If shipping gives you guys problems, maybe an EU member would step up to help as well.
Also, a metal switch button is really pretty specific to the Convoy S2+. It’s not just a piece you can swap out like the rubber buttons, it’s part of the tailcap itself
At the end of the day, shipping is not the problem. And there’s some EU members who could do it . But I’m in no hurry at all and in terms of shipping, I don’t actually care. There’s no custom’s issues as it’s a private matter and shipping costs are not to big.
Hee Bas, I can do it for you, saves the light a trip to the States, but it will be in the new year too, and after another little project. Have a S41S too, and will figure out some working resistor values. I also have Oshpark boards for 6 leds in a circle and a small collection of colour leds.
I think that we can sort out a suitable shipping method, probably a bicycle
LOL now yours was the reply I was hoping for . And no hurry! LOL don’t need 6 bloody leds in the bleeding’ tail, one or two will do nicely . Let me know when and where to send it and thanks!
But you need a bleed resistor from battery + to the body
And most likely also add a capacitor on the to change the modes normally
SMD resistors and capacitors can be recycled from from old electronic parts
I am from Germany and was also thinking to get the modification, but its not so easy and I really dont need a lighted tailcap as they have quite high parasitic drain
And on a SS tailcap you cant just unscrew a bit for lockout like on a anodised light
I’m expecting a S41S in the mail soon (well, i hope it will be soon…)
And i don’t like the translucent tailcap in particular, but would also like to have a stainless steel button with a ring of light (and not just on the S41S).
Maybe blue or green because they’re bright and need little current, maybe red because red needs only 1.9 Volts.
Either way, i’m thinking about using something like this:
Only to use the ring and piston.
But i have many other things to do so it may take a while before i get to it.
Wasn’t the tail PCB all ready for some LEDs for lighted tailcap?
Could check my V1 the day after tomorrow but I remember a pic from a review making it look that part only needs some little LEDs
Driver is something else of course
As I’m trying to do my first mod on an S2, can someone tell me if this 17mm lighted switch can fit to S2 I wanna mod? Will some simple DIY trimming to it’s diameter make it fit easily?
Nice, but what did you buy them for? They’re not click on=click off, they’re on as long as you push the button … The only application I can see is for calling the elevator you must be constructing yourself
I explained earlier:
I will only use the top bit: the outer ring, the translucent ring and the button. And a bit of the threaded part.
The switch i will not use.
I will cut it off under the nut (moer), it will use just a mm more space than a normal slicone boot inside the tailcap.
(at least, that’s the plan…
If it’s impossible maybe i could put it ‘as is’ in my Courui)
Correct, it will physically fit with minor sanding.
The S2+ with metal button is a special case though, the little plastic ring lets very little light through.With that old design, the light will either be too dim to be visible, or draw so much power it won’t be worth it at all.
