Dereelight DBS Aspheric throw figures (with new EZ900 0.9mm x 0.9mm WD pure cool white tint 1.5A 3SM pill)
Maybe so, but if it's good quality glass it can reach ~ 10% range or even below. Even the normal achromatic telescopes or photographic lenses with very thick lenses do not cut that much. Lenses is not the same as glass.
Ok, just to set the record, i just measured it and it is about 16% cut. With and without lens measurement via bounce. It's probably not very accurate but just take it as a ballpark figure.
The CSM-360 Flydragon does not have enough surface brightness nor is the lens big w.r.t the big-ass emitter enough to out-throw this.
Ok, maybe let me break it down for you. We calculate distance via measurements. With 90k cd (very conservative figure measured at 55 metres), it is 300m @ 1 lux amd 600m @ 0.25 lux. The latter would be the ANSI standard. There is no guesstimation, hotspot size does not enter the equation. I am measuring at 55 metres, not at 5 metres, not even at 10m which most would tell you "hey, that's far enough for throwers". I use the same distance for my > 1 million cd throwers. Tatjamagic said there is a difference in the lenses themselves even, some give a lot of chromatic abberation (the purple fringing around the spot) and some less.
I posted these pix in my HID big host thread but didn't post the pix in this thread, here goes. 400m target. (Sorry for the light pollution, can't help it man)
Solarforce MPP-1
asd
ads
Fenix TK70
asd
LOL!
asd
I don't have the SR3800 pix. But i do have this, the DBS vs Solarforce MPP-1.
asd
The quality of the lenses is a lot, if we compare the lens of a telescope or a photographic lens that costs more than the whole flashlight, it might not be so fair, and the good photographic lenses have a really big diameter when they got a big zoom, or there are big aberrations on them otherwise.
I am not saying I do not believe the measurements you made, in fact as I said I am very tempted to get one DBS for your fault haha, it is just I like discussing about it to find out the reason it is performing so well to you.
I was told by a friend who has the Flydragon's head with an SST-90 DD with 26650 MNKE it throws close to the 1000m distance, but I cannot assure it as it has not been in my hands to prove it, nor there are luxometer tests at big distances as you made to compare.
The Flydragon head is just 80mm, with the SST-90 in direct drive mode of about up to 15 amps and with direct copper to LED bonding it is possible. 1000m is out of this world. You need 250k cd to do that for the target at 0.25 lux. If you look at CPF mod section there are very few folks who manages to do that, namely ma_sha, Saabluster and a few others, with huge lenses.
This is with a 110mm lens, SST-50 driven to 9 amps, copper heat sink with active cooling.
http://www.candlepowerforums.com/vb/showthread.php?312107-SOLD-The-Led-Torpedo-the-longest-throwing-LED-spotlight
But with a 7 x50 bino (some light amplification) and a really dark site like in the desert, light at least 15m away to the right or left from the observer and a good target, eg a silver car, it is possible even with 100k cd @ 1000m. But that is not realistic.
In fact i rate my 3.8 million cd light to be good at 2km. That is 1 lux at target.
66mm lens with XM-L driven hard gives you 100k, that's the ballpark of this Dereelight DBS aspheric light. :)
Anyway, more info on SST-90 on direct drive.
http://www.lambdalights.com/varapowert.html
http://flashlightnews.net/forum/index.php?topic=2682.20
Actually you could get even more lux with the XP-C driven to 1A
The die is 0.7mm x 0.7mm. EZ900 die XR-E R2 is 0.9mm by 0.9mm. EZ1000 XR-E R2 is 1.0mm by 1.0mm. The beam is quite narrow, so it is not useful even at 100m (handshake, causes the beam to dance around at target)
asd
Thanks for the info 2100, I will ask to get some luxometer tests for the Flydragon head and SST-90, which I believe it was driven at 10A.
My plan as I thinks said before, is making a flood to throw with the DBS with an XM-L, by the time I get it I hope I can get a U3 (they are just about to be released).
With an XM-L U2 and a 38mm lens I got, I have managed to get around 400m throw "by eye" , do you feel the DBS will throw further than 400m with an XM-L?
I happen to have the T6 3C neutral white pill which has the same output as regular cold-white T6. I measured close just a wee bit over 50k for that. So that's about 450m throw for 0.25 lux. I guess you live at a really dark site plus you had dark-adapted eyes.
Sounds good, what I do not know is if 0.25 lux is visible by eye to know more ore less what is the difference.
Don´t tell me why I have ordered the Ultrafire T8 with two lenses from Manafont, I don't feel it will win any of these throwers, but I wanted to give it a try as it is a new concept for me.
0.25 lux is just barely visible to the naked eye at a dark site. In an urban environment, it is very difficult to see but not impossible on a total white or metallic silver surface. My external ambient is about 0.05 lux.
It might be more or less what I see, I see the reflection on windows when moving left to right, as where I live there is a lot of light pollution.
Sorry for being a pain 2100, I am like a 6 years old boy asking why are the clouds white.
Do you know the focal length for the DBS?
I feel it is also a parameter that can make a difference, and more with XM-L and its bigger emitting angle, the less focal length (the closest the die is to the lens) the more light it can throw as it will not hit the walls of the head.
Yes Gorann, that is the one :)
I do not know how it will perform, it was a bit like a blind purchase.
It has just 12mm travel, it sound good to me, lets see how good it concentrates the beam..
Hehe, wait for me to see the results if you want to.
It might be a good deal or a total shit hahaha, I like the concept, and I hope it will not just be a concept.
I ordered it the past 17th, so lets see if I get it in about two weeks...
I will let you know how good it is when I check it.
I do not know what I will do with it Gorann, if it is good as it is I will leave if not I will probably check with an XR-E or an Osram SSL 80.
I don´t find it now, but I think the head used to be in Kaidomain, I have only found the whole flashlight.
http://old.kaidomain.com/ProductDetails.aspx?ProductId=1101
2100 would be the best one to tell us which lens would work better..
4Sevens had a couple of heads in their clearance area recently.
I know the CL1H v4 and DBS tube are compatible with STL-V6 head. And Ultrafire U80 and Ultrafire C8 is compatible with STL-V6. You can search in this forum, i posted some pix and another guy also posted his C8/STL-V6 combo. It is used to get an ultra-short STL-V6.
However, i am sure you can never get it to work in the DBS head housing because it is slight smaller. Besides the focal length is different.
I read that the head collimates a wee bit better and gets you more lux. It's nearly 100k for the current DBS EZ900 aspheric and 120k for the Tiablo A9 modded with a R2 EZ900 (and it is extremely difficult or rather literally impossible as it is glued to the die, you need to screw and lever and knock it out). Stock Tiablo A9 that WAS being sold last year gets you about 90 plus K cd. Note the word "WAS".
But do note, though the CL1H v4 uses P60 style drop ins, it cannot work with Ultrafire P60s with the external spring and you need to take it out. So i guess the threading is identical.
Not sure how are you able to get a Tiablo A9 currently.
Another option is the Lumapower Ultra VX with Turboforce reflector head. Not sure how can you swap in the EZ900 pill as i am not sure how does it work, but it gets 90+ K cd as well with EZ900. Stock is already 70k cd. Not cheap also.
In short, the DBS aspheric is your best bet, no meddling, gets you into the 100k club for 86 bucks.
I actually paid 79 bucks last time for the EZ1000 pill and "upgraded" to this EZ900 for $23. Should Cree come up with something else next year, no problem at all. Dereelight is one of the most stable brands after Fenix and has a history as long as that if i am not grossly wrong, but it is not marketed well.
