Photos of your new arrived lights
Acebeam H10
Nice! How’s the beam? Pretty much a wall of light huh?
I have an E14vn with 219c and with the optics, it makes the beam greenish. I’m now thinking about Just running it as a mule.
Thanks, its stunning and i mean that, the xpl HI 4000k, xpl HD 4000k, then 219C 5000k and 219B 5000k blend beautifully for a 4500k wall of light.
Not sure of the output tbh, but going off quad p60 mules its not much different………….its very very bright! even on an IMR18350 ! Has drivervn4, can set the heat temps, turbo timers
Driver
DriverVN4
Programming Instruction
Step 1: From Off or On quickly tap the switch 10 times to enter Programming Mode. A dim slow blink will initiate.
Step 2: Tap the Deck number. A dim fast blink will initiate.
Step 3. Tap the number of mode group. A double blink & 1stmode in group will initiate.
Circuit Temperature Sensor
10-10-F (Default 160F)
F1= Off, F2 = 105F, F3 = 115F, F4 =120F, F5=130F, F6=14F0, F7=150F, F8=160F, F9=170F, F10=175F, T11=185F, T12=200F
Toggle Programming Lock
10-11-10
Toggle lock or unlock current Mode Group settings.
Any Mode Group in Deck 2 automatically initiates Programming Lock
Turbo Timer
10-12-T ( Default 10 minutes)
T= Time you want Turbo to run
Turbo = Maximum brightness
After entering Deck 12 light will initiate Turbo. Let light run until desired felt temperature and or time. Turn off to lock in Turbo Timer.
Mode Groups
M = Last mode memory. Light will initiate last mode at next turn ON if light is off longer than 1/2 sec. Mode Group without M will always start with 1st mode.
D = Double Tap. At any mode double tap switch to activate Hidden/Last mode.
F = Firefly = Lowest possible brightness
S = Strobe
Deck 1 – Simplest
10-1-1 => 100
10-1-2 => 5/100 M
10-1-3 => 5/100
10-1-4 => 100/5
10-1-5 => 25/100 M
10-1-6 => 25/100
10-1-7 => 100/25
10-1-8 => 50/100 M
10-1-9 => 50/100
10-1-10 => 100/50
Deck 2 – Lenders with Auto Programming Lock
10-2-1 => 30
10-2-2 => 7/30
10-2-3 => 1/7/30
10-2-4 => F/2/10/30
Deck 3 – General Users
10-3-1 => 5/33/100 M
10-3-2 => 5/33/100
10-3-3 => 100/33/5
10-3-4 => 1/15/100 M
10-3-5 => F/15/100
10-3-6 => 100/15/F
10-3-7 => F/33/100 M
10-3-8 => F/33/100
10-3-9 => 100/33/F
10-3-10 => 15/100/F
10-3-11 => 33/100/F
10-3-12 => 50/100/F
Deck 4 – Goldilocks
10-4-1 => F/5/33/100 M
10-4-2 => F/5/33/100
10-4-3 => 100/33/5/F
10-4-4 => F/5/33 D for 100
10-4-5 => F/2/25/100
Deck 5 – 5 Level Precision
10-5-1 => F/1/20/50/100 M
10-5-2 => F/1/20/50/100
10-5-3 => 100/50/20/1/F
10-5-4 => F/.7/3/25/100
10-5-5 => F/1/5/25 D for 100
Deck 6 – 6 Level Precision
10-6-1 => F/1/5/15/50/100 M
10-6-2 => F/1/5/15/50/100
10-6-3 => F/100/50/15/5/1/F
10-6-4 => F/.7/2/7/25/100
10-6-5 => F/1/3/10/30/100
Deck 7 – Tactical
10-7-1 => 100/S M
10-7-2 => 100/S
10-7-3 => S/100
10-7-4 => 100/20/S
10-7-5 => 100/25 D for Strobe
10-7-6 => 15/100/S MD for Strobe
10-7-7 => 5/33/100 M-D for Strobe
10-7-8 => 3/5/33/100 M-D for Strobe
Deck 8 – Discos & Bicycle
10-8-1=> 10/25/50/70/100/BikeLo/BikeHi
10-8-2=> 5/33/100/Blink.5Hz/Blink1Hz/Blink3Hz/BikeHi/Blink8Hz/S/Beacon
So many options to suit most users there, i like 2 mode simplicity no memory or 3 mode no memory like 5/33/100. 2 mode i like 25% level as this tends to be enough for 95% of my uses, no memory again so you know what to get, Set turbo timer and set temp to 185F as a back up.
Stunning is all that springs to mind tbh
Wow… !! thats impressive
A lot of beautiful lights. That custom E14 is indeed impressive ven. My posting has a little less art to it but its growing on me since I’ve started using it. It’s TM28 with 4x XHP35. I too got the Christmas Tip and had dismissed the Thumb but now that I see Mr Simple with it tucked in like that I’m going to check it out. I think I want that one too.
Been a busy couple weeks!! All new additions. The Manker and Utorch came today.
Thanks
Very cool, very nice touch too with the flat to button top converter……………not seen that before!!!
It does have the look of a diving knife about it. A nice find.
In the last few weeks I’ve received a Manker E11 and a Klarus Mi7.
I then received a Klarus XT11GT which vanished and a friend now has.
Today this bad boy arrived…. I love it.
!http://i.imgur.com/2ApYQc2.jpg !
Convoy S2+ 365nm Flashlight, love this thing.
Add a ZWB2 filter, you’ll love it more !
Not a light but an important internal part!, another sportac nichia, this time single mode and to live in a cooly host
Fed on kinoko fuel
few hours ago arrived….
I like it! :wink:
A pair of Jetbeams. SF-R26 (XPL HI) and SF-R28 (XHP 50). Going to do a basic review on them in a few days.
Is not a new light….but is my last arrived light
:innocent:
EC4
and
B158B
Congrats Trev on the HDS, amazing little light
Quad xp-g3 3000k & 5700k 80+90 cri off vinte
Big gun x65vn 5000k xpl HI 10,500lm and 620kcd
Very misty out
Convoy S2+ 7135x4 3B
I wait 4 weeks for this baby!
