Ok, previous photo was not good, it was hard to determine real size, also my phone have big problems with color rendering over this green pad, so most of you confused the material.
The head of a flashlight ? A zooming one ?
Can we get a picture from the end?
One day=one picture.
A Battery Adapter or something to measure Battery tubes with 10, 14 and 18 mm diameter.
Good idea. But no.
E-switch button.
Almost 20mm length? E-switch button for tank?
File it to fit? :person_facepalming:
battery spacer
Do you ever make a triple (or quad) setup for the convoy M1?
I have a empty host here and can’t decide what to do with it, never built an M1 before.
Any interest in making a maglite LED conversion pill? I’d prefer one to use with new reflector that didn’t have zoom.
Dang, I was completely wrong with the scale, I thought they were at least twice the size they are. I was on my phone and I would have bet money that it was in two parts, glad I didn’t! :person_facepalming:
I had some requests from members for making quad to fit Kathod optics. I decided that M1 is the best host for this optics. Anyway, I dont think it is several times better than Carclo (but it is several times more expensive).
I made 15 pcs only and think this is all. I can make make more if we need at least 5pcs, or share drawings with someone.
Yes. It is hard to get maglite hosts out of states. Will do if somebody will help me with the dimentions or parts.
I'll go in for 3 or 4 of those.
Can the M1 use another cheaper optic as well?
No, M1 kit was designed special for Khatod quad. Other optics (carclo quad) is smaller height, smaller OD, so spacer should be higher, liner ring thicker and etc.
P.S. Im using M1 with S2+ spacer and 30mm Carclo single optics.
