Multi-leds:
Cute-3
Cute-4
GT-3 (can fit xp32 too if I not mistaken)
GT-4
Angie (quad that will throw better than Cute-4SS, unfortunately they have different leds disposition)
Khatod also have some 35mm triple tirs, but for my opinion they are more flood than Cute-3M.
In fact this size (35x15mm) is MR11 standart, there are many chinese manufacures that are making tons of them for home spot lights.
As for single leds, you can put any tir that will fit inside if you will use proper spacer.
For example, I have some ledlink ultra narrow beam tirs (35mm od, 20.8mm height). To avoid datasheet misunderstanding, I will leave here actual specifications:
XP-E2: 4° FWHM, 95.4 cd/lm
XP-L HI: 6.0° FWHM, 47.5 cd/lm
XHP35 HI: 6.9° FWHM, 34.4 cd/lm
XHP35 HD: 9.7° FWHM, 18.9 cd/lm
XM-L: 9.0° FWHM, 22.4 cd/lm
Would like 2 P60 surefire drop ins
Payment sent and scarily fast response :partying_face:
X6 Cu (for alu host) spacers, X6 Cu (for SS/Cu host) spacers, S2, S2+ Cu spacers in stock.
Copper P60 neck?
Spacer for a laser or a saber :heart_eyes:
No, this is ready for use product, not blank before threads cutting.
No, it is not so useless.
Is it in two parts? Looks to have a join at the short end.
My first thought was C8 spacer simply because it’s the most recent new item I have seen being discussed, but when I saw the join I had no idea. And the tapered ends made me think it could be for something that requires a press fit.
No, this is one solid piece.
SK68 to TIR?
sk-98 to triple ?
Ok, previous photo was not good, it was hard to determine real size, also my phone have big problems with color rendering over this green pad, so most of you confused the material.
The head of a flashlight ? A zooming one ?
Can we get a picture from the end?
One day=one picture.
A Battery Adapter or something to measure Battery tubes with 10, 14 and 18 mm diameter.
Good idea. But no.
E-switch button.
Almost 20mm length? E-switch button for tank?
