That is a tricky set-up, jon! To have a fixed calibration for all kinds of flashlight sizes and types, your set-up depends on a luxmeter that correctly reads light coming from any direction, hitting the detector at any postion (and as I understand, that is not an easy requirement to match for a luxmeter).
But the proof of the pudding is again in the eating, if in a series of tests, the calibration of this set-up proves correct enough in various types of flashlights, all is good.
I have no idea if my tests would be relevant with anything other than an AAA light with similar reflector, but it does let me compare similar heads at least. I dont trust the ~85 lumen reading on the AA L11c. Maybe my plastic cap is not consistent when the LED is closer to the plastic vitamin cap on the AAA head, and further away on the AA head.
great fun though, Ive compared a bunch of AAA maratacs and Tools with various drivers, LMH and HML modes, each in both N219b and with 3000k XPG swaps.
I can tell you a reylight with a 3000k XPG reads .6, and a reylight with a 4500k N219b reads 1 on my integrating cap (note that the drop in lumens is in proportion to the drop in CCT):
I also have an Olight i3s, whose stock 6000k XP-G low is mfg spec of 0.5 lumens, modded to a 3000k XPL it reads .2 on my meter:
The real hard part with this type of thing beyond the sphere setup is getting a good calibration. This was my limting factor for my sphere. I simply didn’t have any better lights from which to use as a standard.
If I had a 100% known lumen output light calibration would have been 100x easier, the issue when all you have is modded lights or lights without trustworthy lumen ratings is picking which one to use as your standard.
In my case I settled on a midrange point between all the halfway trustworthy lights and then compared that to the Cree data sheets with a few LED tests.
I have no idea if it is accurate or not but it lines up with the ansi ratings on the few lights I have that came with them and it also lines up with cree data sheets and lastly it is in line with the numbers I see posted on here. So I am happy with the calibration.
true
at the very least though, you can determine which of your lights are the dimmest, and in what order
fwiw, I redid the L11c test with a hot off the charger Eneloop and got an extra 20 lumens compared to my earlier test, but still 35 lumen below spec
I still agree a larger diffusion area would do a better job of comparing lights that are not using the same heads
my Dinky Integrator is just AAA size for now… thanks for helping me get some cheap thrills
I still think you made a major contribution to the Integration Tool concept, by calibrating to your meter. That seems to work. I dont see any particular challenges in regard to consistency of the reading at Low vs High levels (in the narrow range Im testing anyway.) I think you concept is sound, and it made my whole setup really practical. Im very grateful for your contributions to my entertainment…
Just wanted to say thank you TA for creating this thread. I've been playing around with improving my light tube using the ideas you published in the OP. Really has helped a lot. It has also got me trying other materials and designs. So far, nothing has done better than your model in the OP, but it's interesting to explore this aspect of the hobby. In the past, I've been frustrated and discouraged by how much my measurements could vary by just the slightest change in flashlight depth into the tube and such.
I call mine a PVC light box . I'm a little surprised the round spheres haven't taken off more so than the PVC light box designs. I think I read of some issues with the spheres, but haven't followed it closely. I haven't had time to look in adapting mine to how yours is set up here, but looks like it has definite benefits. For me, I'd probably want to build up a 2nd one, rather than losing my only means of lumens measurement while I build, tweak and test, then also I'd have something to compare with.
Thanks, glad others are finding it useful. It is by no means a perfect sphere but it does work far better then my prior designs without the “integrating layer”.
I do think a thinner layer would be better though. Maybe something like DC fix. 2 separate layers would be even better I think.
The other major change I would make if I did it again would be to make the inside of the PVC a matte finish. Either by sanding it (quick and simple) or with a high quality flat paint. The flatter the finish the better.
Yeah, it is more of a light box really but no one searches for light box.
The issue with the round ones is mostly availability and cost. The styrofoam versions work great for low powered lights but once you get to ~1000 lumens or so they start to divagate due to so much light making it through the foam. Plus they are big and bulky which is the biggest reason I prefer the PVC setup, it is much easier to deal with on the desk.
Yeah, build a second one for sure so that you can use the first one to calibrate the second. Calibration is the hardest part in any sphere build. I am still not that confident in mine, it is simply the best I have been able to come up with using the flashlights and LED’s I have access to.
In my LED tests my readings are generally within the margin of error for the datasheet specs, so that would say I am not too far off.
Nice. The crazy angles matter though, not just "realistic" conditions. The crazy angles matter because the whole point of an integrating sphere is not how consistently it can give the same value for the same light, you don't need any kind of sphere or box for that, just a meter stick. The point is how well it can account for angular distributions of different lights.
The main point here is many bounces average out. I wonder about using a jar of some granular cloudy material. Beads? Salt? etc. I also though like EASYB's method, just measure brightness at several angles, and... integrate. Of course it's not as comfortable.
This is not true, loss of integration from light loss through the wall is with the average wall thickness of styrofoam balls (over here 2cm) negligable, and is completely independent of the light power of the measured source. The limit of my integrating spheres are solely determined by the range of the luxmeter that is used, which can be extended to wish by either a neutral density filter or the use of a satellite sphere. My most used sphere measures up to 15,000 lumen, if I need to measure higher, a small adaptation can extend that range.
Is the bad availability of suitable styrofoam balls the only reason for people to not build integrating spheres? (which despite the love of flashoholics for tube-systems are according to all literature of light measuring and measurements in practical use the way to go for good integrated light flux measuring). It is not that it is difficult, via my sigline people will find 4 IS build threads, of which one is simpler, cheaper, faster to build, and better integrating than any tube-system that is in use by CPF and BLF members.
I don’t know what your sphere consists of but I know that the JoshK sphere that I have will deviate by 5% or 10% (forgot which, been a year since I messed with it) per 1000 lumens due to losses.
So basically I have to adjust the multiplier by adding an additional 5-10% per 1000 lumens as the lumens go up in order to get an accurate result.
I tested this by testing three S2+’s separately and then putting them all together and taking a reading and the readings did not match up like they should. I used a few other lights in the same way with the same results. I also compared it to my PVC sphere. The PCV did not deviate to a statistically significant extent where the foam ball did.
I ran these tests due to over time the readings I was getting on high output lights was just not adding up compared to the low output.
All of the data is posted in the joshK thread.
I was 100% in favor of the sphere when I started all of this, which is why I was so excited to get the josh sphere and give it a try. The move away from it was not easy and only happened because I got significantly better and more consistent results on the PVC sphere.
I have positively nothing to prove in this case, I would love a proper sphere but the cost to build one would be way too much to justify the result based on my experiences so far. It would also be a lot of work as it would need to be coated with something to keep the light from making it through the foam.
Which is a point, light makes it through the foam super easy, even moon can be seen just making it glow in a dark room. It is quite possible that denser foam would not have this issue.
Measuring light has little to do with light loss but all with keeping the loss constant, the fact that a small fraction (in the order of a few %) of the light goes through the wall of the styrofoam is of no concern for either integration or accuracy.
About Joshk’s spheres:
I stopped reading and posting in Joshk’s thread after he refused to take on any advice from me (two years of building spheres and numerous tests on the performance), and was being rude to Texlite who was giving very good input at the time. Then he went completely his own way with some clear misconceptions about measuring light and produced and sold a number of spheres without any proper test data on their performance.
He would not even know what kind of tests to perform, not even sure if he really understands what light integration is. Which is all perfectly alright but not if you are into integration sphere making and distributing.
Not having followed his thread any further I would not know why his spheres do not perform, it is certainly not the concept of the integrating sphere, which has been proven worldwide by every light lab.
Just measured two flashlights (that I know have a good constant output) in my integrating sphere, first separately, then together next to each other in the entrance hole. I did not correct for entrance hole effects on the multiplier (but that effect is limited in my large sphere)
First light: 71 lumen
Second light: 115 lumen
Together: 185 lumen
For the record I never doubted your sphere works or that the sphere design works better.
I doubt that cheap spheres using cheap styrofoam balls work better then a PVC setup like I have now.
The only thing with the josh sphere I could not isolate and test was the sphere itself, which is why I came to, and still hold, the conclusion that the foam sphere itself is the cause of the non-linear readings.
With a better and/or coated sphere I have no doubt it would be superior. The question is, at what cost?
I am very much a results minded guy. I am not overly worried about how the results are achieved, as long as they are the desired results.
Thing is that we try to achieve some accuracy (don’t we all?), but we are actually pretty satisfied with a ballpark figure. So if our numbers are not consistent or match up, we just call it a day. And why not?
Btw, in integrating sphere making (and measuring light in general) I found that achieving a good performance has little to do with costs, it has to do with having your theory in order, thinking a lot about how to avoid possible errors, and testing, testing, testing.
Solving an error can be as cheap as taking a piece of sandpaper and carefully sand the inside of a sphere to a nice matt finish (just an example).
I'm guessing most folks would prefer a proper sphere. Whenever I have read a build thread on one, I would get a bit intimidated. Not so much by the physical building, but by understanding what is going on in one. I've always trusted djozz and others that take measuring light seriously, but it's difficult for me to picture in my mind how a sphere can measure both extremes in beam profiles accurately. Couple that with having to purchase or construct a large rigid structure, the barrier to entry was just to high.
I did, though, already have adequately sized PVC parts on hand. With those, I tried my hand at it years ago, but didn't like the fiddly, inconsistent results. I pretty much wrote it off until this thread was created. Someday, I would like a proper sphere that is big enough to measure my big lights. It may have to do double duty as a table top stand or something to overcome the SAF though.
I would agree, it took dozens if not hundreds of hours worth of testing to get my sphere where it is now. It is now consistent enough that I will at least post the numbers although I still have no idea exactly how accurate it is, I just know it is in the ballpark.
I appreciate the heroic efforts to measure total light flux as reliably as possible. However
only total lumens and OTF lux are insufficient to characterize the beam.
I think it’d be better to measure “intensity” (in the photometric definition), as a function of angle instead of only along the flashlight axis. If we had a table of candela X angle we’d have a much more complete picture of the beam and could answer questions like how big/intense is the hotspot, how much spill or corona there is, etc. This is unusual because it’s too much for the general public but for this community it’d be very useful and it seems that measuring lux reliably is a lot easier than total emission.
In principle we need measurements in the whole plane but almost all flashlights have a beam with cylindrical symmetry so readings along a single line are enough. It can be along a circle or a perperdicular to axis.
If we know the distance to the flashlight we can also easily integrate and determine total lumens emitted in the measured angular range, and going far enough even total lumens. This way we wouldn’t even need an integrating sphere and if we have such measurements we can compare with the angular result.
These readings take some time, so it’s better to do them at low/mid levels to avoid output drop. Since the beam profile won’t change with intensity level, doing 1 or 2 readings at max is enough to scale the complete graph.
