80W Billboard light
Hi, this is Anna. Our company would like to install the 80W Billboard light, any recommendations?
Nice Optic
Regards Xandre
How big is the sign and are you planning on building or buying the light(s)?
a regular 5M led light strip is, as an example, 2A at 12V and I have seen them used as cheap billboard illuminations, although they are not the brightest.
Tell us more about the requirements, maybe?
thanks.
The area is about 200*100ft, with some protruding, irregular items affixed on it. We have poles around an edge. What is 5M strip? Thanks a lot.
sounds like you should be consulting a lighting contractor for something that large.
That should be pretty bright with a 5M strip! :smiley:
Do you have any suggestions? Thanks
Something like a high power flood light
Construction site lighning should have powerful LED lights
I am also thinking of 1000-2000W LED flood light.
What is the price?
well, with a sign of that size please omit my idea of a LED strip. In fact, this sign is so big it is barely a DIY solution. To follow building/construction codes and to ensure overall safety the aforementioned hint to a commercial contractor is the correct one.
Check yellow pages, yelp, ads, … to find the right one in you area.
This is true :wink:
