Probably You just didn’t noticed that the lens first sits on the leds domes, and it’s still missing around 0,5mm that the optic legs base in the right place. You just get lucky You didn’t damaged the LED domes when assembling all together.
I assumed that because it fits the same board, but now that you correct me I see that I’m completely wrong. Just had a look at the KD triple that I received last week, it even does not fit the Carclo 20mm triple optic, just KD’s own one (which looks nice enough btw, I like the thicker build and the flat surface so that it can more safe be used in a flashlight without glass lens).
Left KD 20mm triple optic, right Carclo 20mm optic.
The KD triple boards I have are JUNK, they aren’t flat at all too thin by the time I filed and stoned flat, you can spin them on a flat surface like a TOP!
It’s look like stamped from thin copper plate. Edges are rounded, and aren’t flat as KawiBoy1428 said. If compared to other top quality like Noctigon it seems to be very weak.
Anyone has used a KD triple board + optic combination yet to see if these potential issues are actually a real problem?
As far as the board goes: It takes two minutes to sand it flat (I always flatten my boards, I wish I could get the pills as flat as the boards), they are copper and are DTP and therefore will be as good as any DTP board in heat performance.
About the optic: it looks like it will be closer to the led indeed which could potentially damage the led, but may also extract a bit more light out of the led. I’m curious about the beam.
The board plus optics in correct position is 7.4mm but there’s an issue, the legs, when fully inserted up to where the ‘stops’ are (which I assume is the correct optical position, and the optic just not touches the silicon of the leds there), they stick out on the underside of the rather thin 1.0mm board by .7mm.So the optic plus full legs is 8.1mm. Seems like the optic is made with a 2mm board thickness in mind. Nothing you can’t sand off though…
Hmmm… The picture shows the optics resting on the LEDs, not on the ‘stops’.
I had noticed that too with my triples.
Had the board been the regular 1.6mm thickness, it would prevent that from happening, the optics would then be 0.1mm above the LED.
has anybody ordered the KD Nichia 219c triple and not (yet) received it? Are there any potential issues at customs/cargo atm? Ordered on day 1 of the deal and it has been 35+ days without anything yet
My order on Dec 24th should arrive today - it's at my local post office. Ordered 4 of the XPL2 V6's and couple more of your DTP MCPCB's. I really like them in black. Please keep those prices on the DTP MCPCB's! Your discount keeps them competitive, but if your discount expires, your qty pricing does not match up well against intl-outdoor's.
To me it's not worth paying more for a preferred color.
In fact it would be great if you updated your qty pricing based on the discounted price .
I’m not sure about Kaidomain, but Gearbest uses permanently ‘discounted’ prices on items to prevent using coupon codes or store ‘points’. Nevertheless: keep those prices as low as they are
Ban, about the DTP triple board, as seen in the picture a couple of posts above, they do not fully match the optic that comes with it, or the optic is wrong: the broadening of the legs are at the wrong height for this board. Could you take a look at it?
