wow! this thing is beautiful! :+1:
A minute or 2 in Turbo mode?
Mine steps down to high mode after about 37 seconds in Turbo.
I just got my S14S, the LEDs and lens are 100% okay. No flaws from what I can see. Only minor complaints at all is the knurling is quite aggressive and it pinches the bottom o-ring just a little.
Now if my S41SC and extension tube will get here…
I received mine, XP-G3. On a primary inspection the driver’s retainer was a little loose, tight.
after reading some of recent post i notice there’s alot of problem with this light. what do you guys think….buy or wait? any advice?
At this point I think its a buy. I waited for the issues to get ironed out myself and the light I received a few weeks ago has no issues to speak of. I’ve seen others post the same sentiment, but as always ymmv.
Well, i bought mine early december when it was around $ 33.
I think that’s a bargain for a stainless steel quad light with a pure copper head.
It’s the latest version without glue, so i can do what i want with it to improve / adapt it.
My only complaints are that the O ring in the bezel is too thin so the lens can move a little (even after putting a piece of diffuser sheet between optic and lens), the clip is pretty useless and cheap looking, the knurling is so sharp you can use it as a file, and i’m not sure if it should step down a mode after only 37 seconds in turbo mode.
For the rest, i love it and i would certainly buy it again for that price.
yeah martin said the same too. and thanks for your advice. i’ve just bought one a minute ago. i chose coloured w/ nichia 219B. :+1:
Could it be the battery problem? I’ll be using my Olight 16340 protected battery or 30Q 18650 hopefully no issue
The 37 seconds (supposed to be 40) are a feature of the used BLF-A6 driver, which was developed for the BLF-A6 that needed about that timing to prevent overheating. Banggood just used that driver without adapting anything for the S41 (I’m not sure if they even have the knowledge to mess with firmware) , that with its copper chunk could use a bit longer stepdown timing.
My new head finally arrived today, I can confirm that it is NOT glued… Well worth the wait
I hate to be one of those people, but the best way to “fix” the driver (assuming you consider it inadequate) on this light is to dump it for a better one. I was actually pretty surprised (aka disappointed) to see that they had just wholesale copied over the A6 driver for this light. Mine immediately came out and was replaced by one of MtnElec’s Bistro drivers — more programmable, temp regulation instead of stepdown, and a great thru-board bypass. Reflowed 4 219cs to make the upgrade complete and it became a much better light altogether. I think the host is worth doing the upgrades.
Thanks for that info. :+1:
I’ve read somewhere that a TPAD + carclo quad optic can be used if diameter on the optic is reduced. However, from what I can tell, the height of the set up differs from stock?
Has anyone successfully rebuilt this with carclo optics? I’m on the fence on this light and this could be a deciding factor.
I have built an S41 with Tpad quad and fitted Carclo. Used XP-L HI 3A and it works great with MtnE Fet+1 on Bistro.
However I have Not tried it with the new designed heads they are now using. Optic is now supported in the copper head, not the legs of the optic as a Carclo would be.
Sounds like quite the pocket rocket. I’d be interested in doing something similar with 4x 219C.
How did you reduce the diameter of the optic? and did you notice any fitment issues? The original s41 optic and board has a different height than a tpad + carclo.
I’ve used these Nichia 219CT 4000K R9050 with the Mtn. Fet+1 Bistro and I don’t think it could get any better… at least for my skill levels.
Edit: Plus I never did buy the complete light, I waited until the heads got straightened out and bought the heads only with using my points at BG the cost was $27 and $4 per LED, used all A6 no ano tubes and Astro tubes for the rest, always thought the SS tubes and switch would be just to heavy for my liking and it worked out great, especially the no ano A6 tubes all buffed up shiny, looks real good.
Has anyone noticed a difference in heat dissipation between the stainless and aluminum versions?
I’m not saying that the BLF-A6 driver is a bad driver for the S41, just that it is not especially made for it and could use tweaks. I like it better than any other driver they could have chosen.
That one got the Tpad soldered directly to the copper head using a hot plate. Carclo was filed by hand. You can trace the original optic on top of the Carclo to know when to stop filing. It is 2mm reduction which is 1mm all around it.
Allow me to explain a few things, mainly why… the switch to Tpad and Carclo.
These lights were originally Flawed by design. Optics were crushing emitters and ruining them. My reasoning to swap all parts inside was to keep the looks of the light and make it GOOD. Make what I had work again and make it better. Carclo optic has 4 legs to properly support it under pressure. But the Carclo optic does Not fit the original quad board. Tpad quad was made for the Carclo…
Now the copper head has two shelves to support the optic from crushing the emitters. This is where I am unsure if the Carclo will work inside the head now even if the size it reduced to 22mm to fit in the head recess. Honestly the original optic has a cleaner spot than a Carclo and the original optic already fits in the head. If I were to MOD a Newer S41S with redesigned head, I would simply swap the emitters to the original board and keep original optic. Original board is Nichia 219B or C size which is also XP size… XP-G, G2, G3, L and L HI.
But you may still want to consider the MtnE Fet drivers with Bistro to get a programmable thermal sensor to kick back modes at your desired temperature. Not just a blind timer control.
