A spacer for the SRK that was setup to fit 4x quad setups for 16 LED’s would be an interesting. The 8x SRK models seem to be the most popular right now and the shell on all the ones I got had the same internal dimensions.
Or even just a slug to fill in the gaping hole under the LED’s. With said slug I have swapped the stock LB LED’s for XM-L2 U2’s and a TA driver and made over 9000 lumens. With a DTP MCPCB it should do more.
I havent build any light without glass lens. I think you can find better advices from other members about this option.
There is no difference in heat transfer, but visible difference in heat-accomodate mass. For first few minutes triple with copper spacer will be much colder, but difference will decrease and goes to the zero.
As I promised earlier I will send you one C8 triple spacer sample for free. I think copper version will be limited production for BLF members (it will make light too heavy for most users). I would like to make most of them from aluminium and have ordered it, unfortunately I wont be able to get it until mid of january. Anyway, first samples will be ready not earlier than end of January.
Other goods? Zero res switch, P60 single screw-ins, some P60 tail rings…seems thats all.
I tried without glass , but i don’t like how easily optics get scratches on them. Yes , it will still seal watertight .
About copper VS aluminum , i don’t think there will be a considerable difference using the copper one (plus , i really like the lightweight x6 triple when used with aluminum spacer ) .
Will do for 4xTriples for Q8, four quads are too big (24×2.41=58mm without any place between optics).
Slug for noname hosts is big problem. All clones are different, even one brand can sell SRK with different internals.
Yeah, I have found I prefer the aluminum spacers in the S2 series for this reason the lighter weight is nice and while you may gain an extra 15-30 seconds of usable time before it gets too hot to hold with copper I don’t think it is worth it myself.
The X6 being so much larger I was not sure if the same things applied.
I am torn between glass or no glass. The optic does get scratched pretty easy but I don’t notice a lot of real world difference on my S2+’s with them in output or beam pattern. I guess I can always order one of each and use it as an excuse to build another one later
I have a few of the no glass spacers. I’ve only used 1. It went into an EagleEye X6. It was to short without glass and to tall with. I arctic epoxied a flat ground copper shim in to make the bezel o-ring seal to the optic. I think it was around .040” thick.
Are you sure this were mine spacers?
I specially left X6 spacers height in the OP. Taller one should be 2.0mm bigger than more regular version. This is same or little (0.1-0.2mm) more than glass thickness.
P.S. More than 30pcs of 10.6 X6 spacers were sold here. Waiting feedback from other members.
The dimensions were spot on as far as your spacer is concerned. I figured it was just the difference from your host to mine. There's obviously some variances from host to host.
The o-ring was barely loose when the bezel was tightened. I simply put a shim underneath it to get a good squish on the o-ring. It worked great!
Well, for me everything is issue, but same time some members are usual to use lots of tools, take of lots of material, and then saying “its ok, just little hand work”. I understand that some people like it (hand work) and taken good kit and building light without any drilling/cutting/filing is too simple for them. But here is also lots of people that started light modding just because my “ready for use” kits do exist.
I ask everyone who will or have met any problems (even small one) with my parts or who just have any suggests - please contact me with your ideas. If you have fixed problems yourself, you can help others to avoid them in future.
I had a small problem with one of your S2+ copper pills, bought off eBay before I joined the forum.
The threads right at the front of the pill were slightly squashed together, so it wouldn’t screw into the head. Managed to open them back up by putting the pill in backwards and screwing it down, fortunately the aluminium alloy is harder than copper
I know what you mean but I don't know that it's entirely possible when working with these budget flashlights. There's gonna be differences from host to host.
Maybe it can get better but I don't think your gonna get them all just right when the host manufacturers have such high tolerances.
I'll be ordering more EagleEye X6's (they seem to be better quality) pretty soon and I'll measure each one and report back.
These are great heatsinks already so having an average set of measurements from each brand of host is the only way I can see them getting better.
Yes, I know that this problem exist. Sometimes copper is too soft and few last threads are trying to be bended instead of cutted. Will try to fix this in next batches.
Host from 6061T just pretends to be harder than copper. I have met problems when I used to use host for test how does pill fit. After operations that you have described with hundred of pills it had much larger threads than new one.
Completed the build with triple nichia 219C cri 80+ with LD-3 9Amps driver. Brass ring needs to be filed to make clearance for moonlight parts and prevent shorts on others parts of the driver. I filed too much on the brass ring. Lucky i have spares. Happy with the build.
I think it will be better if the pill has the 2 notches like the original for screwing it in. If i want to unscrew the pill sometimes only the brass ring gets unscrewed and not the pill.
