to fall just on the edge of the straight bore I measured at 34.31mm. It may be very slightly wider then that due to falling right on the corner.
What optic do you have in mind for a C8 build?
Very nice! Any beam shots? Particularly of that Kathod PL1672? How does the beam compare to the stock reflector?
Hi,
no beamshots of the Kathod PL1672 at the moment and i am sure i got it from you, kiriba. I will take beamshots next time. The beam is quiet nice and broad compared to the stock X6. I had some seroius problems centering and focussing this thing. XP-L HD worked, XP-L Hi didn´t work. Ugly spot and less range. The spot is now about 4-5 times bigger than the stock X6 but much less spill. The spill is useable but decreases from the spot to the side. I have a ring in the beam from the centering adapter but this can only be seen on the white wall. It is gone after 3-4 metres distance. I hoped that the datasheet is correct but it wasn´t. The lens should do 150cd/lumen which should be about 200 Kcd, but this can not really be achieved.
Regards
Kenjii
Much thanks.
I have found much more simple solution for liner so 15.6 dimention is not needed.
It is not very fast to type from mobile, please read upd.2 here:
Kenjii, you need to improve your datasheet reading skills. There is just 29kd/lm for xpl there. 150 should be right number for XQ-E Hi.
Are 20mm quad cutter boards in stock ? Or will in the future ?
I can found one for you.
Well, I dont know how to deal with them. Australian company is ordering boards in China. Then Richard from MTE orders them from Australia. Then I order boards from MTE and because he dont offer direct shipping to Russia Im using post transfer servise with virtual adress in the US (I can combine several orders and then they are making shipment). If Im lucky and my package passes through the customs I will get them for twice cutters price.
And…after all I have lots orders and more than half of them goes back to the US and even Australia.
In fact I hate cutters design, I hate solder them by myself.
We need to organize 20mm quads production. Technology does not change with led dimentions and quantity, board self-cost depends only from its size and material. 20mm boards should not be more expensive that noctigon xp20 or xm20.
There was a company on here a few months back offering small batches of custom MCPCB’s for a good price. Djozz ordered the custom 144A MCPCB’s from them for around $2 each IIRC, he had to buy 150? of them I think. Might be worth looking into.
I think minimum order quantity for quad boards was 250pcs , to cover design fees (something like that).
What kind of spacer is needed for the M2 quad? I’m interested in making one or two myself.
Check number 9. @ the OP
Oops, should have checked there first! Thanks
Guys, need some advice from you.
Most popular parts (that were known for years and was produced long time before I started), such as S2+ spacers and pills and X6 spacers, their hosts have very limited place inside so parts top have same OD to the MCPCB size.
After Ive tried to solder copper pcb to such plane spacer with solder paste I have realized that pcb goes to the size and it is not very simple to center it.
So, next kits such as X5, M2 (M1) were made with little improvement, hosts have some spare place inside (spacers OD is bigger than MCPCB size), so they were made with rim over pcb plane to center pcb perfectly.
Is there any need in such rim? It makes soldering more easy (Ive seen when smb have soldered parts with bolt inside cental hole ), but if you dont solder parts and use thermal grease you may want to have ideal finished surface, and this is hundred times harder for such lowered shelfs.
So, what would you prefer?
- Spacers with pcb centering rim with current surface finish (you can find photos in this thread)
- Spacers with plane pcb shelf with better surface finish (#120 sanding belt)
For this moment your suggests will influence on C8 triple spacer design, but I will also consider them for the other parts.
I vote option 1, I am not super picky about the surface finish myself. as the host will still overheat in a min or 2 with or without a perfect finish in the lights I build lol.
- me too .
I use fine sandpaper and spacer is ready in 20 seconds .
Hi,
bad conditions. A construction trailer blocked my beamshot location and my tripod broke one leg.
Regards
Kenjii
Distance to the bridge is about 45metres Nikon P100, f=4,0, 0,5 Sek., ISO=800.
Controlshot
Eagle Eye X7
Eagle Eye X6
Astrolux S2
Olight M22
Convoy M2
