Mine came today.after careful calibration of the dick smith esr and a test that gave 20 mohms this is the lowest yet.they are getting better.
edit.
after full charge i repeated.
now if i press very hard on the pointy probes i can get to .01 blinking to .02
so 19 or 18 mohms
Where did you order from?
banggood
Are you planning on checking the capacity?
If you do, give us an update please as to results and test equipment used. :+1:
UDO, you mean you are âabsolutelyâ sure your e-bike limits itself for max 14A amp draw (â700W of power)? I reeally doubt it.
A 14S3P pack of NCR18650Bs, though slightly lighter, would be a baad idea, imho. 3P NCR18650Bs aren't high drain cells and, comparatively, would barely deliver slightly more current at the same output voltage than a single LiitoKala 26650-50A/B.
For a vehicle, no matter what, it is advisable to use sufficiently high drain/power cell packs. Either that, or its throttle response/slope performance will suck, not to mention battery life would also crumble.
It is also possible to build hybrid battery packs. If, for example, you were to like the idea of having a battery pack combining slightly less weight and capacity but preserve/enhance top power output, you could then assemble, for example, a 14SαP pack, for α = sum of a top notch high drain 18650 plus our 26650.
Cheers ^:)
Originally posted on Fri, 12/30/2016 - 04:10; typo fixup.
absolutely.test equipment is a triton hobby charger.
i still have 2 and will test them over the holiday weekend.
the other 4 from the order are in box mods and doing great.
Thank you âsnakebiteâ, looking forward to the results. :+1:
cell 1 cycle 1
5117@1a
cell 1 cycle 2 after fixing the test rig.
5211@1a
cell 2 cycle 1
5277@1a
cycle 2
5451@1a
cell 1 cycle 1
5117@1a
Good info, thankâs âsnakebiteâ. :+1:
They (LiitoKala 26650âs) seem to be staying fairly consistent as time goes on. I hope it continues.
Are you at all interested in modding my Utorch UT02 (Manker U21)? I would certainly pay for materials. Maybe work a trade of some kind? Maybe a new in package Lumintop TD16? Or something else.
update.
i discovered high resistance in my test rig.banana plugs to my holder were losing their tension.
charged the cells again and started another discharge.holding 4.13v @ 1a at start.
was 3.96v.
so these are likely better than we thought.
stay tunedâŠ
What do you want done with it? I like a dedomed XPL in it, but some might prefer it domed.
I received four from GearBest yesterday, first charge>discharge cycle @ 1A down to 2,8V :
I started the cycle this morning before I went to work so the cell voltage recovered a bit.
I am recharging them now :
What is the max current draw you get these from these in a direct drive set up? I just bought 6 shipping was 11 USD so i hope they do well.
well i found a bug.
kingkong 26.21mm
liitokala 26.63mm
too fat for one mod.
will post brand/model when i get it.
they fit all my lights though.
These are a bit wider and a bit shorter then most other 26650âs, it fits like a glove in the L6, it doesnât fall when inserted it just slowly lowers itself to the bottom.
Gonna get some serious amps mangled from them pretty soonâŠ
The BMS low voltage/under discharge protection works well. I accidentally hard-shorted the BP+/B- terminals while assembling the stuff, a lil smoke crept away⊠Had to hook the thing up to the charger board to relive it. Quite interesting to notice my multimeter could actually measure some volts at the output terminals after the âaccidentâ, a below 1Hz voltage signal oscillating between very high 6s and low 7s.
Cheers
Yesterday i received my 2 pcs. I put them to the test with my Opus.
1 cell at 1A - 5434mAh
2 cell at 1A - 5534mAh
I will test them these days on my L6 and will see how they perform.
Received one from Banggood. Did discharge test in Opus BT-C100: 4898mAh. A bit disappointing. Impedance test afterwards showed 76mR.
Just noticed that the product listing has disappeared from BanggoodâŠ
Interesting, I picked up some of these because of good reports earlier, but I have not tested them, waiting for some nice new light. Maybe I will test them when my test charges arrives and then put them back at storage voltage until I have a need for them. They sure seem like a pretty good bargain.
