Oh, I’m 100% positive the tail cap marked with Manker branding is on the Utorch… the outside is branded UT02 on that tail cap, can’t really miss THAT!
FWIW, the Moli 26700 fits in both lights.
“When I took the tail cap off the Utorch UT02, SURPRISE! It clearly says Manker on the pcb the spring is on!
Oddly enough, looking at the tail cap off the Manker it Does Not say Manker! lol”
This world is messed up rofl. What’s next? A Manker light named Utorch…
With the lights on, I see some unclean issues inside… Any guesses which one is worse?
The Utorch has a film on the inside of the lens but the reflector is incredible. The Manker has a finger touch/smudge on the reflector, one major and one minor.
Maybe a Manker light with Utorch pcb?
Is it possible to swap the Utorch with Manker’s switch cover? The dragon eye looks cooler, imo.
I have even installed a rubber boot from L6 in mine
The finger smudges on the reflector of the U21…
Both lights reflectors are like large versions of the Manker X6, threaded and with the ramped o-ring shelf on top, the bezel pushes the lens against the o-ring which in turn seals against the reflector and flares against the sides of the bezel. I like this design.
The above 3 pics are from the Utorch, below are from the Manker…
On both lights, the bezel text lines up with the switch, very nice, the Manker battery tube flat with the name on it also lines up.
Very odd but I am unable to unscrew Manker battery tube from head. No matter how much force I use it won’t let…
Looks like some epoxy from driver catch the threads and it’s stacked?
On UT02 driver is just pressed to fit no glue at all.
If manker bumped down the current because of problems, it makes me question the driver in general. I was going to resistor mod the ut02 but maybe I shouldn’t just yet.
I could just give it a go and see how it lasts but I like the UI and would hate to ruin it. But then again… Can you sense my inner termoil? :cry: …The output is just too low for this form factor. My U11 at half the size puts out as much light. But the beam on the ut02 is pretty nice. See… here we go :person_facepalming:
Has anyone posted any beam shots with an XPL in one of these lights?
Thanks for the comparison dale!
I have the same question about the driver.
Can it be beefed up?
I mean only 1 Ampere means it’s only about 11 Watts, doesn’t it?
Then why bother with a XHP35? An XP-L can do 11 Watts too, and without the losses of a boost driver (but with the losses of a linear driver burning off excess voltage).
And can the driver handle 8.4 Volts?
But XP-L can’t do 1,000+ lm with just 2.3A current draw!
Aha!
Good point.
Well, technically, the XHP-35 won’t do 1000 lumens at 2.3A current draw either. As the cell dies the current will go up, increasingly more until the cell is stomped on. So in the end it’ll balance out something like a normal emitter with higher current draw. I don’t know exactly how it’ll pan out, probably some here that can figure that.
I personally would rather see the new XP-L W2 2B doing 2000 lumens in this light, pulling some 6.7A, with a tighter hot spot. That’s just me though.
Actually w2 bin is very close and xp-l2 can reach 1000 with less watts
A beginners question. What does the pcb board in the tailcap the spring is on do?
thanks for the comparision, the uto2 is surely the way to go if you ask me. i would have one already if it wasnt because of the ui. can’t remember off the top of my head, but it probably has to do with holding the switch to turn on or off light……i hate that.
are you planning to mod the light in any way? i know the lux can be greatly improved with an xpg2.
vinh actually sells his model of the manker 21, i think with his driver and xpg2, it more than doubled stock.
with still 1000 lumens.
Would a flat top 26650 protected Keeppower cell work in the UT02 and give max rated lumens?
I wish it would of have a tactical switch in the bottom , and the one in the head forma changing mods;
You answered your own question, least 50%. Only purpose of the PCB is to mount the spring to it, and give a point of contact to the body tube to complete the ground circuit. When the tail is tightened, the top edge of the tube makes contact to the ground ring on the PCB. This is why it does tail lockout so well - with quality anodized threads, slightly loosening the tail breaks electrically contact at that point of the outer ring on the PCB.
